[petsc-users] Enquiry regarding log summary results
TAY wee-beng
zonexo at gmail.com
Wed Oct 3 08:08:46 CDT 2012
On 2/10/2012 2:43 PM, Jed Brown wrote:
> On Tue, Oct 2, 2012 at 8:35 AM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
> Hi,
> I have combined the momentum linear eqns involving x,y,z into 1
> large matrix. The Poisson eqn is solved using HYPRE strcut format
> so it's not included. I run the code for 50 timesteps (hence 50
> kspsolve) using 96 procs. The log_summary is given below. I have
> some questions:
> 1. After combining the matrix, I should have only 1 PETSc matrix.
> Why does it says there are 4 matrix, 12 vector etc?
> They are part of preconditioning. Are you sure you're using Hypre for
> this? It looks like you are using bjacobi/ilu.
> 2. I'm looking at the stages which take the longest time. It seems
> that MatAssemblyBegin, VecNorm, VecAssemblyBegin, VecScatterEnd
> have very high ratios. The ratios of some others are also not too
> good (~ 1.6 - 2). So are these stages the reason why my code is
> not scaling well? What can I do to improve it?
> 3/4 of the solve time is evenly balanced between MatMult, MatSolve,
> MatLUFactorNumeric, and VecNorm+VecDot.
> The high VecAssembly time might be due to generating a lot of entries
> off-process?
> In any case, this looks like an _extremely_ slow network, perhaps it's
> misconfigured?
My cluster is configured with 48 procs per node. I re-run the case,
using only 48 procs, thus there's no need to pass over a 'slow'
interconnect. I'm now also using GAMG and BCGS for the poisson and
momentum eqn respectively. I have also separated the x,y,z component of
the momentum eqn to 3 separate linear eqns to debug the problem.
Results show that stage "momentum_z" is taking a lot of time. I wonder
if it has to do with the fact that I am partitioning my grids in the z
direction. VecScatterEnd, MatMult are taking a lot of time.
VecNormalize, VecScatterEnd, VecNorm, VecAssemblyBegin 's ratio are also
not good.
I wonder why a lot of entries are generated off-process.
I create my RHS vector using:
/call
VecCreateMPI(MPI_COMM_WORLD,ijk_xyz_end-ijk_xyz_sta,PETSC_DECIDE,b_rhs_semi_z,ierr)/
where ijk_xyz_sta and ijk_xyz_end are obtained from
/call MatGetOwnershipRange(A_semi_z,ijk_xyz_sta,ijk_xyz_end,ierr)/
I then insert the values into the vector using:
/call VecSetValues(b_rhs_semi_z , ijk_xyz_end - ijk_xyz_sta ,
(/ijk_xyz_sta : ijk_xyz_end - 1/) , q_semi_vect_z(ijk_xyz_sta + 1 :
ijk_xyz_end) , INSERT_VALUES , ierr)/
What should I do to correct the problem?
Thanks
> Btw, I insert matrix using:
> /do ijk=ijk_xyz_sta+1,ijk_xyz_end//
> // II = ijk - 1// !Fortran shift to 0-based//
> // call
> MatSetValues(A_semi_xyz,1,II,7,int_semi_xyz(ijk,1:7),semi_mat_xyz(ijk,1:7),INSERT_VALUES,ierr)//
> //end do/
> where ijk_xyz_sta/ijk_xyz_end are the starting/end index
> int_semi_xyz(ijk,1:7) stores the 7 column global indices
> semi_mat_xyz has the corresponding values.
> and I insert vectors using:
> call
> VecSetValues(b_rhs_semi_xyz,ijk_xyz_end_mz-ijk_xyz_sta_mz,(/ijk_xyz_sta_mz:ijk_xyz_end_mz-1/),q_semi_vect_xyz(ijk_xyz_sta_mz+1:ijk_xyz_end_mz),INSERT_VALUES,ierr)
> Thanks!
> Yours sincerely,
> TAY wee-beng
> On 30/9/2012 11:30 PM, Jed Brown wrote:
>> You can measure the time spent in Hypre via PCApply and PCSetUp,
>> but you can't get finer grained integrated profiling because it
>> was not set up that way.
