[petsc-users] Enquiry regarding log summary results
TAY wee-beng
zonexo at gmail.com
Sun Oct 7 16:45:04 CDT 2012
I have attached 3 results using 12,24 and 32 processors. I am using a
completely different clusters and I'm testing if it's the cluster
configuration problems. It's seems that VecScatterEnd does not scale
well from 12 to 24 to 32. Does these results show that there's problems
with the partition still? My partition is clustered closely at the
center, I'm wondering if this has a great effect on scaling...
Tks!
Yours sincerely,
TAY wee-beng
On 6/10/2012 11:54 PM, Jed Brown wrote:
> On Sat, Oct 6, 2012 at 4:51 PM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
> This line happens rather late in the assembly, so it is not the
> main matrix which I've created, right? And hence this doesn't matter?
> Look at all the lines talking about mallocs. If the first assembly
> uses lots of mallocs, the first assembly will be slow.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121007/5caa289e/attachment-0001.html>
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./a.out on a petsc-3.3-dev_atlas6_rel named atlas6-c39 with 12 processors, by g0306332 Mon Oct 8 03:58:56 2012
Using Petsc Development HG revision: 0b92fc173218fc24fd69e1ee041f811d50d4766c HG Date: Fri Oct 05 15:20:44 2012 -0500
Max Max/Min Avg Total
mv: cannot move `/var/tmp/uvwp12.plt' to `/home/wtay/Results/8/': No such file or directory
Time (sec): 1.201e+03 1.00258 1.199e+03
Objects: 5.160e+02 1.00000 5.160e+02
Flops: 2.977e+11 1.11376 2.739e+11 3.287e+12
Flops/sec: 2.478e+08 1.11115 2.285e+08 2.742e+09
MPI Messages: 5.879e+04 2.96007 4.346e+04 5.215e+05
MPI Message Lengths: 4.194e+09 2.02856 8.822e+04 4.601e+10
MPI Reductions: 6.296e+03 1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
e.g., VecAXPY() for real vectors of length N --> 2N flops
and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages: ----- Time ------ ----- Flops ----- --- Messages --- -- Message Lengths -- -- Reductions --
Avg %Total Avg %Total counts %Total Avg %Total counts %Total
0: Main Stage: 1.3933e+02 11.6% 0.0000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0% 2.000e+01 0.3%
1: poisson_eqn: 9.8694e+02 82.3% 3.1635e+12 96.3% 5.206e+05 99.8% 8.705e+04 98.7% 5.977e+03 94.9%
2: momentum_eqn: 7.2420e+01 6.0% 1.2324e+11 3.7% 8.800e+02 0.2% 1.170e+03 1.3% 2.980e+02 4.7%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
Count: number of times phase was executed
Time and Flops: Max - maximum over all processors
Ratio - ratio of maximum to minimum over all processors
Mess: number of messages sent
Avg. len: average message length
Reduct: number of global reductions
Global: entire computation
Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
%T - percent time in this phase %f - percent flops in this phase
%M - percent messages in this phase %L - percent message lengths in this phase
%R - percent reductions in this phase
Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event Count Time (sec) Flops --- Global --- --- Stage --- Total
Max Ratio Max Ratio Max Ratio Mess Avg len Reduct %T %f %M %L %R %T %f %M %L %R Mflop/s
--- Event Stage 0: Main Stage
--- Event Stage 1: poisson_eqn
MatMult 21340 1.0 5.8555e+02 1.1 1.91e+11 1.2 4.0e+05 1.1e+05 0.0e+00 47 62 77 93 0 58 65 77 94 0 3503
MatMultAdd 3280 1.0 4.0142e+01 1.2 1.26e+10 1.2 5.7e+04 1.9e+04 0.0e+00 3 4 11 2 0 4 4 11 2 0 3205
MatMultTranspose 3280 1.0 4.4090e+01 1.3 1.26e+10 1.2 5.7e+04 1.9e+04 0.0e+00 3 4 11 2 0 4 4 11 2 0 2918
MatSolve 1640 0.0 5.8434e-03 0.0 1.42e+06 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 243
MatLUFactorSym 1 1.0 3.1948e-05 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatLUFactorNum 1 1.0 1.7881e-05 6.2 5.53e+03 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 309
MatConvert 4 1.0 2.3882e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatScale 12 1.0 2.8265e-01 1.1 5.26e+07 1.2 7.8e+01 1.0e+05 0.0e+00 0 0 0 0 0 0 0 0 0 0 1960
MatAssemblyBegin 69 1.0 1.6842e+00 2.8 0.00e+00 0.0 2.3e+02 1.8e+04 7.4e+01 0 0 0 0 1 0 0 0 0 1 0
MatAssemblyEnd 69 1.0 1.8641e+00 1.0 0.00e+00 0.0 1.0e+03 1.6e+04 2.0e+02 0 0 0 0 3 0 0 0 0 3 0
MatGetRow 3544348 1.0 4.4062e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetRowIJ 1 0.0 6.9141e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 0.0 4.5061e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.7e-01 0 0 0 0 0 0 0 0 0 0 0
MatCoarsen 4 1.0 6.5285e-01 1.2 0.00e+00 0.0 4.3e+02 1.4e+05 9.2e+01 0 0 0 0 1 0 0 0 0 2 0
