[petsc-users] GAMG issue
John Mousel john.mousel at gmail.com
Fri Mar 30 09:52:45 CDT 2012
Mark,
I've run GAMG twice with different coarse grid sizes of 2 and 8 with 1
sweep of SOR on the coarse grid. For a size of 8 it converges nicely, but
for a size of 2, I think the null space is causing too many problems. If
GAMG were to coarsen to a size of 1, then there would be no hope because
only the null space would remain, right? This doesn't ever seem to occur
with ML because there are at least as many rows as processors.
John
On Fri, Mar 30, 2012 at 8:42 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
> On Mar 29, 2012, at 2:40 PM, John Mousel wrote:
> I'm attempting to solve a non-symmetric discretization of a 3D Poisson
> problem. The problem is singular. I've attached the results of KSPView from
> runs with ML and GAMG. When I run ML, I get convergence in 30 iterations.
> When I attempt to use the same settings with GAMG, I'm not getting
> convergence at all. The two things I notice are:
> 1. GAMG is using KSPType preonly, even though I've set it to be Richardson
> in my command line options.
> PETSc seems to switch the coarse grid solver to GMRES in Setup.  This
> seems to be a bug and I unwisely decide to override this manually. I will
> undo this in the next checkin.  This should not be the problem however.
> 2. ML only coarsens down to 4 rows while GAMG coarsens to 2. My problem is
> singular, and whenever I try to use LU, I get zero pivot problems. To
> mitigate this, I've been using Richardson with SOR on the coarse matrix.
> Could the smaller coarse grid size of GAMG be causing problems with SOR. If
> so, is there a way to put a lower limit on the coarse grid size?
> I'm thinking that with a 2x2 coarse grid 8 iterations of SOR is picking up
> the null space.  Maybe try just one SOR iteration on the coarse grid.
> Also, can you run with options_left so that I can see your arguments.  One
> known bug is the mat_diagaonal_scale breaks GAMG, but it should also break
> ML.
> Mark
> John
> On Thu, Mar 29, 2012 at 11:03 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> On Thu, Mar 29, 2012 at 09:18, John Mousel <john.mousel at gmail.com> wrote:
>>> [0]PETSC ERROR: Error in external library!
>>> [0]PETSC ERROR: Cannot disable floating point exceptions!
>> Looks like something is strange with your environment because fesetenv()
>> is returning an error. I have disabled the call if the trap mode is not
>> changing.
>> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/352b4c19e451
> <KSPView_GAMG.txt><KSPView_ML.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120330/f464616b/attachment-0001.htm>
  Residual norms for pres_ solve.
  0 KSP preconditioned resid norm 5.016797113851e+03 true resid norm 1.537048121012e+01 ||r(i)||/||b|| 1.000000000000e+00
  2 KSP preconditioned resid norm 2.593195031348e+03 true resid norm 1.577483110619e+02 ||r(i)||/||b|| 1.026306911966e+01
  4 KSP preconditioned resid norm 4.642597221361e+02 true resid norm 3.165516339207e+01 ||r(i)||/||b|| 2.059477706608e+00
  6 KSP preconditioned resid norm 1.121148735724e+02 true resid norm 1.634561891940e+01 ||r(i)||/||b|| 1.063442236840e+00
  8 KSP preconditioned resid norm 4.092437868938e+02 true resid norm 4.290066631217e+01 ||r(i)||/||b|| 2.791107560375e+00
 10 KSP preconditioned resid norm 2.364490073524e+01 true resid norm 9.278095018184e-01 ||r(i)||/||b|| 6.036307446299e-02
 12 KSP preconditioned resid norm 1.118938046010e+01 true resid norm 8.235420783716e-01 ||r(i)||/||b|| 5.357945968727e-02
 14 KSP preconditioned resid norm 8.827495203651e-01 true resid norm 1.253023900141e-02 ||r(i)||/||b|| 8.152144900421e-04
 16 KSP preconditioned resid norm 5.786122993849e-02 true resid norm 2.785770732954e-03 ||r(i)||/||b|| 1.812416081755e-04