>> On Sep 30, 2012 3:26 PM, "TAY wee-beng" <zonexo at gmail.com
>> On 27/9/2012 1:44 PM, Matthew Knepley wrote:
>>> On Thu, Sep 27, 2012 at 3:49 AM, TAY wee-beng
>>> <zonexo at gmail.com <mailto:zonexo at gmail.com>> wrote:
>>> Hi,
>>> I'm doing a log summary for my 3d cfd code. I have some
>>> questions:
>>> 1. if I'm solving 3 linear equations using ksp, is the
>>> result given in the log summary the total of the 3
>>> linear eqns' performance? How can I get the performance
>>> for each individual eqn?
>>> Use logging stages:
>>> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Profiling/PetscLogStagePush.html
>>> 2. If I run my code for 10 time steps, does the log
>>> summary gives the total or avg performance/ratio?
>>> Total.
>>> 3. Besides PETSc, I'm also using HYPRE's native
>>> geometric MG (Struct) to solve my Cartesian's grid CFD
>>> poisson eqn. Is there any way I can use PETSc's log
>>> summary to get HYPRE's performance? If I use boomerAMG
>>> thru PETSc, can I get its performance?
>>> If you mean flops, only if you count them yourself and tell
>>> PETSc using
>>> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Profiling/PetscLogFlops.html
>>> This is the disadvantage of using packages that do not
>>> properly monitor things :)
>>> Matt
>> So u mean if I use boomerAMG thru PETSc, there is no proper
>> way of evaluating its performance, beside using PetscLogFlops?
>>> Yours sincerely,
>>> TAY wee-beng
>>> What most experimenters take for granted before they begin
>>> their experiments is infinitely more interesting than any
>>> results to which their experiments lead.
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121003/1e4e10a1/attachment-0001.html>
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./a.out on a petsc-3.3-dev_shared_rel named n12-09 with 48 processors, by wtay Wed Oct 3 14:07:35 2012
Using Petsc Development HG revision: 9883b54053eca13dd473a4711adfd309d1436b6e HG Date: Sun Sep 30 22:42:36 2012 -0500
Max Max/Min Avg Total
Time (sec): 6.005e+03 1.00489 5.990e+03
Objects: 5.680e+02 1.00000 5.680e+02
Flops: 5.608e+11 1.24568 4.595e+11 2.205e+13
Flops/sec: 9.338e+07 1.24320 7.671e+07 3.682e+09
MPI Messages: 1.768e+05 4.44284 1.320e+05 6.337e+06
MPI Message Lengths: 1.524e+10 2.00538 1.128e+05 7.146e+11
MPI Reductions: 1.352e+04 1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
e.g., VecAXPY() for real vectors of length N --> 2N flops
and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages: ----- Time ------ ----- Flops ----- --- Messages --- -- Message Lengths -- -- Reductions --
Avg %Total Avg %Total counts %Total Avg %Total counts %Total
0: Main Stage: 6.9025e+02 11.5% 0.0000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0% 3.600e+01 0.3%
1: poisson: 1.5981e+02 2.7% 5.8320e+11 2.6% 1.749e+05 2.8% 3.211e+03 2.8% 1.435e+03 10.6%
2: momentum_x: 3.7257e+00 0.1% 7.1634e+09 0.0% 3.760e+02 0.0% 1.616e+01 0.0% 2.800e+01 0.2%
3: momentum_y: 4.5579e+00 0.1% 7.2165e+09 0.0% 3.760e+02 0.0% 1.638e+01 0.0% 2.800e+01 0.2%
4: momentum_z: 5.1317e+03 85.7% 2.1457e+13 97.3% 6.161e+06 97.2% 1.095e+05 97.1% 1.199e+04 88.7%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
