[petsc-users] SLEPc with offline preconditioner
Ye Jianbo Bob yelpoo at gmail.com
Sat May 26 03:47:37 CDT 2012
Hi, I have some problem when using SLEPc to compute eigenvalue
problems. I do not know how to implement my idea properly. Let me
explain in detail.
I am interested in solving a set of eigenvalue problems (to find the
smallest magnitude eigenvalues)
A x = \lambda B_i x
for i=1,2,3,...
where A is the Laplacian of some regular grid, B_i is diagonal. It is
known that A is semi-positive with a null vector [1,1,...,1].
I found SLEPc provides EPSSetDeflationSpace to set deflation space
when applies iterative eigen solver. But I am not sure what default
precondition is used when I defined my problem by setting
eps_smallest_magnitude through EPSSetWhichEigenpairs.
It is possible to use shift-and-invert to explicitly address my
problem. If the shift value is 0, zero pivot will be reported during
LU precondition stage. But since my set of eigen problems has the
exact the same A, I hope I could somehow do the precondition (direct
solver) offline only associate with A and apply the iterative eigen
solver online with set of different B_i.
The very initiative is the direct solver applied in precondition stage
is O(N^2) while the matrix-free eigen solver is O(N), thus I think
this would improve the efficiency of my situation. Is there any way to
realize it?
Here is some rough idea:
To prevent the zero pivot during LU, I would dampshift A with a small
quantity A-\sigma I, and then compute its LU offline and store it. In
online stage, I could build an ST shell that read LU computed in
offline stage and solve. This is only an approximated approach,
hopefully not degrading the performance.
Thank you!