MatAXPY 4 1.0 6.9771e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatMatMult 4 1.0 1.3333e+00 1.0 3.72e+07 1.2 4.9e+02 4.9e+04 9.6e+01 0 0 0 0 2 0 0 0 0 2 298
MatMatMultSym 4 1.0 1.0190e+00 1.0 0.00e+00 0.0 4.1e+02 3.9e+04 8.8e+01 0 0 0 0 1 0 0 0 0 1 0
MatMatMultNum 4 1.0 3.1801e-01 1.0 3.72e+07 1.2 7.8e+01 1.0e+05 8.0e+00 0 0 0 0 0 0 0 0 0 0 1249
MatPtAP 4 1.0 4.5583e+00 1.0 1.16e+09 1.8 8.4e+02 1.1e+05 1.1e+02 0 0 0 0 2 0 0 0 0 2 1881
MatPtAPSymbolic 4 1.0 2.8222e+00 1.0 0.00e+00 0.0 7.5e+02 9.3e+04 1.0e+02 0 0 0 0 2 0 0 0 0 2 0
MatPtAPNumeric 4 1.0 1.7362e+00 1.0 1.16e+09 1.8 8.9e+01 2.7e+05 8.0e+00 0 0 0 0 0 0 0 0 0 0 4939
MatTrnMatMult 4 1.0 1.2843e+01 1.0 2.04e+09 1.9 4.7e+02 6.6e+05 1.2e+02 1 1 0 1 2 1 1 0 1 2 1775
MatGetLocalMat 20 1.0 7.1283e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 2.4e+01 0 0 0 0 0 0 0 0 0 0 0
MatGetBrAoCol 12 1.0 8.6687e-02 1.6 0.00e+00 0.0 5.5e+02 1.4e+05 1.6e+01 0 0 0 0 0 0 0 0 0 0 0
MatGetSymTrans 8 1.0 9.0438e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPGMRESOrthog 860 1.0 8.2049e-01 1.1 3.90e+08 1.0 0.0e+00 0.0e+00 8.6e+02 0 0 0 0 14 0 0 0 0 14 5608
KSPSetUp 11 1.0 1.3758e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01 0 0 0 0 0 0 0 0 0 0 0
KSPSolve 20 1.0 9.8386e+02 1.0 2.88e+11 1.1 5.2e+05 8.7e+04 5.8e+03 82 96100 99 93 100100100100 98 3215
VecDot 800 1.0 1.2949e+01 2.7 2.57e+09 1.0 0.0e+00 0.0e+00 8.0e+02 1 1 0 0 13 1 1 0 0 13 2355
VecDotNorm2 400 1.0 1.3116e+01 2.2 5.14e+09 1.0 0.0e+00 0.0e+00 1.2e+03 1 2 0 0 19 1 2 0 0 20 4650
VecMDot 860 1.0 4.3056e-01 1.2 1.95e+08 1.0 0.0e+00 0.0e+00 8.6e+02 0 0 0 0 14 0 0 0 0 14 5343
VecNorm 2104 1.0 1.0177e+01 5.3 1.39e+09 1.0 0.0e+00 0.0e+00 2.1e+03 0 1 0 0 33 0 1 0 0 35 1618
VecScale 14804 1.0 2.2892e+01 1.1 5.83e+09 1.0 0.0e+00 0.0e+00 0.0e+00 2 2 0 0 0 2 2 0 0 0 3007
VecCopy 4144 1.0 7.4420e+00 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
VecSet 14075 1.0 6.1308e+00 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
VecAXPY 27064 1.0 7.9051e+01 1.2 2.33e+10 1.0 0.0e+00 0.0e+00 0.0e+00 6 8 0 0 0 8 9 0 0 0 3472
VecAYPX 26240 1.0 7.8797e+01 1.1 1.45e+10 1.0 0.0e+00 0.0e+00 0.0e+00 6 5 0 0 0 8 5 0 0 0 2176
VecAXPBYCZ 800 1.0 1.2601e+01 1.0 5.14e+09 1.0 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 1 2 0 0 0 4840
VecWAXPY 800 1.0 1.2598e+01 1.0 2.57e+09 1.0 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 1 1 0 0 0 2420
VecMAXPY 1684 1.0 4.7353e-01 1.0 2.30e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 5742
VecAssemblyBegin 87 1.0 4.7785e-01 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 2.6e+02 0 0 0 0 4 0 0 0 0 4 0
VecAssemblyEnd 87 1.0 9.9659e-05 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecPointwiseMult 19724 1.0 8.5318e+01 1.1 8.74e+09 1.0 0.0e+00 0.0e+00 0.0e+00 7 3 0 0 0 8 3 0 0 0 1209
VecScatterBegin 27955 1.0 3.7788e+00 2.3 0.00e+00 0.0 5.2e+05 8.7e+04 0.0e+00 0 0 99 98 0 0 0100 99 0 0
VecScatterEnd 27955 1.0 6.0687e+01 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 4 0 0 0 0 4 0 0 0 0 0
VecSetRandom 4 1.0 2.6621e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecNormalize 1684 1.0 8.1183e+0052.0 5.86e+07 1.0 0.0e+00 0.0e+00 1.7e+03 0 0 0 0 27 0 0 0 0 28 85
PCSetUp 2 1.0 2.7046e+01 1.0 3.60e+09 1.1 4.4e+03 1.6e+05 9.6e+02 2 1 1 1 15 3 1 1 2 16 1555
PCSetUpOnBlocks 820 1.0 6.9976e-04 1.3 5.53e+03 0.0 0.0e+00 0.0e+00 5.0e+00 0 0 0 0 0 0 0 0 0 0 8
PCApply 820 1.0 8.5955e+02 1.0 2.52e+11 1.1 5.0e+05 8.1e+04 2.5e+03 71 83 96 88 39 86 86 96 89 41 3171
PCGAMGgraph_AGG 4 1.0 2.9757e+00 1.0 3.72e+07 1.2 2.3e+02 5.1e+04 7.6e+01 0 0 0 0 1 0 0 0 0 1 133
PCGAMGcoarse_AGG 4 1.0 1.4145e+01 1.0 2.04e+09 1.9 1.3e+03 3.4e+05 2.9e+02 1 1 0 1 5 1 1 0 1 5 1612
PCGAMGProl_AGG 4 1.0 1.0395e+00 1.0 0.00e+00 0.0 5.5e+02 6.4e+04 1.1e+02 0 0 0 0 2 0 0 0 0 2 0
PCGAMGPOpt_AGG 4 1.0 4.1134e+00 1.0 9.11e+08 1.1 1.3e+03 8.0e+04 2.1e+02 0 0 0 0 3 0 0 0 0 4 2503
--- Event Stage 2: momentum_eqn
MatMult 38 1.0 8.5567e+00 1.0 2.35e+09 1.0 8.4e+02 7.2e+05 0.0e+00 1 1 0 1 0 12 23 95 99 0 3260
MatSolve 57 1.0 1.3324e+01 1.1 3.51e+09 1.0 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 18 34 0 0 0 3123
MatLUFactorNum 19 1.0 1.3298e+01 1.1 1.97e+09 1.0 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 18 19 0 0 0 1753
MatILUFactorSym 1 1.0 5.8045e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00 0 0 0 0 0 1 0 0 0 0 0
MatAssemblyBegin 19 1.0 3.3103e+0051.0 0.00e+00 0.0 0.0e+00 0.0e+00 3.8e+01 0 0 0 0 1 3 0 0 0 13 0
