[petsc-users] PCGASMSetLocalSubdomains
Hui Zhang mike.hui.zhang at hotmail.com
Tue May 22 14:43:11 CDT 2012
On May 22, 2012, at 8:14 PM, Dmitry Karpeev wrote:
> It sounds like you need to write a new PC implementation, possibly reusing pieces of PCASM.
Thanks! But then it will be too much work, I think, and what I tried to avoid.
> Then you have control of what is being set up and when. Otherwise you are essentially hacking
> PCASM and using its internal subsolvers, which are only available after PCSetUp().
Yes. Maybe I should follow your advice. Thanks again!
>  PCCOMPOSITE doesn't look like the right framework for this.
> Dmitry.
> On Tue, May 22, 2012 at 5:23 AM, Hui Zhang <mike.hui.zhang at hotmail.com> wrote:
> Hi,
> I have got a new question.  I'm now constructing a PCComposite from PCASM and another PCKSP (coarse
> problem). And construction of PCKSP needs to use the subksp's of PCASM. So I need to PCSetUp on the
> PCASM, right?  But the KSP using PCComposite would setup PCASM again.  How can I avoid twice setup
> of PCASM ?
> Thanks,
> Hui
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120522/569d86f9/attachment-0001.html>