 18 KSP preconditioned resid norm 1.482851639037e-02 true resid norm 7.572356321341e-04 ||r(i)||/||b|| 4.926557742613e-05
 20 KSP preconditioned resid norm 2.833429772564e-02 true resid norm 4.152766547014e-04 ||r(i)||/||b|| 2.701780438911e-05
 22 KSP preconditioned resid norm 2.727719252108e-03 true resid norm 1.753161236491e-04 ||r(i)||/||b|| 1.140602699762e-05
 24 KSP preconditioned resid norm 5.417522429762e-05 true resid norm 1.308360805994e-05 ||r(i)||/||b|| 8.512165547116e-07
 26 KSP preconditioned resid norm 1.274290782774e-05 true resid norm 1.317046021128e-05 ||r(i)||/||b|| 8.568671358587e-07
KSP Object:(pres_) 4 MPI processes
  type: bcgsl
    BCGSL: Ell = 2
    BCGSL: Delta = 0
  maximum iterations=1000
  tolerances:  relative=1e-08, absolute=1e-50, divergence=10000
  left preconditioning
  has attached null space
  using nonzero initial guess
  using PRECONDITIONED norm type for convergence test
PC Object:(pres_) 4 MPI processes
  type: ml
    MG: type is MULTIPLICATIVE, levels=6 cycles=v
      Cycles per PCApply=1
      Using Galerkin computed coarse grid matrices
  Coarse grid solver -- level -------------------------------
    KSP Object:    (pres_mg_coarse_)     4 MPI processes
      type: richardson
        Richardson: damping factor=1
      maximum iterations=1, initial guess is zero
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
    PC Object:    (pres_mg_coarse_)     4 MPI processes
      type: sor
        SOR: type = local_symmetric, iterations = 8, local iterations = 1, omega = 1
      linear system matrix = precond matrix:
      Matrix Object:       4 MPI processes
        type: mpiaij
        rows=4, cols=4
        total: nonzeros=16, allocated nonzeros=16
        total number of mallocs used during MatSetValues calls =0
          not using I-node (on process 0) routines
  Down solver (pre-smoother) on level 1 -------------------------------
    KSP Object:    (pres_mg_levels_1_)     4 MPI processes
      type: richardson
    PC Object:    (pres_mg_levels_1_)     4 MPI processes
      type: sor
        SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1
        type: mpiaij
        rows=7, cols=7
        total: nonzeros=39, allocated nonzeros=39
          using I-node (on process 0) routines: found 1 nodes, limit used is 5
  Up solver (post-smoother) same as down solver (pre-smoother)
  Down solver (pre-smoother) on level 2 -------------------------------
    KSP Object:    (pres_mg_levels_2_)     4 MPI processes
      type: richardson
    PC Object:    (pres_mg_levels_2_)     4 MPI processes
      type: sor
        type: mpiaij
        rows=78, cols=78
        total: nonzeros=2914, allocated nonzeros=2914
          using I-node (on process 0) routines: found 4 nodes, limit used is 5
  Down solver (pre-smoother) on level 3 -------------------------------
    KSP Object:    (pres_mg_levels_3_)     4 MPI processes
      type: richardson
    PC Object:    (pres_mg_levels_3_)     4 MPI processes
      type: sor
        type: mpiaij
        rows=889, cols=889
        total: nonzeros=75418, allocated nonzeros=75418
  Down solver (pre-smoother) on level 4 -------------------------------
    KSP Object:    (pres_mg_levels_4_)     4 MPI processes
      type: richardson
    PC Object:    (pres_mg_levels_4_)     4 MPI processes
      type: sor
        type: mpiaij
        rows=16562, cols=16562
        total: nonzeros=1527407, allocated nonzeros=1527407
  Down solver (pre-smoother) on level 5 -------------------------------
    KSP Object:    (pres_mg_levels_5_)     4 MPI processes
      type: richardson
    PC Object:    (pres_mg_levels_5_)     4 MPI processes
      type: sor
        type: mpiaij
        rows=178085, cols=178085
        total: nonzeros=4676387, allocated nonzeros=8374105
    type: mpiaij
WARNING! There are options you set that were not used!
WARNING! could be spelling mistake, etc!