Count: number of times phase was executed
Time and Flops: Max - maximum over all processors
Ratio - ratio of maximum to minimum over all processors
Mess: number of messages sent
Avg. len: average message length
Reduct: number of global reductions
Global: entire computation
Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
%T - percent time in this phase %f - percent flops in this phase
%M - percent messages in this phase %L - percent message lengths in this phase
%R - percent reductions in this phase
Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event Count Time (sec) Flops --- Global --- --- Stage --- Total
Max Ratio Max Ratio Max Ratio Mess Avg len Reduct %T %f %M %L %R %T %f %M %L %R Mflop/s
--- Event Stage 0: Main Stage
--- Event Stage 1: poisson
MatMult 949 1.0 8.0050e+01 1.4 8.30e+09 1.3 1.1e+05 1.3e+05 0.0e+00 1 1 2 2 0 42 52 65 73 0 3820
MatMultAdd 140 1.0 4.1770e+00 2.0 5.68e+08 1.5 1.3e+04 2.8e+04 0.0e+00 0 0 0 0 0 2 3 7 2 0 4421
MatMultTranspose 140 1.0 9.3398e+00 4.6 5.68e+08 1.5 1.3e+04 2.8e+04 0.0e+00 0 0 0 0 0 3 3 7 2 0 1977
MatSolve 70 0.0 1.3373e-03 0.0 7.18e+05 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 537
MatLUFactorSym 1 1.0 2.8896e-0419.2 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatLUFactorNum 1 1.0 3.9911e-0450.7 1.89e+05 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 473
MatConvert 4 1.0 3.9349e-01 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatScale 12 1.0 4.3059e-01 1.4 5.29e+07 1.4 5.0e+02 1.2e+05 0.0e+00 0 0 0 0 0 0 0 0 0 0 4320
MatAssemblyBegin 69 1.0 1.4660e+01 3.3 0.00e+00 0.0 1.3e+03 2.4e+04 7.4e+01 0 0 0 0 1 5 0 1 0 5 0
MatAssemblyEnd 69 1.0 3.5805e+00 1.1 0.00e+00 0.0 7.3e+03 1.7e+04 2.0e+02 0 0 0 0 1 2 0 4 1 14 0
MatGetRow 3004250 1.0 1.2984e+00 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
MatGetRowIJ 1 0.0 3.3140e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 0.0 1.2302e-04 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 4.2e-02 0 0 0 0 0 0 0 0 0 0 0
MatCoarsen 4 1.0 1.1238e+00 1.1 0.00e+00 0.0 1.5e+04 4.2e+04 3.4e+02 0 0 0 0 2 1 0 8 3 23 0
MatAXPY 4 1.0 1.4109e-01 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatMatMult 4 1.0 3.1390e+00 1.0 3.67e+07 1.4 3.3e+03 5.7e+04 9.6e+01 0 0 0 0 1 2 0 2 1 7 424
MatMatMultSym 4 1.0 2.3711e+00 1.1 0.00e+00 0.0 2.8e+03 4.6e+04 8.8e+01 0 0 0 0 1 1 0 2 1 6 0
MatMatMultNum 4 1.0 7.8353e-01 1.0 3.67e+07 1.4 5.0e+02 1.2e+05 8.0e+00 0 0 0 0 0 0 0 0 0 1 1701
MatPtAP 4 1.0 1.0608e+01 1.0 1.89e+09 3.5 6.5e+03 1.2e+05 1.1e+02 0 0 0 0 1 7 5 4 4 8 2808
MatPtAPSymbolic 4 1.0 5.7953e+00 1.0 0.00e+00 0.0 5.9e+03 9.6e+04 1.0e+02 0 0 0 0 1 4 0 3 3 7 0
MatPtAPNumeric 4 1.0 4.8300e+00 1.0 1.89e+09 3.5 6.4e+02 3.1e+05 8.0e+00 0 0 0 0 0 3 5 0 1 1 6167
MatTrnMatMult 4 1.0 2.3590e+01 1.0 1.56e+09 4.5 2.7e+03 8.7e+05 1.2e+02 0 0 0 0 1 15 12 2 11 8 3021
MatGetLocalMat 20 1.0 1.2136e+00 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 2.4e+01 0 0 0 0 0 1 0 0 0 2 0
MatGetBrAoCol 12 1.0 5.6065e-01 2.7 0.00e+00 0.0 3.5e+03 1.8e+05 1.6e+01 0 0 0 0 0 0 0 2 3 1 0
MatGetSymTrans 8 1.0 1.6375e-01 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPGMRESOrthog 75 1.0 2.5885e+00 2.0 3.30e+08 1.0 0.0e+00 0.0e+00 7.5e+01 0 0 0 0 1 1 3 0 0 5 5937