MatAssemblyEnd 19 1.0 4.1241e+00 1.0 0.00e+00 0.0 4.4e+01 1.8e+05 8.0e+00 0 0 0 0 0 6 0 5 1 3 0
MatGetRowIJ 1 1.0 1.9073e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 1.0 5.7246e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 0 0 0 0 1 0
KSPSetUp 38 1.0 1.5740e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPSolve 19 1.0 4.4298e+01 1.0 1.04e+10 1.0 8.4e+02 7.2e+05 1.4e+02 4 4 0 1 2 61100 95 99 46 2782
VecDot 38 1.0 1.3129e+00 1.6 3.66e+08 1.0 0.0e+00 0.0e+00 3.8e+01 0 0 0 0 1 1 4 0 0 13 3310
VecDotNorm2 19 1.0 1.3210e+00 1.6 7.32e+08 1.0 0.0e+00 0.0e+00 5.7e+01 0 0 0 0 1 1 7 0 0 19 6579
VecNorm 38 1.0 1.5438e+00 4.7 3.66e+08 1.0 0.0e+00 0.0e+00 3.8e+01 0 0 0 0 1 1 4 0 0 13 2815
VecCopy 38 1.0 8.6146e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
VecSet 115 1.0 2.0613e+00 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 3 0 0 0 0 0
VecAXPBYCZ 38 1.0 1.8039e+00 1.0 7.32e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 7 0 0 0 4818
VecWAXPY 38 1.0 1.8099e+00 1.0 3.66e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 4 0 0 0 2401
VecAssemblyBegin 38 1.0 1.0454e-0116.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.1e+02 0 0 0 0 2 0 0 0 0 38 0
VecAssemblyEnd 38 1.0 4.7684e-05 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecScatterBegin 38 1.0 7.1190e-02 2.4 0.00e+00 0.0 8.4e+02 7.2e+05 0.0e+00 0 0 0 1 0 0 0 95 99 0 0
VecScatterEnd 38 1.0 2.8875e-01 2.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
PCSetUp 38 1.0 1.3929e+01 1.1 1.97e+09 1.0 0.0e+00 0.0e+00 5.0e+00 1 1 0 0 0 19 19 0 0 2 1674
PCSetUpOnBlocks 19 1.0 1.3929e+01 1.1 1.97e+09 1.0 0.0e+00 0.0e+00 3.0e+00 1 1 0 0 0 19 19 0 0 1 1674
PCApply 57 1.0 1.4274e+01 1.1 3.51e+09 1.0 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 19 34 0 0 0 2915
Memory usage is given in bytes:
Object Type Creations Destructions Memory Descendants' Mem.
Reports information only for process 0.
Matrix 6 48 2093863816 0
Krylov Solver 2 9 27392 0
Vector 4 63 485882816 0
Vector Scatter 0 10 10360 0
Index Set 0 10 19278416 0
Preconditioner 0 9 8868 0
Viewer 1 0 0 0
Matrix 117 76 1488820380 0
Matrix Coarsen 4 4 2448 0
Krylov Solver 10 4 120512 0
Vector 225 175 387306216 0
Vector Scatter 31 22 22792 0
Index Set 81 74 807916 0
Preconditioner 11 4 3424 0
PetscRandom 4 4 2432 0
Matrix 1 0 0 0
Krylov Solver 1 0 0 0
Vector 10 1 1496 0
Vector Scatter 1 0 0 0
Index Set 5 2 361680 0
Preconditioner 2 0 0 0
Average time to get PetscTime(): 9.53674e-08
Average time for MPI_Barrier(): 9.20296e-06
Average time for zero size MPI_Send(): 2.16564e-06
#PETSc Option Table entries:
-log_summary
-poisson_pc_gamg_agg_nsmooths 1
-poisson_pc_type gamg
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure run at: Sun Oct 7 16:51:24 2012
Configure options: --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-mpi-dir=/app1/mvapich2/current/ --with-blas-lapack-dir=/app1/intel/mkl/lib/intel64/ --with-batch=1 --with-debugging=0 --download-hypre=1 --prefix=/home/svu/g0306332/lib/petsc-3.3-dev_atlas6_rel --known-mpi-shared-libraries=0
Libraries compiled on Sun Oct 7 16:51:24 2012 on atlas6-c01
Machine characteristics: Linux-2.6.18-274.7.1.el5-x86_64-with-redhat-5.8-Final
Using PETSc directory: /home/svu/g0306332/codes/petsc-dev
Using PETSc arch: petsc-3.3-dev_atlas6_rel
Using C compiler: /app1/mvapich2/current/bin/mpicc -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /app1/mvapich2/current/bin/mpif90 -O3 ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/home/svu/g0306332/codes/petsc-dev/petsc-3.3-dev_atlas6_rel/include -I/home/svu/g0306332/codes/petsc-dev/include -I/home/svu/g0306332/codes/petsc-dev/include -I/home/svu/g0306332/codes/petsc-dev/petsc-3.3-dev_atlas6_rel/include -I/app1/mvapich2/current/include -I/app1/mvapich2/1.4/include
Using C linker: /app1/mvapich2/current/bin/mpicc
Using Fortran linker: /app1/mvapich2/current/bin/mpif90
Using libraries: -Wl,-rpath,/home/svu/g0306332/codes/petsc-dev/petsc-3.3-dev_atlas6_rel/lib -L/home/svu/g0306332/codes/petsc-dev/petsc-3.3-dev_atlas6_rel/lib -lpetsc -lX11 -Wl,-rpath,/home/svu/g0306332/codes/petsc-dev/petsc-3.3-dev_atlas6_rel/lib -L/home/svu/g0306332/codes/petsc-dev/petsc-3.3-dev_atlas6_rel/lib -lHYPRE -L/app1/mvapich2/1.4/lib -L/nfs/app1/intel_2011/composer_xe_2011_sp1.6.233/compiler/lib/intel64 -L/app1/intel_2011/composer_xe_2011_sp1.6.233/compiler/lib/intel64 -L/app1/intel_2011/composer_xe_2011_sp1.6.233/ipp/lib/intel64 -L/app1/intel_2011/composer_xe_2011_sp1.6.233/mkl/lib/intel64 -L/app1/intel_2011/composer_xe_2011_sp1.6.233/tbb/lib/intel64/cc4.1.0_libc2.4_kernel2.6.16.21 -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2 -lmpichcxx -lstdc++ -lpthread -Wl,-rpath,/app1/intel/mkl/lib/intel64 -L/app1/intel/mkl/lib/intel64 -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -liomp5 -lpthread -lmpichf90 -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lirc_s -lm -lmpichcxx -lstdc++ -lmpichcxx -lstdc++ -ldl -lmpich -lpthread -lrdmacm -libverbs -libumad -lrt -lgcc_s -ldl
