[petsc-users] SAME_PRECONDITIONER vs. DIFFERENT_NONZERO_PATTERN
Wed May 30 14:04:46 CDT 2012
On Wed, May 30, 2012 at 1:58 PM, John Fettig <john.fettig at gmail.com> wrote:
> I have a question about the difference between SAME_PRECONDITIONER and
> DIFFERENT_NONZERO_PATTERN.  If you solve multiple RHS's (with
> different initial guesses) but the matrix does not change, should you
> expect to get identical results with SAME_PRECONDITIONER and
> DIFFERENT_NONZERO_PATTERN?
Why are you even calling KSPSetOperators? Just call KSPSolve() for each
right hand side.
> I think it should be, but I'm finding that
> not to be the case with ML.
Are you sure the matrix hasn't changed? What kind of differences are you
observing?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120530/23d9390c/attachment.html>
