[petsc-users] Threaded Petsc
Subramanya G subramanya.g at gmail.com
Tue Oct 16 11:30:13 CDT 2012
Hi
Thanks very much for the info. Does this mean that all the internal
vector and matrix operations are multi-threaded?  If I have a
sequential code with PETSC_THREADCOMM_ACTIVE  set to on will it be
faster than a purely sequential code, especially for the KSP routines
, which I guess depend on AXPY type operations.
Thanks
Subramanya G Sadasiva,
Graduate Research Assistant,
Hierarchical Design and Characterization Laboratory,
School of Mechanical Engineering,
Purdue University.
"The art of structure is where to put the holes"
Robert Le Ricolais, 1894-1977
On Tue, Oct 16, 2012 at 9:10 AM, Shri <abhyshr at mcs.anl.gov> wrote:
> Subramanya,
>    Threads can be used in petsc-dev via the thread communicator object "threadcomm". PETSc currently has three thread communicators available:
> i) nothread - This is the default and does not use any threads.
> ii) pthread - This one uses native lockfree thread pool implementation using POSIX threads
> iii) OpenMP - OpenMP manages the threadpool.
> Configuration:
> Configure with --with-pthreadclasses=1 and/or --with-openmp=1 to use pthreads or OpenMP.
> **Note: If you are planning to use the OpenMP thread communicator only on MacOS then you'll need to additionally configure with --with-pthreadclasses=1. This is because OpenMP threadprivate variables are not available on MacOS and we use pthread_get/setspecific() calls for thread private variables instead (which are only available when configured with --with-pthreadclasses).
> Usage:
> cd src/sys/objects/threadcomm/examples/tutorials
> make ex1
> ./ex3 -threadcomm_type <nothread,openmp,pthread> -threadcomm_nthreads < # of threads>
> Use -h to get the list of available options with threadcomm.
> Examples:
> There are several examples in src/sys/threadcomm/examples/tutorials/ .Take a look at these to see how the threadcomm interface is used.
> We currently have PETSc's vector (seq and mpi) operations threaded but haven't made it open yet. These operations are guarded by the flag PETSC_THREADCOMM_ACTIVE. In order to use the threaded vector operations define PETSC_THREADCOMM_ACTIVE in $PETSC_DIR/$PETSC_ARCH/include/petscconf.h
> I'll update the docs on the website.
> Shri
> On Oct 15, 2012, at 11:59 PM, Barry Smith wrote:
>>   Ok, thanks. Shri will update them with the latest info tomorrow. Sorry for the confusion. (they are easier :-)).
>>    Barry
>> On Oct 15, 2012, at 11:57 PM, Subramanya G <subramanya.g at gmail.com> wrote:
>>> Hi Barry,
>>> These are the instructions that I found.
>>> Thanks.
>>> http://www.mcs.anl.gov/petsc/petsc-dev/docs/installation.html#threads
>>> Purdue University.
>>> On Mon, Oct 15, 2012 at 9:49 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> On Oct 15, 2012, at 11:35 PM, Subramanya G <subramanya.g at gmail.com> wrote:
>>>>> Hi,
>>>>> When I try to run the example suggested with -dm_vector_type  pthread
>>>>> , I get  a unknown vector type error.
>>>>  That documentation is out of date. Please let us know where you saw this "suggestion" so we can remove it.
>>>>  Barry
>>>>> Unknown vector type: pthread!
>>>>> Here are my configure lines
>>>>> Configure options --download-mpich --download-f-blas-lapack
>>>>> --download-scientificpython --download-fiat --download-generator
>>>>> --download-chaco --download-triangle --with-shared-libraries
>>>>> --download-metis --download-parmetis --download-umfpack
>>>>> --download-hypre --sharedLibraryFlags=-fPIC -shared
>>>>> I am using the latest Petsc Dev version.
>>>>> Does anybody have any idea what might be wrong? It built without any
>>>>> issues. Do I need to do anything else when I configure.
>>>>> Purdue University.
>>>>> On Mon, Oct 15, 2012 at 5:44 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>>> On Oct 15, 2012, at 7:38 PM, Subramanya G <subramanya.g at gmail.com> wrote:
>>>>>>> Hi ,
>>>>>>> I need iterative solvers for some of my code and I was planning to use
>>>>>>> petsc for it. Owing to the fact that some other parts of my code
>>>>>>> aren't parallelizable, I can't use petsc in parallel. However, I see
>>>>>>> that petsc can do threads now.. I have a small question about this .
>>>>>>> Does this allow me to assemble a matrix in the main thread. and then
>>>>>>> when solve is called will petsc take care of using multiple threads?
>>>>>> Yes
>>>>>>> Will this give me any speed ups?
>>>>>> Yes
>>>>>> You need to use petsc-dev for this functionality and let us know if you have difficulties.
>>>>>> Barry
>>>>>>> Thanks/
>>>>>>> Purdue University.
