[petsc-users] Enquiry regarding log summary results
TAY wee-beng zonexo at gmail.com
Tue Oct 2 16:55:50 CDT 2012
On 27/9/2012 1:44 PM, Matthew Knepley wrote:
> On Thu, Sep 27, 2012 at 3:49 AM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     Hi,
>     I'm doing a log summary for my 3d cfd code. I have some questions:
>     1. if I'm solving 3 linear equations using ksp, is the result
>     given in the log summary the total of the 3 linear eqns'
>     performance? How can I get the performance for each individual eqn?
> Use logging stages:
> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Profiling/PetscLogStagePush.html
I retried using :
PetscLogStage  stage
call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
call PetscLogStageRegister("momentum",stage,ierr)
call PetscLogStagePush(stage,ierr)
//... 1st stage - solving momentum eqn//- run 1st logging/
call PetscLogStagePop(ierr)
call PetscLogStageRegister("poisson",stage,ierr)
/... 2nd stage - solve poisson eqn//- run 2nd logging/
call PetscFinalize(ierr)
I have attached the log_summary results. Turns out that there are 3
stages - 0,1 (momentum),2 (poisson). Shouldn't I be getting 2 stages
instead? How can I correct it? Or it doesn't matter?
>     2. If I run my code for 10 time steps, does the log summary gives
>     the total or avg performance/ratio?
> Total.
>     3. Besides PETSc, I'm also using HYPRE's native geometric MG
>     (Struct) to solve my Cartesian's grid CFD poisson eqn. Is there
>     any way I can use PETSc's log summary to get HYPRE's performance?
>     If I use boomerAMG thru PETSc, can I get its performance?
> If you mean flops, only if you count them yourself and tell PETSc
> using
> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Profiling/PetscLogFlops.html
> This is the disadvantage of using packages that do not properly
> monitor things :)
>     Matt
>     Yours sincerely,
>     TAY wee-beng
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121002/a9c99442/attachment.html>
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./a.out on a petsc-3.3-dev_shared_rel named n12-10 with 48 processors, by wtay Tue Oct  2 23:41:57 2012
Using Petsc Development HG revision: 9883b54053eca13dd473a4711adfd309d1436b6e  HG Date: Sun Sep 30 22:42:36 2012 -0500
                         Max       Max/Min        Avg      Total
Time (sec):           1.181e+02      1.01842   1.171e+02
Objects:              3.870e+02      1.00000   3.870e+02
Flops:                2.920e+09      1.25508   2.551e+09  1.224e+11
Flops/sec:            2.475e+07      1.24073   2.179e+07  1.046e+09
MPI Messages:         1.075e+04      3.04562   8.944e+03  4.293e+05
MPI Message Lengths:  2.917e+08      2.17986   3.148e+04  1.351e+10
MPI Reductions:       1.590e+03      1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 8.2603e+01  70.5%  0.0000e+00   0.0%  0.000e+00   0.0%  0.000e+00        0.0%  2.000e+01   1.3%
 1:         poisson: 2.0226e+01  17.3%  6.7061e+10  54.8%  2.461e+05  57.3%  1.799e+04       57.1%  1.279e+03  80.4%
 2:        momentum: 1.4257e+01  12.2%  5.5380e+10  45.2%  1.832e+05  42.7%  1.349e+04       42.9%  2.900e+02  18.2%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %f - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %f %M %L %R  %T %f %M %L %R Mflop/s
--- Event Stage 0: Main Stage
--- Event Stage 1: poisson
MatMult              889 1.0 9.2293e+00 1.3 9.02e+08 1.3 1.6e+05 3.5e+04 0.0e+00  7 30 37 42  0  40 54 65 73  0  3927
MatMultAdd           129 1.0 6.0007e-01 2.2 6.14e+07 1.5 1.5e+04 9.1e+03 0.0e+00  0  2  3  1  0   2  3  6  2  0  3673
MatMultTranspose     129 1.0 1.1698e+00 3.7 6.14e+07 1.5 1.5e+04 9.1e+03 0.0e+00  0  2  3  1  0   3  3  6  2  0  1884
MatSolve              86 0.0 1.3154e-02 0.0 9.23e+06 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   702
