[petsc-users] Multigrid
Karthik Duraisamy dkarthik at stanford.edu
Tue May 1 17:27:41 CDT 2012
The following was output for the very first iteration whereas what I had attached earlier was output every iteration. I am still a bit perplexed because PCMG drops the residual like a rock (after the first few iterations whereas with no PCMG, it is very slow)
KSP Object: 8 MPI processes
  type: gmres
    GMRES: restart=100, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=1, initial guess is zero
  using preconditioner applied to right hand side for initial guess
  tolerances:  relative=0.01, absolute=1e-08, divergence=1e+10
  left preconditioning
  using DEFAULT norm type for convergence test
PC Object: 8 MPI processes
  type: mg
    MG: type is MULTIPLICATIVE, levels=1 cycles=v
      Cycles per PCApply=1
      Not using Galerkin computed coarse grid matrices
  Coarse grid solver -- level -------------------------------
    KSP Object:    (mg_levels_0_)     8 MPI processes
      type not yet set
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
    PC Object:    (mg_levels_0_)     8 MPI processes
      type not yet set
  linear system matrix = precond matrix:
  Matrix Object:   8 MPI processes
    type: mpiaij
    rows=75000, cols=75000
    total: nonzeros=4427800, allocated nonzeros=4427800
    total number of mallocs used during MatSetValues calls =0
      using I-node (on process 0) routines: found 3476 nodes, limit used is 5
----- Original Message -----
To: "PETSc users list" <petsc-users at mcs.anl.gov>
Sent: Tuesday, May 1, 2012 3:22:56 PM
Subject: Re: [petsc-users] Multigrid
On Tue, May 1, 2012 at 6:18 PM, Karthik Duraisamy < dkarthik at stanford.edu > wrote:
Hello,
Sorry (and thanks for the reply). I've attached the no multigrid case. I didn't include it because (at least to the untrained eye, everything looks the same).
Did you send all the output from the MG case? There must be a PC around it. By default its GMRES, so there would be
an extra GMRES loop compared to the case without MG.
Matt
Karthik
type: gmres
tolerances: relative=1e-05, absolute=1e-50, divergence=1e+10
using nonzero initial guess
using PRECONDITIONED norm type for convergence test
type: bjacobi
block Jacobi: number of blocks = 8
Local solve is same for all blocks, in the following KSP and PC objects:
KSP Object: (sub_) 1 MPI processes
type: preonly
maximum iterations=10000, initial guess is zero
using NONE norm type for convergence test
PC Object: (sub_) 1 MPI processes
type: ilu
ILU: out-of-place factorization
0 levels of fill
tolerance for zero pivot 1e-12
using diagonal shift to prevent zero pivot
matrix ordering: natural
factor fill ratio given 1, needed 1
Factored matrix follows:
Matrix Object: 1 MPI processes
type: seqaij
rows=9015, cols=9015
package used to perform factorization: petsc
total: nonzeros=517777, allocated nonzeros=517777
using I-node routines: found 3476 nodes, limit used is 5
type: seqaij
type: mpiaij
To: "PETSc users list" < petsc-users at mcs.anl.gov >
Sent: Tuesday, May 1, 2012 3:15:14 PM
On Tue, May 1, 2012 at 6:12 PM, Karthik Duraisamy < dkarthik at stanford.edu > wrote:
Hello Barry,
Thank you for your super quick response. I have attached the output of ksp_view and it is practically the same as that when I don't use PCMG. The part I don't understand is how PCMG able to function at the zero grid level and still produce a much better convergence than when using the default PC. Is there any additional smoothing or interpolation going on?
You only included one output, so I have no way of knowing what you used before. However, this is running GMRES/ILU.
Also, for Algebraic Multigrid, would you recommend BoomerAMG or ML ?
They are different algorithms. Its not possible to say generally that one is better. Try them both.
Matt
Best regards,
Karthik.
type: mg
type: gmres
GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
type: bjacobi
KSP Object: (mg_levels_0_sub_) 1 MPI processes
type: preonly
PC Object: (mg_levels_0_sub_) 1 MPI processes
type: ilu
0 levels of fill
type: seqaij
type: seqaij
type: mpiaij
type: mpiaij
Sent: Tuesday, May 1, 2012 1:39:26 PM
On May 1, 2012, at 3:37 PM, Karthik Duraisamy wrote:
> Hello,
> I have been using PETSc for a couple of years with good success, but lately as my linear problems have become stiffer (condition numbers of the order of 1.e20), I am looking to use better preconditioners. I tried using PCMG with all the default options (i.e., I just specified my preconditioner as PCMG and did not add any options to it) and I am immediately seeing better convergence.
> What I am not sure of is why? I would like to know more about the default parameters (the manual is not very explicit) and more importantly, want to know why it is working even when I haven't specified any grid levels and coarse grid operators. Any
> help in this regard will be appreciated.
First run with -ksp_view to see what solver it is actually using.
Barry
> Also, ultimately I want to use algebraic multigrid so is PCML a better option than BoomerAMG? I tried BoomerAMG with mixed results.
> Thanks,
> Karthik
> Karthik Duraisamy
> Assistant Professor (Consulting)
> Durand Building Rm 357
> Dept of Aeronautics and Astronautics
> Stanford University
> Stanford CA 94305
> Phone: 650-721-2835
> Web: www.stanford.edu/~dkarthik
-- Norbert Wiener
-- Norbert Wiener
