[petsc-users] Petsc/Slepc Integration with Code Blocks IDE
Mon Apr 1 07:52:20 CDT 2013
Sonya Blade <sonyablade2010 at hotmail.com> writes:
> Thank you Jed,
> After running the code it retrieves, the given results
> $ make getlinklibs
> 1> -Wl,-rpath,/cygdrive/c/Users/...../Downloads/petsc-3.3-p6/arch-mswin-c-debug/lib
> 2> -L/cygdrive/c/Users/...../Downloads/petsc-3.3-p6/arch-mswin-c-debug/lib -lpetsc -lX11 -lpthread -Wl,
> 3>-rpath,/cygdrive/c/Users/...../Downloads/petsc-3.3-p6/arch-mswin-c-debug/lib -lflapack -lfblas
> 4>-L/usr/lib/gcc/i686-pc-cygwin/4.5.3 -lmpichf90 -lgfortran -lgcc_s -lgdi32 -luser32 -ladvapi32 -lkernel32 -ldl -lpmpich
> 5>-lmpich -lopa -lmpl -lpthread -lgcc_eh -luser32 -ladvapi32 -lshell32 -ldl
> I've tried to parse out so it can be more readable, in the second line there is -lX11 and -lpthread
> libraries which I don't have in the mentioned folder.
They are likely in "system paths", thus available using only -lX11. I
don't know what format Code Blocks expects, but libX11 is the one
accounting for most/all of your errors.
> And should I add those libraries gdi32, advapi32, kernel32, shell32 depicted
> in the 4 and 5 line ? It seems they are intrinsic libraries that I'm not supposed to
> dealt with.
You can try without, and add them if you get weird link errors. It
depends whether Code Blocks and/or your compiler add them automatically.