MatLUFactorSym         1 1.0 2.6720e-03167.3 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         1 1.0 8.1620e-031006.9 5.33e+06 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   653
MatConvert             3 1.0 4.8410e-02 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               9 1.0 4.9452e-02 2.6 4.65e+06 1.4 5.8e+02 3.3e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0  3655
MatAssemblyBegin      50 1.0 2.3006e+00 3.4 0.00e+00 0.0 1.6e+03 6.5e+03 5.4e+01  1  0  0  0  3   7  0  1  0  4     0
MatAssemblyEnd        50 1.0 6.2769e-01 1.2 0.00e+00 0.0 9.0e+03 4.3e+03 1.4e+02  1  0  2  0  9   3  0  4  1 11     0
MatGetRow         311990 1.2 1.7204e-01 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatGetRowIJ            1 0.0 1.6093e-04 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 0.0 5.0211e-04 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 4.2e-02  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             3 1.0 6.2435e-01 1.1 0.00e+00 0.0 3.1e+04 1.8e+04 3.8e+02  1  0  7  4 24   3  0 13  7 30     0
MatAXPY                3 1.0 1.9019e-02 3.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMatMult             3 1.0 4.3979e-01 1.0 3.24e+06 1.3 4.1e+03 1.4e+04 7.2e+01  0  0  1  0  5   2  0  2  1  6   294
MatMatMultSym          3 1.0 3.5735e-01 1.1 0.00e+00 0.0 3.5e+03 1.1e+04 6.6e+01  0  0  1  0  4   2  0  1  1  5     0
MatMatMultNum          3 1.0 9.2986e-02 1.2 3.24e+06 1.3 5.8e+02 3.3e+04 6.0e+00  0  0  0  0  0   0  0  0  0  0  1393
MatPtAP                3 1.0 1.1116e+00 1.0 1.13e+08 2.5 8.8e+03 2.6e+04 8.1e+01  1  2  2  2  5   5  4  4  3  6  2345
MatPtAPSymbolic        3 1.0 7.1388e-01 1.1 0.00e+00 0.0 7.9e+03 2.1e+04 7.5e+01  1  0  2  1  5   3  0  3  2  6     0
MatPtAPNumeric         3 1.0 4.0797e-01 1.1 1.13e+08 2.5 8.9e+02 6.3e+04 6.0e+00  0  2  0  0  0   2  4  0  1  0  6389
MatTrnMatMult          3 1.0 3.2513e+00 1.0 1.87e+08 5.1 3.4e+03 2.1e+05 8.7e+01  3  6  1  5  5  16 11  1  9  7  2349
MatGetLocalMat        15 1.0 1.3235e-01 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.8e+01  0  0  0  0  1   0  0  0  0  1     0
MatGetBrAoCol          9 1.0 1.8796e-01 2.9 0.00e+00 0.0 4.1e+03 4.7e+04 1.2e+01  0  0  1  1  1   1  0  2  2  1     0
MatGetSymTrans         6 1.0 1.8284e-02 3.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPGMRESOrthog        73 1.0 3.2654e-01 2.3 3.44e+07 1.2 0.0e+00 0.0e+00 7.3e+01  0  1  0  0  5   1  2  0  0  6  4578
KSPSetUp               9 1.0 4.6377e-02 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1     0
KSPSolve               1 1.0 1.9749e+01 1.0 1.56e+09 1.2 2.5e+05 3.1e+04 1.3e+03 17 55 57 57 79  98100100100 99  3396
VecDot                42 1.0 9.3734e-01 2.9 1.16e+07 1.1 0.0e+00 0.0e+00 4.2e+01  0  0  0  0  3   2  1  0  0  3   553
VecDotNorm2           21 1.0 9.9729e-01 3.2 2.32e+07 1.1 0.0e+00 0.0e+00 6.3e+01  0  1  0  0  4   3  2  0  0  5  1040
VecMDot               73 1.0 2.9734e-01 4.0 1.72e+07 1.2 0.0e+00 0.0e+00 7.3e+01  0  1  0  0  5   1  1  0  0  6  2514
VecNorm              141 1.0 6.8643e-01 3.4 9.56e+06 1.2 0.0e+00 0.0e+00 1.4e+02  0  0  0  0  9   2  1  0  0 11   614
VecScale             635 1.0 8.8242e-02 3.7 2.86e+07 1.2 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  2  0  0  0 14090
VecCopy              177 1.0 9.4576e-02 3.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               660 1.0 7.7769e-02 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY             1078 1.0 3.0908e-01 2.2 1.08e+08 1.2 0.0e+00 0.0e+00 0.0e+00  0  4  0  0  0   1  7  0  0  0 15168
VecAYPX             1032 1.0 6.9673e-01 3.5 6.71e+07 1.2 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   2  4  0  0  0  4193
VecAXPBYCZ            42 1.0 2.4312e-01 4.8 2.32e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1  2  0  0  0  4267
