[petsc-users] Enquiry regarding log summary results
Barry Smith
bsmith at mcs.anl.gov
Tue Oct 2 17:44:22 CDT 2012
There will always be the "initial" stage for anything that happens before the first stage push(). Not much should be happening in it however.
Barry
On Oct 2, 2012, at 4:55 PM, TAY wee-beng <zonexo at gmail.com> wrote:
> On 27/9/2012 1:44 PM, Matthew Knepley wrote:
>> On Thu, Sep 27, 2012 at 3:49 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>> Hi,
>> I'm doing a log summary for my 3d cfd code. I have some questions:
>> 1. if I'm solving 3 linear equations using ksp, is the result given in the log summary the total of the 3 linear eqns' performance? How can I get the performance for each individual eqn?
>> Use logging stages: http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Profiling/PetscLogStagePush.html
> I retried using :
> PetscLogStage stage
> call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
> call PetscLogStageRegister("momentum",stage,ierr)
> call PetscLogStagePush(stage,ierr)
> ... 1st stage - solving momentum eqn - run 1st logging
> call PetscLogStagePop(ierr)
> call PetscLogStageRegister("poisson",stage,ierr)
> ... 2nd stage - solve poisson eqn - run 2nd logging
> call PetscFinalize(ierr)
> I have attached the log_summary results. Turns out that there are 3 stages - 0,1 (momentum),2 (poisson). Shouldn't I be getting 2 stages instead? How can I correct it? Or it doesn't matter?
>> 2. If I run my code for 10 time steps, does the log summary gives the total or avg performance/ratio?
>> Total.
>> 3. Besides PETSc, I'm also using HYPRE's native geometric MG (Struct) to solve my Cartesian's grid CFD poisson eqn. Is there any way I can use PETSc's log summary to get HYPRE's performance? If I use boomerAMG thru PETSc, can I get its performance?
>> If you mean flops, only if you count them yourself and tell PETSc using http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Profiling/PetscLogFlops.html
>> This is the disadvantage of using packages that do not properly monitor things :)
>> Matt
>> Yours sincerely,
>> TAY wee-beng
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
> <log_summary.txt>