Option left: name:-pres_options_left no value
Options:
-pres_ksp_type bcgsl
-pres_pc_type ml -pres_pc_ml_Threshold .01
-pres_mg_coarse_ksp_type richardson -pres_mg_coarse_pc_type sor -pres_mg_coarse_pc_sor_its 8
-pres_ksp_monitor_true_residual -pres_ksp_view  -pres_options_left
RUN 1:
Options:
-pres_pc_type gamg -pres_pc_gamg_sym_graph -pres_pc_gamg_coarse_eq_limit 2 -pres_pc_gamg_agg_nsmooths 1 -pres_pc_gamg_threshold 0.01
-pres_mg_levels_ksp_type richardson -pres_mg_levels_pc_type sor
-pres_mg_coarse_ksp_type richardson -pres_mg_coarse_pc_type sor -pres_mg_coarse_pc_sor_its 1
-pres_ksp_monitor_true_residual -pres_pc_gamg_verbose 2 -pres_ksp_view -pres_options_left
	[0]PCSetFromOptions_GAMG threshold set 1.000000e-02
	[0]PCSetUp_GAMG level 0 N=178085, n data rows=1, n data cols=1, nnz/row (ave)=26, np=4
	[0]PCGAMGFilterGraph 64.0278% nnz after filtering, with threshold 0.01, 26.2593 nnz ave.
	[0]maxIndSetAgg removed 0 of 178085 vertices. (0 local)  6937 selected.
		[0]PCGAMGProlongator_AGG New grid 6937 nodes
			PCGAMGOptprol_AGG smooth P0: max eigen=1.927344e+00 min=4.441888e-02 PC=jacobi
		[0]PCSetUp_GAMG 1) N=6937, n data cols=1, nnz/row (ave)=63, 4 active pes
	[0]PCGAMGFilterGraph 32.3853% nnz after filtering, with threshold 0.01, 63.4622 nnz ave.
	[0]maxIndSetAgg removed 0 of 6937 vertices. (0 local)  167 selected.
		[0]PCGAMGProlongator_AGG New grid 167 nodes
			PCGAMGOptprol_AGG smooth P0: max eigen=4.364217e+00 min=5.712156e-03 PC=jacobi
	[0]createLevel aggregate processors: npe: 4 --> 2, neq=167
		[0]PCSetUp_GAMG 2) N=167, n data cols=1, nnz/row (ave)=58, 2 active pes
	[0]PCGAMGFilterGraph 19.7613% nnz after filtering, with threshold 0.01, 58.2096 nnz ave.
	[0]maxIndSetAgg removed 0 of 167 vertices. (0 local)  8 selected.
		[0]PCGAMGProlongator_AGG New grid 8 nodes
			PCGAMGOptprol_AGG smooth P0: max eigen=1.459581e+00 min=1.292445e-03 PC=jacobi
	[0]createLevel aggregate processors: npe: 2 --> 1, neq=8
		[0]PCSetUp_GAMG 3) N=8, n data cols=1, nnz/row (ave)=8, 1 active pes
	[0]PCGAMGFilterGraph 56.25% nnz after filtering, with threshold 0.01, 8 nnz ave.
	[0]maxIndSetAgg removed 0 of 8 vertices. (0 local)  2 selected.
		[0]PCGAMGProlongator_AGG New grid 2 nodes
			PCGAMGOptprol_AGG smooth P0: max eigen=2.426409e+00 min=3.017187e-14 PC=jacobi
		[0]PCSetUp_GAMG 4) N=2, n data cols=1, nnz/row (ave)=2, 1 active pes
	[0]PCSetUp_GAMG 5 levels, grid complexity = 1.09623
  0 KSP preconditioned resid norm 3.214004976835e+04 true resid norm 1.537048121012e+01 ||r(i)||/||b|| 1.000000000000e+00
  2 KSP preconditioned resid norm 9.962575667075e+03 true resid norm 1.666562709330e+01 ||r(i)||/||b|| 1.084261895609e+00
  4 KSP preconditioned resid norm 9.964216763945e+03 true resid norm 1.668511403642e+01 ||r(i)||/||b|| 1.085529711681e+00
  6 KSP preconditioned resid norm 1.009624086413e+04 true resid norm 1.899567590778e+01 ||r(i)||/||b|| 1.235854339764e+00
  8 KSP preconditioned resid norm 1.119961784740e+04 true resid norm 4.344299871311e+01 ||r(i)||/||b|| 2.826391582620e+00
 10 KSP preconditioned resid norm 3.270474238322e+04 true resid norm 5.485695179461e+02 ||r(i)||/||b|| 3.568980765449e+01
 12 KSP preconditioned resid norm 6.862047100670e+04 true resid norm 1.392424526518e+03 ||r(i)||/||b|| 9.059082194521e+01
