[petsc-users] Threaded Petsc
Shri abhyshr at mcs.anl.gov
Tue Oct 16 11:10:03 CDT 2012
Subramanya,
   Threads can be used in petsc-dev via the thread communicator object "threadcomm". PETSc currently has three thread communicators available:
i) nothread - This is the default and does not use any threads.
ii) pthread - This one uses native lockfree thread pool implementation using POSIX threads
iii) OpenMP - OpenMP manages the threadpool.
Configuration:
Configure with --with-pthreadclasses=1 and/or --with-openmp=1 to use pthreads or OpenMP.
**Note: If you are planning to use the OpenMP thread communicator only on MacOS then you'll need to additionally configure with --with-pthreadclasses=1. This is because OpenMP threadprivate variables are not available on MacOS and we use pthread_get/setspecific() calls for thread private variables instead (which are only available when configured with --with-pthreadclasses).
Usage:
cd src/sys/objects/threadcomm/examples/tutorials
make ex1
./ex3 -threadcomm_type <nothread,openmp,pthread> -threadcomm_nthreads < # of threads>
Use -h to get the list of available options with threadcomm.
Examples:
There are several examples in src/sys/threadcomm/examples/tutorials/ .Take a look at these to see how the threadcomm interface is used.
We currently have PETSc's vector (seq and mpi) operations threaded but haven't made it open yet. These operations are guarded by the flag PETSC_THREADCOMM_ACTIVE. In order to use the threaded vector operations define PETSC_THREADCOMM_ACTIVE in $PETSC_DIR/$PETSC_ARCH/include/petscconf.h
I'll update the docs on the website.
Shri
On Oct 15, 2012, at 11:59 PM, Barry Smith wrote:
>   Ok, thanks. Shri will update them with the latest info tomorrow. Sorry for the confusion. (they are easier :-)).
>    Barry
> On Oct 15, 2012, at 11:57 PM, Subramanya G <subramanya.g at gmail.com> wrote:
>> Hi Barry,
>> These are the instructions that I found.
>> Thanks.
>> http://www.mcs.anl.gov/petsc/petsc-dev/docs/installation.html#threads
>> Subramanya G Sadasiva,
>> Graduate Research Assistant,
>> Hierarchical Design and Characterization Laboratory,
>> School of Mechanical Engineering,
>> Purdue University.
>> "The art of structure is where to put the holes"
>> Robert Le Ricolais, 1894-1977
>> On Mon, Oct 15, 2012 at 9:49 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> On Oct 15, 2012, at 11:35 PM, Subramanya G <subramanya.g at gmail.com> wrote:
>>>> Hi,
>>>> When I try to run the example suggested with -dm_vector_type  pthread
>>>> , I get  a unknown vector type error.
>>>  That documentation is out of date. Please let us know where you saw this "suggestion" so we can remove it.
>>>  Barry
>>>> Unknown vector type: pthread!
>>>> Here are my configure lines
>>>> Configure options --download-mpich --download-f-blas-lapack
>>>> --download-scientificpython --download-fiat --download-generator
>>>> --download-chaco --download-triangle --with-shared-libraries
>>>> --download-metis --download-parmetis --download-umfpack
>>>> --download-hypre --sharedLibraryFlags=-fPIC -shared
>>>> I am using the latest Petsc Dev version.
>>>> Does anybody have any idea what might be wrong? It built without any
>>>> issues. Do I need to do anything else when I configure.
>>>> Purdue University.
>>>> On Mon, Oct 15, 2012 at 5:44 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>> On Oct 15, 2012, at 7:38 PM, Subramanya G <subramanya.g at gmail.com> wrote:
>>>>>> Hi ,
>>>>>> I need iterative solvers for some of my code and I was planning to use
>>>>>> petsc for it. Owing to the fact that some other parts of my code
>>>>>> aren't parallelizable, I can't use petsc in parallel. However, I see
>>>>>> that petsc can do threads now.. I have a small question about this .
>>>>>> Does this allow me to assemble a matrix in the main thread. and then
>>>>>> when solve is called will petsc take care of using multiple threads?
>>>>> Yes
>>>>>> Will this give me any speed ups?
>>>>> Yes
>>>>> You need to use petsc-dev for this functionality and let us know if you have difficulties.
>>>>> Barry
>>>>>> Thanks/
>>>>>> Purdue University.