Job /app1/common/lsf7/7.0/linux2.6-glibc2.3-x86_64/bin/mvapich_wrapper ./a.out -poisson_pc_gamg_agg_nsmooths 1 -poisson_pc_type gamg -log_summary
TID HOST_NAME COMMAND_LINE STATUS TERMINATION_TIME
00000 atlas6-c39 ./a.out -poisson Done 10/08/2012 03:58:59
00001 atlas6-c39 ./a.out -poisson Done 10/08/2012 03:58:59
00002 atlas6-c39 ./a.out -poisson Done 10/08/2012 03:58:59
00003 atlas6-c39 ./a.out -poisson Done 10/08/2012 03:58:59
00004 atlas6-c39 ./a.out -poisson Done 10/08/2012 03:58:59
00005 atlas6-c39 ./a.out -poisson Done 10/08/2012 03:58:59
00006 atlas6-c39 ./a.out -poisson Done 10/08/2012 03:58:59
00007 atlas6-c39 ./a.out -poisson Done 10/08/2012 03:58:59
00008 atlas6-c39 ./a.out -poisson Done 10/08/2012 03:58:59
00009 atlas6-c39 ./a.out -poisson Done 10/08/2012 03:58:59
00010 atlas6-c39 ./a.out -poisson Done 10/08/2012 03:58:59
00011 atlas6-c39 ./a.out -poisson Done 10/08/2012 03:58:59
*** WIDEN YOUR WINDOW TO 120 CHARACTERS. Use 'enscript -r -fCourier9' to print this document ***
./a.out on a petsc-3.3-dev_atlas6_rel named atlas6-c14 with 24 processors, by g0306332 Mon Oct 8 04:17:33 2012
mv: cannot move `/var/tmp/uvwp24.plt' to `/home/wtay/Results/8/': No such file or directory
Time (sec): 5.824e+02 1.00339 5.807e+02
Flops: 1.380e+11 1.23808 1.148e+11 2.756e+12
Flops/sec: 2.370e+08 1.23418 1.978e+08 4.746e+09
MPI Messages: 6.066e+04 3.66281 3.892e+04 9.341e+05
MPI Message Lengths: 3.500e+09 2.02046 8.586e+04 8.021e+10
MPI Reductions: 5.548e+03 1.00000
0: Main Stage: 1.1861e+02 20.4% 0.0000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0% 2.000e+01 0.4%
1: poisson_eqn: 4.2596e+02 73.4% 2.6333e+12 95.5% 9.323e+05 99.8% 8.450e+04 98.4% 5.229e+03 94.3%
2: momentum_eqn: 3.6084e+01 6.2% 1.2276e+11 4.5% 1.840e+03 0.2% 1.366e+03 1.6% 2.980e+02 5.4%
Phase summary info:
MatMult 17700 1.0 2.6405e+02 1.2 9.02e+10 1.3 7.1e+05 1.0e+05 0.0e+00 42 62 76 92 0 58 65 76 94 0 6455
MatMultAdd 2720 1.0 1.9278e+01 1.5 6.25e+09 1.5 1.1e+05 1.7e+04 0.0e+00 3 4 11 2 0 3 4 11 2 0 5553
MatMultTranspose 2720 1.0 2.1702e+01 1.5 6.25e+09 1.5 1.1e+05 1.7e+04 0.0e+00 3 4 11 2 0 4 4 11 2 0 4933
MatSolve 1360 0.0 4.2832e-03 0.0 1.30e+06 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 303
MatLUFactorSym 1 1.0 3.8147e-05 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatLUFactorNum 1 1.0 2.1935e-05 7.7 6.48e+03 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 295
MatConvert 4 1.0 1.2682e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatScale 12 1.0 1.4481e-01 1.1 3.05e+07 1.4 1.7e+02 9.8e+04 0.0e+00 0 0 0 0 0 0 0 0 0 0 3835
MatAssemblyBegin 69 1.0 2.6819e+00 2.5 0.00e+00 0.0 5.3e+02 1.6e+04 7.4e+01 0 0 0 0 1 0 0 0 0 1 0
MatAssemblyEnd 69 1.0 1.0519e+00 1.0 0.00e+00 0.0 2.6e+03 1.3e+04 2.0e+02 0 0 0 0 4 0 0 0 0 4 0
MatGetRow 1821330 1.1 2.2507e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetRowIJ 1 0.0 8.1062e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 0.0 5.1022e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 8.3e-02 0 0 0 0 0 0 0 0 0 0 0
MatCoarsen 4 1.0 3.9578e-01 1.3 0.00e+00 0.0 3.1e+03 4.7e+04 1.8e+02 0 0 0 0 3 0 0 0 0 4 0
MatAXPY 4 1.0 3.4627e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatMatMult 4 1.0 7.5009e-01 1.0 2.13e+07 1.3 1.1e+03 4.4e+04 9.6e+01 0 0 0 0 2 0 0 0 0 2 530
MatMatMultSym 4 1.0 5.8047e-01 1.0 0.00e+00 0.0 9.7e+02 3.5e+04 8.8e+01 0 0 0 0 2 0 0 0 0 2 0
MatMatMultNum 4 1.0 1.7238e-01 1.0 2.13e+07 1.3 1.7e+02 9.8e+04 8.0e+00 0 0 0 0 0 0 0 0 0 0 2308
MatPtAP 4 1.0 3.0428e+00 1.0 8.45e+08 2.7 2.2e+03 9.0e+04 1.1e+02 1 0 0 0 2 1 0 0 0 2 2823
MatPtAPSymbolic 4 1.0 1.8848e+00 1.0 0.00e+00 0.0 2.0e+03 7.5e+04 1.0e+02 0 0 0 0 2 0 0 0 0 2 0
MatPtAPNumeric 4 1.0 1.1581e+00 1.0 8.45e+08 2.7 2.4e+02 2.1e+05 8.0e+00 0 0 0 0 0 0 0 0 0 0 7418
MatTrnMatMult 4 1.0 6.8553e+00 1.0 1.03e+09 3.2 1.1e+03 5.9e+05 1.2e+02 1 1 0 1 2 2 1 0 1 2 3304
MatGetLocalMat 20 1.0 3.6288e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 2.4e+01 0 0 0 0 0 0 0 0 0 0 0