 14 KSP preconditioned resid norm 8.020735170110e+04 true resid norm 1.708524744698e+03 ||r(i)||/||b|| 1.111562300062e+02
 16 KSP preconditioned resid norm 7.957648213223e+04 true resid norm 1.697241325110e+03 ||r(i)||/||b|| 1.104221333027e+02
 18 KSP preconditioned resid norm 7.987861582440e+04 true resid norm 1.720588721880e+03 ||r(i)||/||b|| 1.119411096087e+02
 20 KSP preconditioned resid norm 7.781283925015e+04 true resid norm 1.570743019621e+03 ||r(i)||/||b|| 1.021921824144e+02
 22 KSP preconditioned resid norm 7.613701956079e+04 true resid norm 1.437142018083e+03 ||r(i)||/||b|| 9.350013174194e+01
 24 KSP preconditioned resid norm 7.441069686260e+04 true resid norm 1.291829388291e+03 ||r(i)||/||b|| 8.404612520790e+01
 26 KSP preconditioned resid norm 7.381709754141e+04 true resid norm 1.239993290391e+03 ||r(i)||/||b|| 8.067368050748e+01
 28 KSP preconditioned resid norm 4.660758247799e+05 true resid norm 1.986383272864e+04 ||r(i)||/||b|| 1.292336424416e+03
 30 KSP preconditioned resid norm 3.843023238140e+05 true resid norm 1.626650509205e+04 ||r(i)||/||b|| 1.058295109287e+03
 32 KSP preconditioned resid norm 3.807302107274e+05 true resid norm 1.621607637493e+04 ||r(i)||/||b|| 1.055014228459e+03
 34 KSP preconditioned resid norm 1.576847461172e+05 true resid norm 3.774334039228e+03 ||r(i)||/||b|| 2.455573112925e+02
 36 KSP preconditioned resid norm 1.485636406237e+05 true resid norm 3.409895452504e+03 ||r(i)||/||b|| 2.218470200047e+02
 38 KSP preconditioned resid norm 1.453089145230e+05 true resid norm 3.119776988055e+03 ||r(i)||/||b|| 2.029719789125e+02
 40 KSP preconditioned resid norm 1.494647504254e+05 true resid norm 2.103792395208e+03 ||r(i)||/||b|| 1.368722531487e+02
 42 KSP preconditioned resid norm 1.492528384367e+05 true resid norm 2.105571540467e+03 ||r(i)||/||b|| 1.369880039332e+02
 44 KSP preconditioned resid norm 1.495172887683e+05 true resid norm 2.098100475867e+03 ||r(i)||/||b|| 1.365019381752e+02
 46 KSP preconditioned resid norm 1.486262786592e+05 true resid norm 2.164181004195e+03 ||r(i)||/||b|| 1.408011222687e+02
 48 KSP preconditioned resid norm 1.660465856506e+05 true resid norm 4.172426666954e+03 ||r(i)||/||b|| 2.714571268079e+02
 50 KSP preconditioned resid norm 1.482759191221e+05 true resid norm 2.856097129241e+03 ||r(i)||/||b|| 1.858170274696e+02
 52 KSP preconditioned resid norm 1.685729081672e+05 true resid norm 5.947178479153e+03 ||r(i)||/||b|| 3.869220747128e+02
 54 KSP preconditioned resid norm 1.569362853302e+05 true resid norm 5.573721373030e+03 ||r(i)||/||b|| 3.626250406110e+02
 56 KSP preconditioned resid norm 1.572502232797e+05 true resid norm 5.614318099048e+03 ||r(i)||/||b|| 3.652662543416e+02
 58 KSP preconditioned resid norm 1.563201382830e+05 true resid norm 5.430932820022e+03 ||r(i)||/||b|| 3.533352499365e+02
 60 KSP preconditioned resid norm 1.575394042371e+05 true resid norm 5.517707804827e+03 ||r(i)||/||b|| 3.589808106460e+02
 62 KSP preconditioned resid norm 1.574611644503e+05 true resid norm 5.514851203197e+03 ||r(i)||/||b|| 3.587949607958e+02
 64 KSP preconditioned resid norm 1.584082961150e+05 true resid norm 5.573531260888e+03 ||r(i)||/||b|| 3.626126719584e+02
