[petsc-users] vfork problems compiling on Windows
Dominik Szczerba dominik at itis.ethz.ch
Fri May 18 16:49:47 CDT 2012
> Running 'make' in the subfolder' where you got 'vfork' errors should
> update the library with the missing pieces - so you shouldn't have to
> do any more 're-make final library' stuff.
After "make" in the concerned subfolder I came back to the root folder
and issued "make test". But errors were reported during the tests so I
thought the library had not been finalized.
> Alternative way of achieving incremental build is the following
> command in the top-level dir. [But this can also take a while to
> complete]
> make ACTION=lib tree
> BTW: do you have an antivirus or some type of scanner software thats
> running? Would disabling such a thing make the "vfork: Resource
> temporarily unavailable" problem go away?
Thanks for the hints. Yes I have a virus scanner and I believe I once
disabled it for a test and it did not help, but am not absolutely
certain any more. Will try next time the problem occurs.
Dominik