MatGetBrAoCol 12 1.0 7.6919e-02 1.6 0.00e+00 0.0 1.2e+03 1.4e+05 1.6e+01 0 0 0 0 0 0 0 0 0 0 0
MatGetSymTrans 8 1.0 4.5255e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPGMRESOrthog 720 1.0 4.8121e-01 1.2 2.00e+08 1.1 0.0e+00 0.0e+00 7.2e+02 0 0 0 0 13 0 0 0 0 14 9566
KSPSetUp 11 1.0 7.0659e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01 0 0 0 0 0 0 0 0 0 0 0
KSPSolve 20 1.0 4.2393e+02 1.0 1.33e+11 1.3 9.3e+05 8.5e+04 5.1e+03 73 96100 98 92 100100100100 98 6212
VecDot 660 1.0 1.2440e+01 5.9 1.08e+09 1.0 0.0e+00 0.0e+00 6.6e+02 1 1 0 0 12 1 1 0 0 13 2022
VecDotNorm2 330 1.0 1.2494e+01 4.8 2.16e+09 1.0 0.0e+00 0.0e+00 9.9e+02 1 2 0 0 18 2 2 0 0 19 4027
VecMDot 720 1.0 2.8871e-01 1.4 1.00e+08 1.1 0.0e+00 0.0e+00 7.2e+02 0 0 0 0 13 0 0 0 0 14 7972
VecNorm 1754 1.0 1.3658e+0119.0 5.93e+08 1.0 0.0e+00 0.0e+00 1.8e+03 1 1 0 0 32 1 1 0 0 34 1011
VecScale 12284 1.0 8.2996e+00 1.2 2.49e+09 1.1 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 2 2 0 0 0 6885
VecCopy 3444 1.0 3.1909e+00 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
VecSet 11695 1.0 2.7659e+00 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
VecAXPY 22444 1.0 3.1521e+01 1.3 9.91e+09 1.1 0.0e+00 0.0e+00 0.0e+00 5 8 0 0 0 7 9 0 0 0 7223
VecAYPX 21760 1.0 3.1916e+01 1.2 6.19e+09 1.1 0.0e+00 0.0e+00 0.0e+00 5 5 0 0 0 7 5 0 0 0 4458
VecAXPBYCZ 660 1.0 5.2597e+00 1.1 2.16e+09 1.0 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 1 2 0 0 0 9566
VecWAXPY 660 1.0 5.2671e+00 1.1 1.08e+09 1.0 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 1 1 0 0 0 4776
VecMAXPY 1404 1.0 2.3818e-01 1.1 1.18e+08 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 11420
VecAssemblyBegin 110 1.0 8.9732e-01 3.7 0.00e+00 0.0 0.0e+00 0.0e+00 3.2e+02 0 0 0 0 6 0 0 0 0 6 0
VecAssemblyEnd 110 1.0 1.0490e-04 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecPointwiseMult 16364 1.0 3.4136e+01 1.2 3.73e+09 1.1 0.0e+00 0.0e+00 0.0e+00 5 3 0 0 0 7 3 0 0 0 2507
VecScatterBegin 23218 1.0 3.1578e+00 2.3 0.00e+00 0.0 9.3e+05 8.4e+04 0.0e+00 0 0 99 97 0 1 0 99 99 0 0
VecScatterEnd 23218 1.0 4.9513e+01 5.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 5 0 0 0 0 7 0 0 0 0 0
VecSetRandom 4 1.0 1.3620e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecNormalize 1404 1.0 1.2207e+01120.4 3.01e+07 1.1 0.0e+00 0.0e+00 1.4e+03 1 0 0 0 25 1 0 0 0 27 57
PCSetUp 2 1.0 1.5744e+01 1.0 1.83e+09 1.2 1.2e+04 1.2e+05 1.1e+03 3 2 1 2 19 4 2 1 2 20 2664
PCSetUpOnBlocks 680 1.0 6.5613e-04 1.6 6.48e+03 0.0 0.0e+00 0.0e+00 5.0e+00 0 0 0 0 0 0 0 0 0 0 10
PCApply 680 1.0 3.6728e+02 1.1 1.18e+11 1.3 8.9e+05 7.9e+04 2.1e+03 62 82 95 87 37 84 86 95 89 39 6165
PCGAMGgraph_AGG 4 1.0 1.5585e+00 1.0 2.13e+07 1.3 4.9e+02 4.9e+04 7.6e+01 0 0 0 0 1 0 0 0 0 1 255
PCGAMGcoarse_AGG 4 1.0 7.5525e+00 1.0 1.03e+09 3.2 5.2e+03 1.8e+05 3.8e+02 1 1 1 1 7 2 1 1 1 7 2999
PCGAMGProl_AGG 4 1.0 1.3036e+00 1.0 0.00e+00 0.0 1.3e+03 5.5e+04 1.1e+02 0 0 0 0 2 0 0 0 0 2 0
PCGAMGPOpt_AGG 4 1.0 2.1967e+00 1.0 4.93e+08 1.2 2.8e+03 7.6e+04 2.1e+02 0 0 0 0 4 1 0 0 0 4 4693
MatMult 38 1.0 4.4312e+00 1.1 1.20e+09 1.1 1.7e+03 7.2e+05 0.0e+00 1 1 0 2 0 12 23 95 99 0 6295
MatSolve 57 1.0 6.1924e+00 1.1 1.78e+09 1.1 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 17 34 0 0 0 6680
MatLUFactorNum 19 1.0 6.1136e+00 1.1 9.93e+08 1.1 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 16 19 0 0 0 3776
MatILUFactorSym 1 1.0 2.6631e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00 0 0 0 0 0 1 0 0 0 0 0
MatAssemblyBegin 19 1.0 2.0705e+0034.4 0.00e+00 0.0 0.0e+00 0.0e+00 3.8e+01 0 0 0 0 1 4 0 0 0 13 0
MatAssemblyEnd 19 1.0 2.1199e+00 1.0 0.00e+00 0.0 9.2e+01 1.8e+05 8.0e+00 0 0 0 0 0 6 0 5 1 3 0
MatGetRowIJ 1 1.0 2.1458e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 1.0 2.9305e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 0 0 0 0 1 0
KSPSetUp 38 1.0 8.0219e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPSolve 19 1.0 2.1292e+01 1.0 5.28e+09 1.1 1.7e+03 7.2e+05 1.4e+02 4 4 0 2 2 59100 95 99 46 5766
VecDot 38 1.0 7.3666e-01 1.9 1.87e+08 1.0 0.0e+00 0.0e+00 3.8e+01 0 0 0 0 1 1 4 0 0 13 5899
VecDotNorm2 19 1.0 7.0598e-01 1.7 3.73e+08 1.0 0.0e+00 0.0e+00 5.7e+01 0 0 0 0 1 2 7 0 0 19 12310
VecNorm 38 1.0 9.6422e-01 6.6 1.87e+08 1.0 0.0e+00 0.0e+00 3.8e+01 0 0 0 0 1 1 4 0 0 13 4507
VecCopy 38 1.0 4.3037e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
VecSet 115 1.0 1.0355e+00 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 3 0 0 0 0 0