 66 KSP preconditioned resid norm 1.634951153589e+05 true resid norm 5.910135540989e+03 ||r(i)||/||b|| 3.845120696090e+02
 68 KSP preconditioned resid norm 1.647079886374e+05 true resid norm 6.000249380861e+03 ||r(i)||/||b|| 3.903748554672e+02
 70 KSP preconditioned resid norm 1.650191144351e+05 true resid norm 6.022517993959e+03 ||r(i)||/||b|| 3.918236463536e+02
 72 KSP preconditioned resid norm 1.542157148610e+05 true resid norm 5.403131962522e+03 ||r(i)||/||b|| 3.515265324917e+02
 74 KSP preconditioned resid norm 1.554195380312e+05 true resid norm 5.450251819441e+03 ||r(i)||/||b|| 3.545921396302e+02
 76 KSP preconditioned resid norm 1.532469232837e+05 true resid norm 5.409499245974e+03 ||r(i)||/||b|| 3.519407865001e+02
 78 KSP preconditioned resid norm 1.222695504853e+05 true resid norm 8.087451810483e+03 ||r(i)||/||b|| 5.261677692406e+02
 80 KSP preconditioned resid norm 1.144385291371e+05 true resid norm 8.086187300487e+03 ||r(i)||/||b|| 5.260855005089e+02
 82 KSP preconditioned resid norm 1.139628084163e+05 true resid norm 8.074654763408e+03 ||r(i)||/||b|| 5.253351962782e+02
 84 KSP preconditioned resid norm 9.849803475030e+04 true resid norm 8.340298610024e+03 ||r(i)||/||b|| 5.426179243193e+02
 86 KSP preconditioned resid norm 9.841631558189e+04 true resid norm 8.334019324969e+03 ||r(i)||/||b|| 5.422093954666e+02
 88 KSP preconditioned resid norm 9.602058427463e+04 true resid norm 8.471718963816e+03 ||r(i)||/||b|| 5.511681025470e+02
 90 KSP preconditioned resid norm 9.627762519493e+04 true resid norm 8.455558776172e+03 ||r(i)||/||b|| 5.501167244267e+02
 92 KSP preconditioned resid norm 9.628212912916e+04 true resid norm 8.455709739147e+03 ||r(i)||/||b|| 5.501265460433e+02
 94 KSP preconditioned resid norm 9.944415339754e+04 true resid norm 8.303497811687e+03 ||r(i)||/||b|| 5.402236727774e+02
 96 KSP preconditioned resid norm 1.360957681260e+05 true resid norm 9.342234268251e+03 ||r(i)||/||b|| 6.078036296028e+02
 98 KSP preconditioned resid norm 1.028254804925e+06 true resid norm 1.639833993379e+05 ||r(i)||/||b|| 1.066872254006e+04
100 KSP preconditioned resid norm 2.878267699013e+06 true resid norm 5.284924897012e+05 ||r(i)||/||b|| 3.438360077844e+04
102 KSP preconditioned resid norm 3.284723758217e+06 true resid norm 6.019019818184e+05 ||r(i)||/||b|| 3.915960558360e+04
104 KSP preconditioned resid norm 3.490898600321e+06 true resid norm 6.386257805102e+05 ||r(i)||/||b|| 4.154884754615e+04
106 KSP preconditioned resid norm 4.292371780598e+06 true resid norm 7.825387697929e+05 ||r(i)||/||b|| 5.091179378807e+04
108 KSP preconditioned resid norm 4.272469798938e+06 true resid norm 7.783966012792e+05 ||r(i)||/||b|| 5.064230524980e+04
110 KSP preconditioned resid norm 3.932496986313e+06 true resid norm 7.284977182706e+05 ||r(i)||/||b|| 4.739589530814e+04
112 KSP preconditioned resid norm 3.938646883327e+06 true resid norm 7.296330278220e+05 ||r(i)||/||b|| 4.746975828848e+04
114 KSP preconditioned resid norm 3.108284574985e+06 true resid norm 6.043424330292e+05 ||r(i)||/||b|| 3.931838078246e+04
116 KSP preconditioned resid norm 3.382223114783e+06 true resid norm 3.235035948244e+05 ||r(i)||/||b|| 2.104707005604e+04
