[petsc-users] scaling problem
Mark F. Adams mark.adams at columbia.edu
Sat May 26 17:28:33 CDT 2012
Just a few comments on the perf data.  I see a lot (~5x) load imbalance on reduction stuff like VecMDot and VecNorm (Time Ratio, max/min) but even a lot of imbalance on simple non-collective vector ops like VecAXPY (~3x).  So if the work is load balanced well then I would suspect its a NUMA issue.
On May 26, 2012, at 6:13 PM, Aron Roland wrote:
> Dear All,
> I have some question on some recent implementation of PETSc for solving a large linear system from a 4d problem on hybrid unstructured meshes.
> The point is that we have implemented all the mappings and the solution is fine, the number of iterations too. The results are robust with respect to the amount of CPU used but we have a scaling issue.
> The system is an intel cluster of the latest generation on Infiniband.
> We have attached the summary ... with hooefully a lot of informations.
> Any comments, suggestions, ideas are very welcome.
> We have been reading the threads with that are dealing with multi-core and the bus-limitation stuff, so we are aware of this.
> I am thinking now on an open/mpi hybrid stuff but I am not quite happy with the bus-limitation explanation, most of the systems are multicore.
> I hope the limitation are not the sparse matrix mapping that we are using ...
> Thanks in advance ...
> Cheers
> Aron
> <benchmark.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120526/3a82de0e/attachment.html>