VecAXPBYCZ 38 1.0 9.1814e-01 1.1 3.73e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 7 0 0 0 9466
VecWAXPY 38 1.0 9.1795e-01 1.1 1.87e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 4 0 0 0 4734
VecAssemblyBegin 38 1.0 8.9392e-0211.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.1e+02 0 0 0 0 2 0 0 0 0 38 0
VecAssemblyEnd 38 1.0 4.3392e-05 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecScatterBegin 38 1.0 5.8024e-02 2.2 0.00e+00 0.0 1.7e+03 7.2e+05 0.0e+00 0 0 0 2 0 0 0 95 99 0 0
VecScatterEnd 38 1.0 3.1747e-01 3.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
PCSetUp 38 1.0 6.4099e+00 1.1 9.93e+08 1.1 0.0e+00 0.0e+00 5.0e+00 1 1 0 0 0 17 19 0 0 2 3602
PCSetUpOnBlocks 19 1.0 6.4097e+00 1.1 9.93e+08 1.1 0.0e+00 0.0e+00 3.0e+00 1 1 0 0 0 17 19 0 0 1 3602
PCApply 57 1.0 6.6614e+00 1.1 1.78e+09 1.1 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 18 34 0 0 0 6210
Matrix 6 48 1076255464 0
Vector 4 63 248561024 0
Index Set 0 10 9824824 0
Viewer 1 0 0 0
Matrix 117 76 734590032 0
Vector 225 175 200939176 0
Index Set 81 74 764972 0
Matrix 1 0 0 0
Vector 10 1 1496 0
Average time to get PetscTime(): 0
Average time for MPI_Barrier(): 2.36034e-05
Average time for zero size MPI_Send(): 2.29478e-06
-log_summary
00000 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:17:35
00001 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:17:35
00002 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:17:35
00003 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:17:35
00004 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:17:35
00005 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:17:35
00006 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:17:35
00007 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:17:35
00008 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:17:35
00009 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:17:35
00010 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:17:35
00011 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:17:35
00012 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:17:35
00013 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:17:35
00014 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:17:35
00015 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:17:35
00016 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:17:35
00017 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:17:35
00018 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:17:35
00019 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:17:35
00020 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:17:35
00021 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:17:35
00022 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:17:35
00023 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:17:35
./a.out on a petsc-3.3-dev_atlas6_rel named atlas6-c14 with 32 processors, by g0306332 Mon Oct 8 04:38:44 2012
mv: cannot move `/var/tmp/uvwp32.plt' to `/home/wtay/Results/8/': No such file or directory
Time (sec): 5.793e+02 1.00264 5.781e+02
Flops: 1.280e+11 1.26041 1.076e+11 3.442e+12
Flops/sec: 2.210e+08 1.25710 1.861e+08 5.955e+09
MPI Messages: 8.329e+04 3.19963 5.696e+04 1.823e+06
MPI Message Lengths: 4.386e+09 2.01368 7.429e+04 1.354e+11
MPI Reductions: 6.648e+03 1.00000
0: Main Stage: 1.4747e+02 25.5% 0.0000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0% 2.000e+01 0.3%
1: poisson_eqn: 4.0301e+02 69.7% 3.3200e+12 96.4% 1.820e+06 99.9% 7.334e+04 98.7% 6.329e+03 95.2%
2: momentum_eqn: 2.7602e+01 4.8% 1.2245e+11 3.6% 2.480e+03 0.1% 9.434e+02 1.3% 2.980e+02 4.5%
Phase summary info:
MatMult 22328 1.0 2.4333e+02 1.1 8.47e+10 1.3 1.5e+06 8.6e+04 0.0e+00 40 63 80 93 0 57 65 80 94 0 8859
MatMultAdd 3432 1.0 1.7052e+01 1.5 5.96e+09 1.5 1.7e+05 1.8e+04 0.0e+00 2 4 10 2 0 4 4 10 2 0 7952
MatMultTranspose 3432 1.0 2.4190e+01 2.0 5.96e+09 1.5 1.7e+05 1.8e+04 0.0e+00 3 4 10 2 0 4 4 10 2 0 5605
MatSolve 1716 0.0 6.4962e-03 0.0 1.62e+06 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 249
MatLUFactorSym 1 1.0 3.4094e-05 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatLUFactorNum 1 1.0 2.0027e-05 7.0 6.24e+03 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 311
MatConvert 4 1.0 9.4268e-02 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatScale 12 1.0 1.0746e-01 1.6 2.28e+07 1.4 2.7e+02 8.1e+04 0.0e+00 0 0 0 0 0 0 0 0 0 0 5182
MatAssemblyBegin 69 1.0 2.4791e+00 3.8 0.00e+00 0.0 7.1e+02 1.6e+04 7.4e+01 0 0 0 0 1 0 0 0 0 1 0