KSPSetUp 11 1.0 3.6090e-01 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01 0 0 0 0 0 0 0 0 0 1 0
KSPSolve 1 1.0 1.5654e+02 1.0 1.46e+10 1.3 1.7e+05 1.2e+05 1.4e+03 3 3 3 3 10 98100100100 99 3726
VecDot 34 1.0 7.1871e+00 6.1 9.03e+07 1.0 0.0e+00 0.0e+00 3.4e+01 0 0 0 0 0 3 1 0 0 2 602
VecDotNorm2 17 1.0 7.2364e+00 5.6 1.81e+08 1.0 0.0e+00 0.0e+00 5.1e+01 0 0 0 0 0 3 1 0 0 4 1196
VecMDot 75 1.0 2.2869e+00 3.8 1.65e+08 1.0 0.0e+00 0.0e+00 7.5e+01 0 0 0 0 1 1 1 0 0 5 3360
VecNorm 132 1.0 5.8965e+0011.2 8.09e+07 1.0 0.0e+00 0.0e+00 1.3e+02 0 0 0 0 1 2 1 0 0 9 649
VecScale 674 1.0 1.7632e+00 3.1 2.27e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 2 0 0 0 5983
VecCopy 181 1.0 6.9148e-01 4.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 673 1.0 7.6137e-01 4.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 1159 1.0 4.6118e+00 3.0 8.44e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 7 0 0 0 8513
VecAYPX 1120 1.0 6.7999e+00 3.0 5.26e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 3 4 0 0 0 3596
VecAXPBYCZ 34 1.0 2.2253e+00 2.7 1.81e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 1 0 0 0 3890
VecWAXPY 34 1.0 2.3384e+00 3.0 9.03e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 1 0 0 0 1851
VecMAXPY 114 1.0 8.3695e-01 2.4 1.95e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 2 0 0 0 10851
VecAssemblyBegin 110 1.0 4.8131e-01 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 3.2e+02 0 0 0 0 2 0 0 0 0 23 0
VecAssemblyEnd 110 1.0 3.8481e-04 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecPointwiseMult 884 1.0 7.6038e+00 3.3 3.32e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 3 3 0 0 0 2030
VecScatterBegin 1345 1.0 8.7802e-01 4.0 0.00e+00 0.0 1.6e+05 1.1e+05 0.0e+00 0 0 2 2 0 0 0 90 83 0 0
VecScatterEnd 1345 1.0 5.5070e+0113.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 16 0 0 0 0 0
VecSetRandom 4 1.0 1.0962e-01 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecNormalize 114 1.0 4.4160e+0011.7 4.96e+07 1.0 0.0e+00 0.0e+00 1.1e+02 0 0 0 0 1 1 0 0 0 8 522
PCSetUp 2 1.0 5.6255e+01 1.0 3.09e+09 1.2 4.1e+04 1.3e+05 1.2e+03 1 1 1 1 9 35 23 23 27 84 2433
PCSetUpOnBlocks 35 1.0 8.9216e-04 5.9 1.89e+05 0.0 0.0e+00 0.0e+00 5.0e+00 0 0 0 0 0 0 0 0 0 0 212
PCApply 35 1.0 8.1400e+01 1.1 1.04e+10 1.3 1.3e+05 1.0e+05 1.2e+02 1 2 2 2 1 49 67 75 66 8 4792
PCGAMGgraph_AGG 4 1.0 6.8337e+00 1.0 3.67e+07 1.4 1.3e+03 7.0e+04 7.6e+01 0 0 0 0 1 4 0 1 0 5 195
PCGAMGcoarse_AGG 4 1.0 2.5930e+01 1.0 1.56e+09 4.5 2.0e+04 1.7e+05 5.3e+02 0 0 0 0 4 16 12 11 17 37 2748
PCGAMGProl_AGG 4 1.0 3.3635e+00 1.0 0.00e+00 0.0 3.4e+03 8.1e+04 1.1e+02 0 0 0 0 1 2 0 2 1 8 0
PCGAMGPOpt_AGG 4 1.0 9.5650e+00 1.0 8.23e+08 1.2 8.3e+03 9.6e+04 2.1e+02 0 0 0 0 2 6 6 5 4 15 3603
--- Event Stage 2: momentum_x
MatMult 2 1.0 1.8518e-01 1.1 3.40e+07 1.1 1.9e+02 4.4e+05 0.0e+00 0 0 0 0 0 5 23 50 80 0 8786
MatSolve 3 1.0 2.5920e-01 1.2 5.03e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 7 34 0 0 0 9297
MatLUFactorNum 1 1.0 2.7748e-01 1.1 2.81e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 7 19 0 0 0 4845
