[petsc-users] scaling problem
Sat May 26 17:32:37 CDT 2012
That load imbalance often comes from whatever came *before* the reduction.
On May 26, 2012 5:25 PM, "Mark F. Adams" <mark.adams at columbia.edu> wrote:
> Just a few comments on the perf data.  I see a lot (~5x) load imbalance on
> reduction stuff like VecMDot and VecNorm (Time Ratio, max/min) but even a
> lot of imbalance on simple non-collective vector ops like VecAXPY (~3x).
>  So if the work is load balanced well then I would suspect its a NUMA issue.
> Mark
> On May 26, 2012, at 6:13 PM, Aron Roland wrote:
>  Dear All,
> I have some question on some recent implementation of PETSc for solving a
> large linear system from a 4d problem on hybrid unstructured meshes.
> The point is that we have implemented all the mappings and the solution is
> fine, the number of iterations too. The results are robust with respect to
> the amount of CPU used but we have a scaling issue.
> The system is an intel cluster of the latest generation on Infiniband.
> We have attached the summary ... with hooefully a lot of informations.
> Any comments, suggestions, ideas are very welcome.
> We have been reading the threads with that are dealing with multi-core and
> the bus-limitation stuff, so we are aware of this.
> I am thinking now on an open/mpi hybrid stuff but I am not quite happy
> with the bus-limitation explanation, most of the systems are multicore.
> I hope the limitation are not the sparse matrix mapping that we are using
> Thanks in advance ...
> Cheers
> Aron
>  <benchmark.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120526/c039586a/attachment-0001.html>