VecWAXPY              42 1.0 2.2274e-01 4.6 1.16e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  1  0  0  0  2329
VecMAXPY             119 1.0 8.7651e-02 3.4 2.03e+07 1.2 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 10078
VecAssemblyBegin     115 1.0 3.7941e-01 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 3.4e+02  0  0  0  0 22   1  0  0  0 27     0
VecAssemblyEnd       115 1.0 4.2558e-04 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult     807 1.0 6.0901e-01 2.3 4.20e+07 1.2 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   2  3  0  0  0  3001
VecScatterBegin     1266 1.0 2.3614e-01 2.4 0.00e+00 0.0 2.3e+05 3.0e+04 0.0e+00  0  0 53 50  0   1  0 92 87  0     0
VecScatterEnd       1266 1.0 7.4624e+00 5.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0  18  0  0  0  0     0
VecSetRandom           3 1.0 8.0581e-03 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         119 1.0 5.9730e-01 5.4 5.23e+06 1.2 0.0e+00 0.0e+00 1.2e+02  0  0  0  0  7   2  0  0  0  9   376
PCSetUp                2 1.0 7.8047e+00 1.0 3.19e+08 1.4 6.3e+04 3.2e+04 1.0e+03  7 11 15 15 63  39 20 26 26 78  1759
PCSetUpOnBlocks       43 1.0 1.1463e-0269.3 5.33e+06 0.0 0.0e+00 0.0e+00 5.0e+00  0  0  0  0  0   0  0  0  0  0   465
PCApply               43 1.0 9.7608e+00 1.2 1.17e+09 1.3 1.8e+05 2.9e+04 1.4e+02  8 38 42 38  9  46 69 73 67 11  4774
PCGAMGgraph_AGG        3 1.0 9.0476e-01 1.0 3.24e+06 1.3 1.5e+03 1.8e+04 5.7e+01  1  0  0  0  4   4  0  1  0  4   143
PCGAMGcoarse_AGG       3 1.0 4.0595e+00 1.0 1.87e+08 5.1 3.8e+04 3.8e+04 5.3e+02  3  6  9 11 33  20 11 16 19 41  1881
PCGAMGProl_AGG         3 1.0 5.8402e-01 1.0 0.00e+00 0.0 4.2e+03 2.0e+04 8.4e+01  0  0  1  1  5   3  0  2  1  7     0
PCGAMGPOpt_AGG         3 1.0 1.1830e+00 1.0 8.01e+07 1.2 9.9e+03 2.5e+04 1.6e+02  1  3  2  2 10   6  5  4  3 12  2833
--- Event Stage 2: momentum
MatMult              861 1.0 9.5562e+00 1.3 8.82e+08 1.3 1.5e+05 3.6e+04 0.0e+00  7 29 36 41  0  59 64 84 95  0  3713
MatMultAdd           129 1.0 6.3861e-01 2.1 6.14e+07 1.5 1.5e+04 9.1e+03 0.0e+00  0  2  3  1  0   3  4  8  2  0  3452
MatMultTranspose     129 1.0 1.2222e+00 3.6 6.14e+07 1.5 1.5e+04 9.1e+03 0.0e+00  1  2  3  1  0   4  4  8  2  0  1803
MatSolve              8929.7 7.7899e-02 2.1 2.46e+07 2.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  8874
MatLUFactorNum         1 1.0 1.3516e-01 2.0 8.40e+06 1.3 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  1  0  0  0  2759
MatILUFactorSym        1 1.0 1.2454e-01 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatAssemblyBegin       1 1.0 3.8949e-011845.9 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   2  0  0  0  1     0
MatAssemblyEnd         1 1.0 2.3289e-01 1.2 0.00e+00 0.0 1.9e+02 1.0e+05 8.0e+00  0  0  0  0  1   1  0  0  0  3     0
MatGetRowIJ            1 1.0 5.9605e-06 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 1.0 1.7303e-02 3.4 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  1     0
KSPGMRESOrthog        43 1.0 1.7178e-02 2.5 5.41e+04 0.0 0.0e+00 0.0e+00 4.3e+01  0  0  0  0  3   0  0  0  0 15     3
KSPSetUp               2 1.0 5.8122e-02 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               2 1.0 1.3166e+01 1.0 1.36e+09 1.3 1.8e+05 3.2e+04 2.7e+02 11 45 43 43 17  92100100100 92  4206
VecDot                44 1.0 8.5812e-01 2.4 1.32e+07 1.1 0.0e+00 0.0e+00 4.4e+01  1  0  0  0  3   4  1  0  0 15   691
VecDotNorm2           22 1.0 9.6094e-01 2.1 2.65e+07 1.1 0.0e+00 0.0e+00 6.6e+01  1  1  0  0  4   5  2  0  0 23  1234
VecMDot               43 1.0 1.6975e-02 2.6 2.70e+04 0.0 0.0e+00 0.0e+00 4.3e+01  0  0  0  0  3   0  0  0  0 15     2
VecNorm              110 1.0 7.7599e-01 2.9 7.78e+06 1.2 0.0e+00 0.0e+00 1.1e+02  0  0  0  0  7   3  1  0  0 38   446