MatILUFactorSym 1 1.0 2.8246e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00 0 0 0 0 0 7 0 0 0 4 0
MatAssemblyBegin 1 1.0 5.8029e-013185.7 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 5 0 0 0 7 0
MatAssemblyEnd 1 1.0 4.6551e-01 1.1 0.00e+00 0.0 1.9e+02 1.1e+05 8.0e+00 0 0 0 0 0 12 0 50 20 29 0
MatGetRowIJ 1 1.0 1.3113e-05 6.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 1.0 3.4148e-02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 1 0 0 0 7 0
KSPSetUp 2 1.0 1.0453e-01 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 0 0 0 0 0
KSPSolve 1 1.0 1.2832e+00 1.0 1.50e+08 1.1 1.9e+02 4.4e+05 1.2e+01 0 0 0 0 0 34100 50 80 43 5583
VecDot 2 1.0 3.1625e-02 2.1 5.31e+06 1.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 1 4 0 0 7 8051
VecDotNorm2 1 1.0 3.0667e-02 1.9 1.06e+07 1.0 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 1 7 0 0 11 16605
VecNorm 2 1.0 8.6468e-0212.2 5.31e+06 1.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 1 4 0 0 7 2945
VecCopy 2 1.0 2.2391e-02 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 7 1.0 4.3424e-02 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
VecAXPBYCZ 2 1.0 5.0054e-02 1.5 1.06e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 7 0 0 0 10173
VecWAXPY 2 1.0 3.7987e-02 1.1 5.31e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 4 0 0 0 6703
VecAssemblyBegin 2 1.0 5.3350e-02206.6 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00 0 0 0 0 0 1 0 0 0 21 0
VecAssemblyEnd 2 1.0 2.1935e-05 5.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecScatterBegin 2 1.0 2.8200e-03 2.5 0.00e+00 0.0 1.9e+02 4.4e+05 0.0e+00 0 0 0 0 0 0 0 50 80 0 0
VecScatterEnd 2 1.0 1.5276e-02 4.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
PCSetUp 2 1.0 5.8300e-01 1.1 2.81e+07 1.1 0.0e+00 0.0e+00 5.0e+00 0 0 0 0 0 15 19 0 0 18 2306
PCSetUpOnBlocks 1 1.0 5.8285e-01 1.1 2.81e+07 1.1 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 15 19 0 0 11 2307
PCApply 3 1.0 2.7368e-01 1.2 5.03e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 7 34 0 0 0 8805
--- Event Stage 3: momentum_y
MatMult 2 1.0 2.6384e-01 1.6 3.43e+07 1.1 1.9e+02 4.4e+05 0.0e+00 0 0 0 0 0 5 23 50 80 0 6228
MatSolve 3 1.0 4.3936e-01 1.9 5.08e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 7 34 0 0 0 5539
MatLUFactorNum 1 1.0 3.7870e-01 1.3 2.83e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 7 19 0 0 0 3584
MatILUFactorSym 1 1.0 6.7441e-01 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00 0 0 0 0 0 10 0 0 0 4 0
MatAssemblyBegin 1 1.0 2.6880e-011700.5 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 3 0 0 0 7 0
MatAssemblyEnd 1 1.0 4.4579e-01 1.1 0.00e+00 0.0 1.9e+02 1.1e+05 8.0e+00 0 0 0 0 0 9 0 50 20 29 0
MatGetRowIJ 1 1.0 6.9141e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 1.0 1.4430e-01 6.5 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 1 0 0 0 7 0
KSPSetUp 2 1.0 1.9449e-01 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 0 0 0 0 0
KSPSolve 1 1.0 2.1803e+00 1.0 1.51e+08 1.1 1.9e+02 4.4e+05 1.2e+01 0 0 0 0 0 48100 50 80 43 3310
VecDot 2 1.0 1.6268e-0112.1 5.31e+06 1.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 2 4 0 0 7 1565
