[petsc-users] Adding a processing on the solution
Mon May 28 08:09:08 CDT 2012
On Mon, May 28, 2012 at 1:48 AM, behzad baghapour <
behzad.baghapour at gmail.com> wrote:
> Besides, Is the SNES context call residual evaluation then Jacobian or
> vise versa? I just concern that the limiting procedure affects both
> residual and Jacobian in the same iteration.
The Jacobian is, by definition, the derivative of the residual. If you are
doing Newton's method, then you are solving with the Jacobian, therefore
the Jacobian also "sees" the limiter.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120528/99b89922/attachment.html>
