[petsc-users] Multigrid
Tue May 1 17:22:56 CDT 2012
On Tue, May 1, 2012 at 6:18 PM, Karthik Duraisamy <dkarthik at stanford.edu>wrote:
> Hello,
>   Sorry (and thanks for the reply). I've attached the no multigrid case. I
> didn't include it because (at least to the untrained eye, everything looks
> the same).
Did you send all the output from the MG case? There must be a PC around it.
By default its GMRES, so there would be
an extra GMRES loop compared to the case without MG.
   Matt
> Regards,
> Karthik
> KSP Object: 8 MPI processes
>  type: gmres
>    GMRES: restart=100, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>    GMRES: happy breakdown tolerance 1e-30
>  maximum iterations=1
>  using preconditioner applied to right hand side for initial guess
>  tolerances:  relative=1e-05, absolute=1e-50, divergence=1e+10
>  left preconditioning
>  using nonzero initial guess
>  using PRECONDITIONED norm type for convergence test
> PC Object: 8 MPI processes
>  type: bjacobi
>    block Jacobi: number of blocks = 8
>    Local solve is same for all blocks, in the following KSP and PC objects:
>  KSP Object:  (sub_)   1 MPI processes
>    type: preonly
>    maximum iterations=10000, initial guess is zero
>    tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>    using NONE norm type for convergence test
>  PC Object:  (sub_)   1 MPI processes
>    type: ilu
>      ILU: out-of-place factorization
>      0 levels of fill
>      tolerance for zero pivot 1e-12
>      using diagonal shift to prevent zero pivot
>      matrix ordering: natural
>      factor fill ratio given 1, needed 1
>        Factored matrix follows:
>          Matrix Object:           1 MPI processes
>            type: seqaij
>            rows=9015, cols=9015
>            package used to perform factorization: petsc
>            total: nonzeros=517777, allocated nonzeros=517777
>            total number of mallocs used during MatSetValues calls =0
>              using I-node routines: found 3476 nodes, limit used is 5
>    linear system matrix = precond matrix:
>      type: seqaij
>  Matrix Object:   8 MPI processes
>    type: mpiaij
>    rows=75000, cols=75000
>    total: nonzeros=4427800, allocated nonzeros=4427800
>      using I-node (on process 0) routines: found 3476 nodes, limit used is
> 5
> From: "Matthew Knepley" <knepley at gmail.com>
> To: "PETSc users list" <petsc-users at mcs.anl.gov>
> Sent: Tuesday, May 1, 2012 3:15:14 PM
> Subject: Re: [petsc-users] Multigrid
> On Tue, May 1, 2012 at 6:12 PM, Karthik Duraisamy < dkarthik at stanford.edu> wrote:
> Hello Barry,
> Thank you for your super quick response. I have attached the output of
> ksp_view and it is practically the same as that when I don't use PCMG. The
> part I don't understand is how PCMG able to function at the zero grid level
> and still produce a much better convergence than when using the default PC.
> Is there any additional smoothing or interpolation going on?
> You only included one output, so I have no way of knowing what you used
> before. However, this is running GMRES/ILU.
> Also, for Algebraic Multigrid, would you recommend BoomerAMG or ML ?
> They are different algorithms. Its not possible to say generally that one
> is better. Try them both.
> Matt
> Best regards,
> Karthik.
> type: mg
> MG: type is MULTIPLICATIVE, levels=1 cycles=v
> Cycles per PCApply=1
> Not using Galerkin computed coarse grid matrices
> Coarse grid solver -- level -------------------------------
> KSP Object: (mg_levels_0_) 8 MPI processes
> type: gmres
> GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> maximum iterations=1, initial guess is zero
> PC Object: (mg_levels_0_) 8 MPI processes
> type: bjacobi
> KSP Object: (mg_levels_0_sub_) 1 MPI processes
> type: preonly
> PC Object: (mg_levels_0_sub_) 1 MPI processes
> type: ilu
> 0 levels of fill
> type: seqaij
> type: seqaij
> type: mpiaij
> using I-node (on process 0) routines: found 3476 nodes, limit used is 5
> type: mpiaij
> From: "Barry Smith" < bsmith at mcs.anl.gov >
> To: "PETSc users list" < petsc-users at mcs.anl.gov >
> Sent: Tuesday, May 1, 2012 1:39:26 PM
> On May 1, 2012, at 3:37 PM, Karthik Duraisamy wrote:
> > Hello,
> > I have been using PETSc for a couple of years with good success, but
> lately as my linear problems have become stiffer (condition numbers of the
> order of 1.e20), I am looking to use better preconditioners. I tried using
> PCMG with all the default options (i.e., I just specified my preconditioner
> as PCMG and did not add any options to it) and I am immediately seeing
> better convergence.
> > What I am not sure of is why? I would like to know more about the
> default parameters (the manual is not very explicit) and more importantly,
> want to know why it is working even when I haven't specified any grid
> levels and coarse grid operators. Any
> > help in this regard will be appreciated.
> First run with -ksp_view to see what solver it is actually using.
> Barry
> > Also, ultimately I want to use algebraic multigrid so is PCML a better
> option than BoomerAMG? I tried BoomerAMG with mixed results.
> > Thanks,
> > Karthik
> > Karthik Duraisamy
> > Assistant Professor (Consulting)
> > Durand Building Rm 357
> > Dept of Aeronautics and Astronautics
> > Stanford University
> > Stanford CA 94305
> > Phone: 650-721-2835
> > Web: www.stanford.edu/~dkarthik
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120501/7fa99aba/attachment.htm>
