[petsc-users] PT-SCOTCH not available
Jinquan Zhong
jzhong at scsolutions.com
Thu Oct 25 19:32:25 CDT 2012
The log file says:
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
Downloaded ptscotch could not be used. Please check install in /data/Users/jzhong/petsc-3.3-p3-option4p2/linux-gnu-c-debug
File "./config/configure.py", line 311, in petsc_configure
framework.configure(out = sys.stdout)
File "/data/Users/jzhong/petsc-3.3-p3-option4p2/config/BuildSystem/config/framework.py", line 933, in configure
child.configure()
File "/data/Users/jzhong/petsc-3.3-p3-option4p2/config/BuildSystem/config/package.py", line 526, in configure
self.executeTest(self.configureLibrary)
File "/data/Users/jzhong/petsc-3.3-p3-option4p2/config/BuildSystem/config/base.py", line 115, in executeTest
ret = apply(test, args,kargs)
File "/data/Users/jzhong/petsc-3.3-p3-option4p2/config/BuildSystem/config/package.py", line 453, in configureLibrary
for location, directory, lib, incl in self.generateGuesses():
File "/data/Users/jzhong/petsc-3.3-p3-option4p2/config/BuildSystem/config/package.py", line 235, in generateGuesses
raise RuntimeError('Downloaded '+self.package+' could not be used. Please check install in '+d+'\n')
Jinquan
-----Original Message-----
From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Jinquan Zhong
Sent: Thursday, October 25, 2012 5:31 PM
To: 'PETSc users list'
Subject: Re: [petsc-users] PT-SCOTCH not available
I got this
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:133)
Not quite working yet.
Jinquan
From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Satish Balay
Sent: Thursday, October 25, 2012 5:14 PM
To: PETSc users list
try using the attached patch and see if it works.
patch -Np1 < mumps-ptscotch.py
rm -rf externalpackages/scotch*
./configure ....
Satish
On Thu, 25 Oct 2012, Jinquan Zhong wrote:
> Yes, I used
> ./configure \
> --with-blas-lib=/data/Users/jzhong/scalapack-2.0.1/lib/librefblas.a \
> --with-lapack-lib=/data/Users/jzhong/scalapack-2.0.1/lib/libreflapack.
> a \ --download-blacs --download-scalapack \
> --with-mpi-dir=/data/Users/jzhong/mpich2 \
> --with-mpiexec=/data/Users/jzhong/mpich2/bin/mpiexec \
> --with-cmake=/data/Users/jzhong/CMAKE/cmake-2.8.8/bin/cmake \
> --with-scalar-type=complex --with-precision=double --with-clanguage=c
> --with-fortran-kernels=generic \
> --with-ptscotch=1 --download-ptscotch=yes \ --download-mumps
> --download-superlu_dist \ --download-parmetis --download-metis
> --with-fortran-interfaces
> Jinquan
> Sent: Thursday, October 25, 2012 3:49 PM
> do you also have parmetis installed?
> Satish
> > Dear PETSc folks,
> > I am trying to install PT-SCOTCH as the external package for PETSc. I used
> > --with-ptscotch=1
> > to install PETSc. No complains.
> > But when I tried to use PT-SCOTCH, here is the message I got ...
> > ZMUMPS 4.10.0
> > L U Solver for unsymmetric matrices
> > Type of parallelism: Working host
> > ****** ANALYSIS STEP ********
> > PT-SCOTCH not available.
> > Aborting.
> > Any idea to make it work?
> > Thanks,
> > Jinquan