VecDotNorm2 1 1.0 1.5914e-01 4.8 1.06e+07 1.0 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 3 7 0 0 11 3200
VecNorm 2 1.0 5.7848e-0184.8 5.31e+06 1.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 8 4 0 0 7 440
VecCopy 2 1.0 4.2936e-02 3.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 7 1.0 8.5729e-02 4.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
VecAXPBYCZ 2 1.0 9.1384e-02 2.7 1.06e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 7 0 0 0 5572
VecWAXPY 2 1.0 5.4740e-02 1.6 5.31e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 4 0 0 0 4651
VecAssemblyBegin 2 1.0 5.1133e-02181.4 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00 0 0 0 0 0 1 0 0 0 21 0
VecAssemblyEnd 2 1.0 2.2888e-05 6.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecScatterBegin 2 1.0 4.3221e-03 3.7 0.00e+00 0.0 1.9e+02 4.4e+05 0.0e+00 0 0 0 0 0 0 0 50 80 0 0
VecScatterEnd 2 1.0 9.5706e-0248.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
PCSetUp 2 1.0 1.1065e+00 1.7 2.83e+07 1.1 0.0e+00 0.0e+00 5.0e+00 0 0 0 0 0 18 19 0 0 18 1227
PCSetUpOnBlocks 1 1.0 1.1063e+00 1.7 2.83e+07 1.1 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 18 19 0 0 11 1227
PCApply 3 1.0 4.5571e-01 1.8 5.08e+07 1.1 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 7 34 0 0 0 5340
--- Event Stage 4: momentum_z
MatMult 41867 1.0 3.5526e+03 1.3 3.68e+11 1.3 5.0e+06 1.3e+05 0.0e+00 51 62 79 93 0 60 64 81 95 0 3841
MatMultAdd 6404 1.0 2.5862e+02 2.7 2.60e+10 1.5 5.9e+05 2.8e+04 0.0e+00 2 4 9 2 0 3 4 10 2 0 3266
MatMultTranspose 6404 1.0 4.1748e+02 5.0 2.60e+10 1.5 5.9e+05 2.8e+04 0.0e+00 4 4 9 2 0 4 4 10 2 0 2023
MatSolve 3637 8.4 6.2673e+01 1.9 7.38e+09 1.1 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 1 2 0 0 0 5614
MatLUFactorNum 145 1.0 6.3762e+01 1.6 4.10e+09 1.1 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 1 1 0 0 0 3078
MatILUFactorSym 1 1.0 7.4252e-01 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatAssemblyBegin 145 1.0 4.6714e+01 8.3 0.00e+00 0.0 0.0e+00 0.0e+00 2.9e+02 0 0 0 0 2 0 0 0 0 2 0
MatAssemblyEnd 145 1.0 3.1650e+01 2.4 0.00e+00 0.0 1.9e+02 1.1e+05 8.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetRowIJ 1 1.0 1.1921e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 1.0 1.4477e-01 4.8 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPGMRESOrthog 1601 1.0 1.4767e-01 2.1 5.36e+05 0.0 0.0e+00 0.0e+00 1.6e+03 0 0 0 0 12 0 0 0 0 13 4
KSPSetUp 290 1.0 3.6730e-01 3.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPSolve 194 1.0 4.8040e+03 1.0 5.46e+11 1.2 6.2e+06 1.1e+05 1.1e+04 80 97 97 97 78 94100100100 88 4466
VecDot 1842 1.0 3.9224e+02 8.1 4.89e+09 1.0 0.0e+00 0.0e+00 1.8e+03 3 1 0 0 14 4 1 0 0 15 598
VecDotNorm2 921 1.0 3.8957e+02 6.6 9.79e+09 1.0 0.0e+00 0.0e+00 2.8e+03 3 2 0 0 20 4 2 0 0 23 1204
VecMDot 1601 1.0 1.2703e-01 2.4 2.67e+05 0.0 0.0e+00 0.0e+00 1.6e+03 0 0 0 0 12 0 0 0 0 13 2
VecNorm 4317 1.0 2.5639e+0218.7 2.96e+09 1.0 0.0e+00 0.0e+00 4.3e+03 2 1 0 0 32 2 1 0 0 36 554
VecScale 28818 1.0 8.1507e+01 3.9 9.62e+09 1.0 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 1 2 0 0 0 5489
