[petsc-users] SAME_PRECONDITIONER vs. DIFFERENT_NONZERO_PATTERN
John Fettig
john.fettig at gmail.com
Wed May 30 13:58:00 CDT 2012
I have a question about the difference between SAME_PRECONDITIONER and
DIFFERENT_NONZERO_PATTERN. If you solve multiple RHS's (with
different initial guesses) but the matrix does not change, should you
expect to get identical results with SAME_PRECONDITIONER and
DIFFERENT_NONZERO_PATTERN? I think it should be, but I'm finding that
not to be the case with ML.
John