VecScale             602 1.0 9.0100e-02 4.2 2.69e+07 1.2 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  2  0  0  0 12970
VecCopy              176 1.0 1.0720e-01 3.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               612 1.0 8.4964e-02 3.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY             1075 1.0 3.5763e-01 3.1 1.07e+08 1.2 0.0e+00 0.0e+00 0.0e+00  0  4  0  0  0   2  8  0  0  0 13071
VecAYPX             1032 1.0 6.9883e-01 4.0 6.71e+07 1.2 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   3  5  0  0  0  4181
VecAXPBYCZ            44 1.0 2.5807e-01 4.7 2.65e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1  2  0  0  0  4595
VecWAXPY              44 1.0 2.3328e-01 4.7 1.32e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  1  0  0  0  2541
VecMAXPY              86 1.0 2.7514e-04 6.2 5.42e+04 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   197
VecAssemblyBegin       4 1.0 1.2141e-0134.8 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  4     0
VecAssemblyEnd         4 1.0 4.1008e-0510.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult     774 1.0 8.1749e-01 3.9 4.02e+07 1.2 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   3  3  0  0  0  2144
VecScatterBegin     1119 1.0 2.4684e-01 3.1 0.00e+00 0.0 1.8e+05 3.2e+04 0.0e+00  0  0 43 43  0   1  0100100  0     0
VecScatterEnd       1119 1.0 8.0261e+00 6.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0  28  0  0  0  0     0
VecNormalize          86 1.0 4.9263e-0194.5 8.13e+04 0.0 0.0e+00 0.0e+00 8.6e+01  0  0  0  0  5   2  0  0  0 30     0
PCSetUp                2 1.0 2.6639e-01 2.1 8.40e+06 1.3 0.0e+00 0.0e+00 5.0e+00  0  0  0  0  0   1  1  0  0  2  1400
PCSetUpOnBlocks       44 1.0 2.6618e-01 2.1 8.40e+06 1.3 0.0e+00 0.0e+00 3.0e+00  0  0  0  0  0   1  1  0  0  1  1401
PCApply               46 1.0 1.0259e+01 1.1 1.18e+09 1.3 1.8e+05 2.9e+04 1.3e+02  8 39 42 38  8  69 85 98 89 44  4609
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Matrix     6             40    183988644     0
       Krylov Solver     2              8        26224     0
              Vector     4             54     42591168     0
      Vector Scatter     0              8         8480     0
           Index Set     0              8      1664536     0
      Preconditioner     0              8         7988     0
              Viewer     1              0            0     0
              Matrix    84             51    118292312     0
      Matrix Coarsen     3              3         1860     0
       Krylov Solver     8              3        90384     0
              Vector   170            129     36025624     0
      Vector Scatter    22             15        15900     0
           Index Set    55             50       424808     0
      Preconditioner     9              3         2592     0
         PetscRandom     3              3         1848     0
              Matrix     1              0            0     0
       Krylov Solver     1              0            0     0
              Vector    10              1         1504     0
      Vector Scatter     1              0            0     0
           Index Set     5              2       205792     0
      Preconditioner     2              0            0     0
Average time to get PetscTime(): 1.90735e-07
Average time for MPI_Barrier(): 3.9196e-05
Average time for zero size MPI_Send(): 2.75373e-05
#PETSc Option Table entries:
-log_summary
-poisson_pc_gamg_agg_nsmooths 1
-poisson_pc_type gamg
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure run at: Mon Oct  1 11:36:09 2012
Configure options: --with-mpi-dir=/opt/openmpi-1.5.3/ --with-blas-lapack-dir=/opt/intelcpro-11.1.059/mkl/lib/em64t/ --with-debugging=0 --download-hypre=1 --prefix=/home/wtay/Lib/petsc-3.3-dev_shared_rel --known-mpi-shared=1 --with-shared-libraries
