[petsc-users] PT-SCOTCH not available
Satish Balay
balay at mcs.anl.gov
Thu Oct 25 19:40:41 CDT 2012
do 'rm -rf externalpackages linux-gnu-c-debug' and retry configure.
If you still have issues - send configure.log to petsc-maint
Satish
On Fri, 26 Oct 2012, Jinquan Zhong wrote:
> The log file says:
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
> Downloaded ptscotch could not be used. Please check install in /data/Users/jzhong/petsc-3.3-p3-option4p2/linux-gnu-c-debug
> File "./config/configure.py", line 311, in petsc_configure
> framework.configure(out = sys.stdout)
> File "/data/Users/jzhong/petsc-3.3-p3-option4p2/config/BuildSystem/config/framework.py", line 933, in configure
> child.configure()
> File "/data/Users/jzhong/petsc-3.3-p3-option4p2/config/BuildSystem/config/package.py", line 526, in configure
> self.executeTest(self.configureLibrary)
> File "/data/Users/jzhong/petsc-3.3-p3-option4p2/config/BuildSystem/config/base.py", line 115, in executeTest
> ret = apply(test, args,kargs)
> File "/data/Users/jzhong/petsc-3.3-p3-option4p2/config/BuildSystem/config/package.py", line 453, in configureLibrary
> for location, directory, lib, incl in self.generateGuesses():
> File "/data/Users/jzhong/petsc-3.3-p3-option4p2/config/BuildSystem/config/package.py", line 235, in generateGuesses
> raise RuntimeError('Downloaded '+self.package+' could not be used. Please check install in '+d+'\n')
> Jinquan
> -----Original Message-----
> From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Jinquan Zhong
> Sent: Thursday, October 25, 2012 5:31 PM
> To: 'PETSc users list'
> Subject: Re: [petsc-users] PT-SCOTCH not available
> I got this
> TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:133)
> Not quite working yet.
> Jinquan
> From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Satish Balay
> Sent: Thursday, October 25, 2012 5:14 PM
> To: PETSc users list
> try using the attached patch and see if it works.
> patch -Np1 < mumps-ptscotch.py
> rm -rf externalpackages/scotch*
> ./configure ....
> Satish
> On Thu, 25 Oct 2012, Jinquan Zhong wrote:
> > Yes, I used
> > ./configure \
> > --with-blas-lib=/data/Users/jzhong/scalapack-2.0.1/lib/librefblas.a \
> > --with-lapack-lib=/data/Users/jzhong/scalapack-2.0.1/lib/libreflapack.
> > a \ --download-blacs --download-scalapack \
> > --with-mpi-dir=/data/Users/jzhong/mpich2 \
> > --with-mpiexec=/data/Users/jzhong/mpich2/bin/mpiexec \
> > --with-cmake=/data/Users/jzhong/CMAKE/cmake-2.8.8/bin/cmake \
> > --with-scalar-type=complex --with-precision=double --with-clanguage=c
> > --with-fortran-kernels=generic \
> > --with-ptscotch=1 --download-ptscotch=yes \ --download-mumps
> > --download-superlu_dist \ --download-parmetis --download-metis
> > --with-fortran-interfaces
> > Jinquan
> > Sent: Thursday, October 25, 2012 3:49 PM
> > do you also have parmetis installed?
> > Satish
> > > Dear PETSc folks,
> > > I am trying to install PT-SCOTCH as the external package for PETSc. I used
> > > --with-ptscotch=1
> > > to install PETSc. No complains.
> > > But when I tried to use PT-SCOTCH, here is the message I got ...
> > > ZMUMPS 4.10.0
> > > L U Solver for unsymmetric matrices
> > > Type of parallelism: Working host
> > > ****** ANALYSIS STEP ********
> > > PT-SCOTCH not available.
> > > Aborting.
> > > Any idea to make it work?
> > > Thanks,
> > > Jinquan
