[petsc-users] PCComposite
Jed Brown
jedbrown at mcs.anl.gov
Mon May 28 08:20:02 CDT 2012
On Mon, May 28, 2012 at 5:19 AM, Hui Zhang <mike.hui.zhang at hotmail.com>wrote:
> Sorry for repost the following question, but after reading composite.c and
> asm.c,
> I can not understand. I observed that my subroutine for modifying
> submatrices of PCASM was
> called twice. In composite.c it seems there is no calling of PCSetUp on
> its componential PC's.
> In asm.c, the PCSetUp_ASM first determines whether pc->setupcalled is true.
> I think this is a general question for PCComposite say pc. If it consists
> of two pc's pc0, pc1
> and I have PCSetUp(pc0), I would not expect pc0 to be SetUp again. I can
> not understand
> in my case why PCASM seems SetUp twice.
Does the routine do anything or just return immediately? If nothing has
been changed since the last time a PC was set up, it should return
immediately. If you have changed some configuration, it may need to be set
up again.
> Thanks!
> Hui
> > I have got a new question. I'm now constructing a PCComposite from
> PCASM and another PCKSP (coarse
> > problem). And construction of PCKSP needs to use the subksp's of PCASM.
> So I need to PCSetUp on the
> > PCASM, right? But the KSP using PCComposite would setup PCASM again.
> How can I avoid twice setup
> > of PCASM ?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120528/23f5dc22/attachment-0001.html>