MatAssemblyEnd 69 1.0 9.1389e-01 1.1 0.00e+00 0.0 3.8e+03 1.2e+04 2.0e+02 0 0 0 0 3 0 0 0 0 3 0
MatGetRow 1358404 1.1 1.6604e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetRowIJ 1 0.0 7.1526e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 0.0 4.6015e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.2e-02 0 0 0 0 0 0 0 0 0 0 0
MatCoarsen 4 1.0 3.2097e-01 1.3 0.00e+00 0.0 5.8e+03 3.5e+04 2.2e+02 0 0 0 0 3 0 0 0 0 3 0
MatAXPY 4 1.0 2.6504e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatMatMult 4 1.0 5.9873e-01 1.0 1.59e+07 1.4 1.8e+03 3.8e+04 9.6e+01 0 0 0 0 1 0 0 0 0 2 666
MatMatMultSym 4 1.0 4.7245e-01 1.0 0.00e+00 0.0 1.5e+03 3.1e+04 8.8e+01 0 0 0 0 1 0 0 0 0 1 0
MatMatMultNum 4 1.0 1.2957e-01 1.0 1.59e+07 1.4 2.7e+02 8.1e+04 8.0e+00 0 0 0 0 0 0 0 0 0 0 3078
MatPtAP 4 1.0 2.4452e+00 1.0 6.76e+08 3.0 3.4e+03 7.9e+04 1.1e+02 0 0 0 0 2 1 0 0 0 2 3527
MatPtAPSymbolic 4 1.0 1.5169e+00 1.1 0.00e+00 0.0 3.1e+03 6.5e+04 1.0e+02 0 0 0 0 2 0 0 0 0 2 0
MatPtAPNumeric 4 1.0 9.2885e-01 1.0 6.76e+08 3.0 3.4e+02 2.0e+05 8.0e+00 0 0 0 0 0 0 0 0 0 0 9285
MatTrnMatMult 4 1.0 5.3296e+00 1.0 7.66e+08 3.9 1.5e+03 5.5e+05 1.2e+02 1 1 0 1 2 1 1 0 1 2 4241
MatGetLocalMat 20 1.0 2.7215e-01 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 2.4e+01 0 0 0 0 0 0 0 0 0 0 0
MatGetBrAoCol 12 1.0 9.9058e-02 2.2 0.00e+00 0.0 1.9e+03 1.2e+05 1.6e+01 0 0 0 0 0 0 0 0 0 0 0
MatGetSymTrans 8 1.0 3.3771e-02 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPGMRESOrthog 898 1.0 4.8392e-01 1.4 1.50e+08 1.1 0.0e+00 0.0e+00 9.0e+02 0 0 0 0 14 0 0 0 0 14 9516
KSPSetUp 11 1.0 5.3839e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01 0 0 0 0 0 0 0 0 0 0 0
KSPSolve 20 1.0 4.0076e+02 1.0 1.24e+11 1.3 1.8e+06 7.3e+04 6.2e+03 69 96100 99 93 99100100100 98 8284
VecDot 838 1.0 1.9926e+0110.1 1.02e+09 1.1 0.0e+00 0.0e+00 8.4e+02 1 1 0 0 13 2 1 0 0 13 1603
VecDotNorm2 419 1.0 1.9897e+01 8.4 2.03e+09 1.1 0.0e+00 0.0e+00 1.3e+03 1 2 0 0 19 2 2 0 0 20 3211
VecMDot 898 1.0 3.8118e-01 1.9 7.48e+07 1.1 0.0e+00 0.0e+00 9.0e+02 0 0 0 0 14 0 0 0 0 14 6040
VecNorm 2199 1.0 1.4204e+0118.3 5.47e+08 1.1 0.0e+00 0.0e+00 2.2e+03 1 0 0 0 33 1 1 0 0 35 1211
VecScale 15488 1.0 9.1676e+00 2.1 2.34e+09 1.1 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 2 2 0 0 0 7861
VecCopy 4334 1.0 3.1940e+00 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
VecSet 14721 1.0 2.4871e+00 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
VecAXPY 28318 1.0 3.1641e+01 1.9 9.33e+09 1.1 0.0e+00 0.0e+00 0.0e+00 5 8 0 0 0 7 9 0 0 0 9083
VecAYPX 27456 1.0 3.1435e+01 1.6 5.83e+09 1.1 0.0e+00 0.0e+00 0.0e+00 5 5 0 0 0 7 5 0 0 0 5713
VecAXPBYCZ 838 1.0 4.9286e+00 1.3 2.03e+09 1.1 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 1 2 0 0 0 12962
VecWAXPY 838 1.0 4.9716e+00 1.3 1.02e+09 1.1 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 1 1 0 0 0 6425
VecMAXPY 1760 1.0 1.7820e-01 1.5 8.84e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 15270
VecAssemblyBegin 118 1.0 1.9584e+00 6.7 0.00e+00 0.0 0.0e+00 0.0e+00 3.5e+02 0 0 0 0 5 0 0 0 0 5 0
VecAssemblyEnd 118 1.0 1.0204e-04 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecPointwiseMult 20636 1.0 3.3645e+01 1.7 3.50e+09 1.1 0.0e+00 0.0e+00 0.0e+00 5 3 0 0 0 7 3 0 0 0 3210
VecScatterBegin 29278 1.0 4.1807e+00 2.5 0.00e+00 0.0 1.8e+06 7.3e+04 0.0e+00 1 0 99 98 0 1 0100 99 0 0
VecScatterEnd 29278 1.0 1.0144e+0214.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 6 0 0 0 0 8 0 0 0 0 0
VecSetRandom 4 1.0 1.0141e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecNormalize 1760 1.0 1.1541e+01158.2 2.25e+07 1.1 0.0e+00 0.0e+00 1.8e+03 1 0 0 0 26 1 0 0 0 28 60
PCSetUp 2 1.0 1.2079e+01 1.0 1.36e+09 1.2 2.0e+04 9.8e+04 1.1e+03 2 1 1 1 16 3 1 1 1 17 3473
PCSetUpOnBlocks 858 1.0 8.4829e-04 1.7 6.24e+03 0.0 0.0e+00 0.0e+00 5.0e+00 0 0 0 0 0 0 0 0 0 0 7
PCApply 858 1.0 3.4936e+02 1.1 1.11e+11 1.3 1.7e+06 6.8e+04 2.6e+03 59 83 96 88 39 84 86 96 89 41 8195
PCGAMGgraph_AGG 4 1.0 1.1721e+00 1.0 1.59e+07 1.4 7.4e+02 4.4e+04 7.6e+01 0 0 0 0 1 0 0 0 0 1 340
PCGAMGcoarse_AGG 4 1.0 5.8811e+00 1.0 7.66e+08 3.9 8.7e+03 1.4e+05 4.1e+02 1 1 0 1 6 1 1 0 1 7 3843
PCGAMGProl_AGG 4 1.0 8.9037e-01 1.0 0.00e+00 0.0 1.8e+03 5.4e+04 1.1e+02 0 0 0 0 2 0 0 0 0 2 0
PCGAMGPOpt_AGG 4 1.0 1.6679e+00 1.0 3.64e+08 1.2 4.5e+03 6.4e+04 2.1e+02 0 0 0 0 3 0 0 0 0 3 6189
MatMult 38 1.0 3.3929e+00 1.3 8.88e+08 1.1 2.4e+03 7.2e+05 0.0e+00 1 1 0 1 0 12 23 95 99 0 8221
