[petsc-users] EVP Solutions with Subspace
Barry Smith
bsmith at mcs.anl.gov
Fri Apr 5 08:26:39 CDT 2013
For each matrix, after you finish calling MatSetValues() for that matrix you need to call MatAssemblyBegin(mat,MAT_FINAL_ASSEMBLY) then MatAssemblyEnd(mat,MAT_FINAL_ASSEMBLY) See the manual page.
Barry
On Apr 5, 2013, at 8:20 AM, Sonya Blade <sonyablade2010 at hotmail.com> wrote:
> Dear All,
> I'd like to solve the problem of Generalized EVP where A is positive definite
> and where B has products only on its diagonal and some of them might be zeros.
> I started implementation with modifying the existing example(namely example 2
> in the official Slepc site). Instead of using the Matrix viewer object I used
> reading A and B matrices directly from text file. Program produces the following
> error message, this has been triggered right after ierr = EPSSolve(eps);CHKERRQ(ierr);
> call. I supply with main program body and required matrices stored in files.
> [0]PETSC ERROR: --------------------- Error Message ----------------------------
> [0]PETSC ERROR: Object is in wrong state!
> [0]PETSC ERROR: Not for unassembled matrix!
> [0]PETSC ERROR: ----------------------------------------------------------------
> [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 6, Mon Feb 11 12:26:34 CST 20
> 13
> I appreciated your help, any other example of solving GEVP with subspace, arnoldi
> or Lanczos methods is also wellcome.
> Regards, <main.c><IN.txt><mass.txt>