118 KSP preconditioned resid norm 3.034407011811e+06 true resid norm 3.294035179204e+05 ||r(i)||/||b|| 2.143091770630e+04
Linear solve did not converge due to DIVERGED_ITS iterations 118
  type: bcgsl
    BCGSL: Ell = 2
    BCGSL: Delta = 0
  maximum iterations=120
  type: gamg
    MG: type is MULTIPLICATIVE, levels=5 cycles=v
      type: preonly
      using NONE norm type for convergence test
      type: sor
        type: mpiaij
        rows=2, cols=2
        total: nonzeros=4, allocated nonzeros=4
      type: richardson
      type: sor
        type: mpiaij
        rows=8, cols=8
        total: nonzeros=64, allocated nonzeros=64
          using I-node (on process 0) routines: found 2 nodes, limit used is 5
      type: richardson
      type: sor
        type: mpiaij
        rows=167, cols=167
        total: nonzeros=9721, allocated nonzeros=9721
      type: richardson
      type: sor
        type: mpiaij
        rows=6937, cols=6937
        total: nonzeros=440237, allocated nonzeros=440237
      type: richardson
      type: sor
        type: mpiaij
    type: mpiaij
Option left: name: -pres_options_left no value
RUN2:
Options:
-pres_pc_type gamg -pres_pc_gamg_sym_graph -pres_pc_gamg_coarse_eq_limit 8 -pres_pc_gamg_agg_nsmooths 1 -pres_pc_gamg_threshold 0.01
	[0]PCSetUp_GAMG 4 levels, grid complexity = 1.09623
  0 KSP preconditioned resid norm 1.210558693457e+04 true resid norm 1.537048121012e+01 ||r(i)||/||b|| 1.000000000000e+00
  2 KSP preconditioned resid norm 4.471234066863e+03 true resid norm 5.782528108610e+01 ||r(i)||/||b|| 3.762099591783e+00
  4 KSP preconditioned resid norm 5.705586099552e+02 true resid norm 1.766618406384e+01 ||r(i)||/||b|| 1.149357903786e+00
  6 KSP preconditioned resid norm 2.630493890369e+02 true resid norm 4.130300513941e+00 ||r(i)||/||b|| 2.687164089060e-01
  8 KSP preconditioned resid norm 1.622096002911e+01 true resid norm 3.985823191611e-01 ||r(i)||/||b|| 2.593167472849e-02
 10 KSP preconditioned resid norm 1.166276779499e+01 true resid norm 1.933128706628e-01 ||r(i)||/||b|| 1.257689125149e-02
 12 KSP preconditioned resid norm 8.600869344082e-01 true resid norm 1.497599703252e-02 ||r(i)||/||b|| 9.743349494267e-04
 14 KSP preconditioned resid norm 1.478956802605e-01 true resid norm 1.829141074894e-03 ||r(i)||/||b|| 1.190035009242e-04
 16 KSP preconditioned resid norm 2.089299129489e-02 true resid norm 3.275473585379e-04 ||r(i)||/||b|| 2.131015640046e-05
 18 KSP preconditioned resid norm 1.222936568425e-03 true resid norm 4.389356922168e-05 ||r(i)||/||b|| 2.855705597088e-06
 20 KSP preconditioned resid norm 2.108428382409e-03 true resid norm 2.784330122700e-05 ||r(i)||/||b|| 1.811478824012e-06
 22 KSP preconditioned resid norm 1.051218867616e-04 true resid norm 1.044274089421e-05 ||r(i)||/||b|| 6.794023395530e-07
Linear solve converged due to CONVERGED_RTOL iterations 22
  type: bcgsl
    BCGSL: Ell = 2
    BCGSL: Delta = 0
  type: gamg
    MG: type is MULTIPLICATIVE, levels=4 cycles=v
      type: preonly
      type: sor
        type: mpiaij
        rows=8, cols=8
      type: richardson
      type: sor
        type: mpiaij
        rows=167, cols=167
      type: richardson
      type: sor
        type: mpiaij
      type: richardson
      type: sor
        type: mpiaij
    type: mpiaij