MatSolve 57 1.0 4.6989e+00 1.4 1.31e+09 1.1 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 16 34 0 0 0 8769
MatLUFactorNum 19 1.0 4.5038e+00 1.1 7.31e+08 1.1 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 16 19 0 0 0 5093
MatILUFactorSym 1 1.0 1.9833e-01 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00 0 0 0 0 0 1 0 0 0 0 0
MatAssemblyBegin 19 1.0 3.3288e+0018.8 0.00e+00 0.0 0.0e+00 0.0e+00 3.8e+01 0 0 0 0 1 5 0 0 0 13 0
MatAssemblyEnd 19 1.0 1.6178e+00 1.2 0.00e+00 0.0 1.2e+02 1.8e+05 8.0e+00 0 0 0 0 0 6 0 5 1 3 0
MatGetOrdering 1 1.0 2.2255e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 0 0 0 0 1 0
KSPSetUp 38 1.0 5.9859e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPSolve 19 1.0 1.6160e+01 1.0 3.90e+09 1.1 2.4e+03 7.2e+05 1.4e+02 3 4 0 1 2 59100 95 99 46 7577
VecDot 38 1.0 1.3321e+00 4.0 1.38e+08 1.1 0.0e+00 0.0e+00 3.8e+01 0 0 0 0 1 2 4 0 0 13 3262
VecDotNorm2 19 1.0 1.2704e+00 3.6 2.76e+08 1.1 0.0e+00 0.0e+00 5.7e+01 0 0 0 0 1 2 7 0 0 19 6841
VecNorm 38 1.0 1.5091e+00 9.8 1.38e+08 1.1 0.0e+00 0.0e+00 3.8e+01 0 0 0 0 1 2 4 0 0 13 2879
VecCopy 38 1.0 3.3406e-01 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
VecSet 115 1.0 7.8406e-01 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 3 0 0 0 0 0
VecAXPBYCZ 38 1.0 6.9826e-01 1.4 2.76e+08 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 7 0 0 0 12446
VecWAXPY 38 1.0 6.8325e-01 1.3 1.38e+08 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 4 0 0 0 6360
VecAssemblyBegin 38 1.0 4.2442e-0143.9 0.00e+00 0.0 0.0e+00 0.0e+00 1.1e+02 0 0 0 0 2 0 0 0 0 38 0
VecAssemblyEnd 38 1.0 4.1008e-05 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecScatterBegin 38 1.0 5.7228e-02 2.5 0.00e+00 0.0 2.4e+03 7.2e+05 0.0e+00 0 0 0 1 0 0 0 95 99 0 0
VecScatterEnd 38 1.0 4.9354e-01 4.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
PCSetUp 38 1.0 4.7225e+00 1.1 7.31e+08 1.1 0.0e+00 0.0e+00 5.0e+00 1 1 0 0 0 16 19 0 0 2 4857
PCSetUpOnBlocks 19 1.0 4.7223e+00 1.1 7.31e+08 1.1 0.0e+00 0.0e+00 3.0e+00 1 1 0 0 0 16 19 0 0 1 4857
PCApply 57 1.0 5.0658e+00 1.4 1.31e+09 1.1 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 17 34 0 0 0 8133
Matrix 6 48 802816820 0
Vector 4 63 184694312 0
Index Set 0 10 7279624 0
Viewer 1 0 0 0
Matrix 117 76 536993068 0
Vector 225 175 150834928 0
Index Set 81 74 749444 0
Matrix 1 0 0 0
Vector 10 1 1496 0
Average time for MPI_Barrier(): 2.57969e-05
Average time for zero size MPI_Send(): 2.34693e-06
-log_summary
00000 atlas6-c43 ./a.out -poisson Done 10/08/2012 04:38:45
00001 atlas6-c43 ./a.out -poisson Done 10/08/2012 04:38:45
00002 atlas6-c43 ./a.out -poisson Done 10/08/2012 04:38:45
00003 atlas6-c43 ./a.out -poisson Done 10/08/2012 04:38:45
00004 atlas6-c43 ./a.out -poisson Done 10/08/2012 04:38:45
00005 atlas6-c43 ./a.out -poisson Done 10/08/2012 04:38:45
00006 atlas6-c43 ./a.out -poisson Done 10/08/2012 04:38:45
00007 atlas6-c43 ./a.out -poisson Done 10/08/2012 04:38:45
00008 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:38:45
00009 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:38:45
00010 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:38:45
00011 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:38:45
00012 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:38:45
00013 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:38:45
00014 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:38:45
00015 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:38:45
00016 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:38:45
00017 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:38:45
00018 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:38:45
00019 atlas6-c39 ./a.out -poisson Done 10/08/2012 04:38:45
00020 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:38:45
00021 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:38:45
00022 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:38:45
00023 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:38:45
00024 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:38:45
00025 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:38:45
00026 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:38:45
00027 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:38:45
00028 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:38:45
00029 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:38:45
00030 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:38:45
00031 atlas6-c14 ./a.out -poisson Done 10/08/2012 04:38:45
