[petsc-users] How to set up -mat_mumps_icntl13 1 in the code?
Wed May 16 13:02:40 CDT 2012
On May 16, 2012, at 5:51 AM, Giacomo Mulas wrote:
> On Tue, 15 May 2012, Barry Smith wrote:
>>> So, if I understand correctly, I am supposed to call
>>> PetscOptionsInsertString() to add any options I want to have as defaults,
>>> then what is the call PetscOptionsInsert() for?
>>   It "resets" the options database with the command line options. If you
>> did not call this then the InsertString() options would not be overwritten
> Ah ok! It makes sense now that you explain. I could not quite understand
> this from the man pages :(
>>  Ignore the PetscOptionsSetFromOptions() it has nothing to do with
>> anything there (it is just in that example to test it).  It does not
>> affect the options data base entries.
> So I can omit that. Good. However, I suspect this is not the case for the
> similar slepc function EPSSetFromOptions(): I had to put that _after_ the
> PetscOptionsInsertString() call, or inserted options would be ignored by
> slepc. So I suppose the correct sequence should be:
> PetscOptionsInsertString() # this adds my defaults
> PetscOptionsInsert()       # this has command line options replace defaults
> EPSSetFromOptions()        # this applies resulting options to my eps object
> Is that right?
  Yes. Generally I would put the PetscOptionsInsertString() and PetscOptionsInsert() right at the beginning of the program after PetscInitialize() then you don't have to monkey with it later.  Meanwhile EPSSetFromOptions() comes later in the code whenever it comes.
   Barry
> Thanks, bye
> Giacomo
> _________________________________________________________________
> Giacomo Mulas <gmulas at oa-cagliari.inaf.it>
> OSSERVATORIO ASTRONOMICO DI CAGLIARI
> Str. 54, Loc. Poggio dei Pini * 09012 Capoterra (CA)
> Tel. (OAC): +39 070 71180 248     Fax : +39 070 71180 222
> Tel. (UNICA): +39 070 675 4916
> "When the storms are raging around you, stay right where you are"
>                         (Freddy Mercury)
