[petsc-users] Enquiry regarding log summary results
Tue Oct 2 07:43:00 CDT 2012
On Tue, Oct 2, 2012 at 8:35 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>  Hi,
> I have combined the momentum linear eqns involving x,y,z into 1 large
> matrix. The Poisson eqn is solved using HYPRE strcut format so it's not
> included. I run the code for 50 timesteps (hence 50 kspsolve) using 96
> procs. The log_summary is given below. I have some questions:
> 1. After combining the matrix, I should have only 1 PETSc matrix. Why does
> it says there are 4 matrix, 12 vector etc?
They are part of preconditioning. Are you sure you're using Hypre for this?
It looks like you are using bjacobi/ilu.
> 2. I'm looking at the stages which take the longest time. It seems that
> MatAssemblyBegin, VecNorm, VecAssemblyBegin, VecScatterEnd have very high
> ratios. The ratios of some others are also not too good (~ 1.6 - 2). So are
> these stages the reason why my code is not scaling well? What can I do to
> improve it?
3/4 of the solve time is evenly balanced between MatMult, MatSolve,
MatLUFactorNumeric, and VecNorm+VecDot.
The high VecAssembly time might be due to generating a lot of entries
off-process?
In any case, this looks like an _extremely_ slow network, perhaps it's
misconfigured?
> Btw, I insert matrix using:
> *do ijk=ijk_xyz_sta+1,ijk_xyz_end**
> **    II = ijk - 1**    !Fortran shift to 0-based**
> **    call
> MatSetValues(A_semi_xyz,1,II,7,int_semi_xyz(ijk,1:7),semi_mat_xyz(ijk,1:7),INSERT_VALUES,ierr)
> **end do*
> where ijk_xyz_sta/ijk_xyz_end are the starting/end index
> int_semi_xyz(ijk,1:7) stores the 7 column global indices
> semi_mat_xyz has the corresponding values.
> and I insert vectors using:
> call
> VecSetValues(b_rhs_semi_xyz,ijk_xyz_end_mz-ijk_xyz_sta_mz,(/ijk_xyz_sta_mz:ijk_xyz_end_mz-1/),q_semi_vect_xyz(ijk_xyz_sta_mz+1:ijk_xyz_end_mz),INSERT_VALUES,ierr)
> Thanks!
> Yours sincerely,
> TAY wee-beng
> On 30/9/2012 11:30 PM, Jed Brown wrote:
> You can measure the time spent in Hypre via PCApply and PCSetUp, but you
> can't get finer grained integrated profiling because it was not set up that
> way.
> On Sep 30, 2012 3:26 PM, "TAY wee-beng" <zonexo at gmail.com> wrote:
>>  On 27/9/2012 1:44 PM, Matthew Knepley wrote:
>> On Thu, Sep 27, 2012 at 3:49 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>> Hi,
>>> I'm doing a log summary for my 3d cfd code. I have some questions:
>>> 1. if I'm solving 3 linear equations using ksp, is the result given in
>>> the log summary the total of the 3 linear eqns' performance? How can I get
>>> the performance for each individual eqn?
>>  Use logging stages:
>> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Profiling/PetscLogStagePush.html
>>> 2. If I run my code for 10 time steps, does the log summary gives the
>>> total or avg performance/ratio?
>>  Total.
>>> 3. Besides PETSc, I'm also using HYPRE's native geometric MG (Struct) to
>>> solve my Cartesian's grid CFD poisson eqn. Is there any way I can use
>>> PETSc's log summary to get HYPRE's performance? If I use boomerAMG thru
>>> PETSc, can I get its performance?
>>  If you mean flops, only if you count them yourself and tell PETSc using
>> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Profiling/PetscLogFlops.html
>>  This is the disadvantage of using packages that do not properly monitor
>> things :)
>>      Matt
>> So u mean if I use boomerAMG thru PETSc, there is no proper way of
>> evaluating its performance, beside using PetscLogFlops?
>>> Yours sincerely,
>>> TAY wee-beng
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121002/4581a8ac/attachment.html>