VecCopy 8393 1.0 3.4342e+01 3.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 28235 1.0 3.8371e+01 3.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 52833 1.0 2.2300e+02 3.3 3.85e+10 1.0 0.0e+00 0.0e+00 0.0e+00 2 8 0 0 0 3 8 0 0 0 8025
VecAYPX 51232 1.0 3.0984e+02 3.0 2.40e+10 1.0 0.0e+00 0.0e+00 0.0e+00 3 5 0 0 0 4 5 0 0 0 3610
VecAXPBYCZ 1842 1.0 1.1255e+02 2.3 9.79e+09 1.0 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 1 2 0 0 0 4167
VecWAXPY 1842 1.0 1.1471e+02 2.7 4.89e+09 1.0 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 1 1 0 0 0 2044
VecMAXPY 3202 1.0 1.0685e-02 5.7 5.38e+05 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 50
VecAssemblyBegin 388 1.0 3.0027e+0160.3 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+03 0 0 0 0 9 0 0 0 0 10 0
VecAssemblyEnd 388 1.0 3.5229e-03 4.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecPointwiseMult 38424 1.0 3.4261e+02 3.4 1.44e+10 1.0 0.0e+00 0.0e+00 0.0e+00 3 3 0 0 0 4 3 0 0 0 1959
VecScatterBegin 54675 1.0 3.8022e+01 4.2 0.00e+00 0.0 6.2e+06 1.1e+05 0.0e+00 0 0 97 97 0 0 0100100 0 0
VecScatterEnd 54675 1.0 2.5222e+0320.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 20 0 0 0 0 23 0 0 0 0 0
VecNormalize 3202 1.0 1.6108e+021783.0 8.07e+05 0.0 0.0e+00 0.0e+00 3.2e+03 1 0 0 0 24 1 0 0 0 27 0
PCSetUp 290 1.0 6.4608e+01 1.6 4.10e+09 1.1 0.0e+00 0.0e+00 5.0e+00 1 1 0 0 0 1 1 0 0 0 3038
PCSetUpOnBlocks 1746 1.0 6.4608e+01 1.6 4.10e+09 1.1 0.0e+00 0.0e+00 3.0e+00 1 1 0 0 0 1 1 0 0 0 3038
PCApply 2036 1.0 3.8864e+03 1.2 4.81e+11 1.3 6.0e+06 1.0e+05 4.8e+03 61 83 94 86 36 71 85 97 89 40 4682
Memory usage is given in bytes:
Object Type Creations Destructions Memory Descendants' Mem.
Reports information only for process 0.
Matrix 12 56 1787149752 0
Krylov Solver 4 13 31728 0
Vector 8 85 405124904 0
Vector Scatter 0 12 12720 0
Index Set 0 16 15953504 0
Preconditioner 0 13 12540 0
Viewer 1 0 0 0
Matrix 117 76 1166561340 0
Matrix Coarsen 4 4 2480 0
Krylov Solver 10 4 120512 0
Vector 225 175 331789264 0
Vector Scatter 31 22 23320 0
Index Set 81 74 1327712 0
Preconditioner 11 4 3456 0
PetscRandom 4 4 2464 0
Matrix 1 0 0 0
Krylov Solver 1 0 0 0
Vector 10 1 1504 0
Vector Scatter 1 0 0 0
Index Set 5 2 219352 0
Preconditioner 2 0 0 0
Matrix 1 0 0 0
Vector 10 1 1504 0
Index Set 5 2 222304 0
Matrix 1 0 0 0
Vector 10 1 1504 0
Index Set 5 2 222296 0
Average time to get PetscTime(): 2.14577e-07
Average time for MPI_Barrier(): 3.71933e-05
Average time for zero size MPI_Send(): 1.50005e-05
#PETSc Option Table entries:
-log_summary
-poisson_pc_gamg_agg_nsmooths 1
-poisson_pc_type gamg
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure run at: Mon Oct 1 11:36:09 2012
Configure options: --with-mpi-dir=/opt/openmpi-1.5.3/ --with-blas-lapack-dir=/opt/intelcpro-11.1.059/mkl/lib/em64t/ --with-debugging=0 --download-hypre=1 --prefix=/home/wtay/Lib/petsc-3.3-dev_shared_rel --known-mpi-shared=1 --with-shared-libraries
Libraries compiled on Mon Oct 1 11:36:09 2012 on hpc12
Machine characteristics: Linux-2.6.32-279.1.1.el6.x86_64-x86_64-with-centos-6.3-Final
Using PETSc directory: /home/wtay/Codes/petsc-dev
Using PETSc arch: petsc-3.3-dev_shared_rel
