[petsc-users] EVP Solutions with Subspace
Sonya Blade
sonyablade2010 at hotmail.com
Fri Apr 5 08:36:00 CDT 2013
> For each matrix, after you finish calling MatSetValues() for that matrix you need to call >MatAssemblyBegin(mat,MAT_FINAL_ASSEMBLY) then MatAssemblyEnd(mat,MAT_FINAL_ASSEMBLY) See the manual page.
Thank you Bary,
And how to set the requested eigenvalue numbers, for example if I prefer only the
6 lowest or 6 highest eigenvalues to be found?
