[petsc-users] ex52_integrateElement.cu
David Fuentes
fuentesdt at gmail.com
Wed Mar 28 13:14:50 CDT 2012
thanks! its running, but I seem to be getting different answer for cpu/gpu ?
i had some floating point problems on this Tesla M2070 gpu before, but
adding the '-arch=sm_20' option seemed to fix it last time.
is the assembly in single precision ? my 'const PetscReal jacobianInverse'
being passed in are doubles
SCRGP2$ ./ex52 -dim 2 -compute_function -show_residual -batch -gpu
GPU layout grid(1,2,1) block(3,1,1) with 1 batches
N_t: 3, N_cb: 1
Residual:
Vector Object: 1 MPI processes
type: seq
0
755712
0
-58720
-2953.13
0.375
1.50323e+07
0.875
0
SCRGP2$
Residual:
type: seq
-0.25
-0.5
0.25
-0.5
-1
0.5
0.25
0.5
0.75
On Wed, Mar 28, 2012 at 11:55 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Mar 28, 2012 at 11:45 AM, David Fuentes <fuentesdt at gmail.com>wrote:
>> The example seems to be running on cpu with '-batch' but i'm getting
>> errors in line 323 with the '-gpu' option
>> [0]PETSC ERROR: IntegrateElementBatchGPU() line 323 in
>> src/snes/examples/tutorials/ex52_integrateElement.cu
>> should this possibly be PetscScalar ?
> No.
>> - ierr = cudaMalloc((void**) &d_coefficients, Ne*N_bt *
>> sizeof(float));CHKERRQ(ierr);
>> + ierr = cudaMalloc((void**) &d_coefficients, Ne*N_bt *
>> sizeof(PetscScalar));CHKERRQ(ierr);
>> SCRGP2$ python $PETSC_DIR/bin/pythonscripts/PetscGenerateFEMQuadrature.py
>> 2 1 1 1 laplacian ex52.h
>> ['/opt/apps/PETSC/petsc-dev/bin/pythonscripts/PetscGenerateFEMQuadrature.py',
>> '2', '1', '1', '1', 'laplacian', 'ex52.h']
>> 2 1 1 1 laplacian
>> [{(-1.0, -1.0): [(1.0, ())]}, {(1.0, -1.0): [(1.0, ())]}, {(-1.0, 1.0):
>> [(1.0, ())]}]
>> {0: {0: [0], 1: [1], 2: [2]}, 1: {0: [], 1: [], 2: []}, 2: {0: []}}
>> Perm: [0, 1, 2]
>> Creating /home/fuentes/snestutorial/ex52.h
>> Creating /home/fuentes/snestutorial/ex52_gpu.h
>> [(1.0, ())]}]
>> Perm: [0, 1, 2]
>> Creating /home/fuentes/snestutorial/ex52_gpu_inline.h
>> SCRGP2$ make ex52
>> /usr/bin/mpicxx -o ex52.o -c -O0 -g -fPIC
>> -I/opt/apps/PETSC/petsc-dev/include
>> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/include
>> -I/opt/apps/cuda/4.1/cuda/include -I/opt/apps/PETSC/petsc-dev/include/sieve
>> -I/opt/MATLAB/R2011a/extern/include -I/usr/include
>> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/cbind/include
>> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/forbind/include
>> -I/usr/include/mpich2 -D__INSDIR__=src/snes/examples/tutorials/ ex52.c
>> nvcc -O0 -g -arch=sm_20 -c --compiler-options="-O0 -g -fPIC
>> -I/usr/include/mpich2 -D__INSDIR__=src/snes/examples/tutorials/"
>> ex52_gpu_inline.h(7): warning: variable "points_0" was declared but never
>> referenced
>> ex52_gpu_inline.h(21): warning: variable "Basis_0" was declared but never
>> referenced
>> referenced
>> ex52_gpu_inline.h(13): warning: variable "weights_0" was declared but
>> never referenced
>> referenced
>> ex52_gpu_inline.h(28): warning: variable "BasisDerivatives_0" was
>> declared but never referenced
>> referenced
>> referenced
>> referenced
>> never referenced
>> referenced
>> /usr/bin/mpicxx -O0 -g -o ex52 ex52.o ex52_integrateElement.o
>> -Wl,-rpath,/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/lib
>> -L/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/lib -lpetsc
>> -ltriangle -lX11 -lpthread -lsuperlu_dist_3.0 -lcmumps -ldmumps -lsmumps
>> -lzmumps -lmumps_common -lpord -lparmetis -lmetis -lscalapack -lblacs
>> -Wl,-rpath,/opt/apps/cuda/4.1/cuda/lib64 -L/opt/apps/cuda/4.1/cuda/lib64
>> -lcufft -lcublas -lcudart -lcusparse
>> -Wl,-rpath,/opt/MATLAB/R2011a/sys/os/glnxa64:/opt/MATLAB/R2011a/bin/glnxa64:/opt/MATLAB/R2011a/extern/lib/glnxa64
>> -L/opt/MATLAB/R2011a/bin/glnxa64 -L/opt/MATLAB/R2011a/extern/lib/glnxa64
>> -leng -lmex -lmx -lmat -lut -licudata -licui18n -licuuc
>> -Wl,-rpath,/opt/epd-7.1-2-rh5-x86_64/lib -L/opt/epd-7.1-2-rh5-x86_64/lib
>> -lmkl_rt -lmkl_intel_thread -lmkl_core -liomp5 -lexoIIv2for -lexodus
>> -lnetcdf_c++ -lnetcdf -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.4.3
>> -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -ldl -lmpich -lopa -lpthread -lrt
>> -lgcc_s -lmpichf90 -lgfortran -lm -lm -lmpichcxx -lstdc++ -lmpichcxx
>> -lstdc++ -ldl -lmpich -lopa -lpthread -lrt -lgcc_s -ldl
>> /bin/rm -f ex52.o ex52_integrateElement.o
>> Residual:
>> type: seq
>> -0.25
>> -0.5
>> 0.25
>> -0.5
>> -1
>> 0.5
>> 0.25
>> 0.5
>> 0.75
>> [0]PETSC ERROR: FormFunctionLocalBatch() line 679 in
>> src/snes/examples/tutorials/ex52.c
>> [0]PETSC ERROR: SNESDMComplexComputeFunction() line 431 in
>> src/snes/utils/damgsnes.c
>> [0]PETSC ERROR: main() line 1021 in src/snes/examples/tutorials/ex52.c
>> application called MPI_Abort(MPI_COMM_WORLD, 35) - process 0
> This is failing on cudaMalloc(), which means your card is not available
> for running. Are you trying to run on your laptop?
> If so, applications like Preview can lock up the GPU. I know of no way to
> test this in CUDA while running. I just close
> apps until it runs.
> Thanks,
> Matt
>> On Tue, Mar 27, 2012 at 8:37 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Tue, Mar 27, 2012 at 2:10 PM, Blaise Bourdin <bourdin at lsu.edu> wrote:
>>>> On Mar 27, 2012, at 1:23 PM, Matthew Knepley wrote:
>>>> On Tue, Mar 27, 2012 at 12:58 PM, David Fuentes <fuentesdt at gmail.com>wrote:
>>>>> Hi,
>>>>> I had a question about the status of example 52.
>>>>> http://petsc.cs.iit.edu/petsc/petsc-dev/file/a8e2f2c19319/src/snes/examples/tutorials/ex52.c
>>>>> http://petsc.cs.iit.edu/petsc/petsc-dev/file/a8e2f2c19319/src/snes/examples/tutorials/ex52_integrateElement.cu
>>>>> Can this example be used with a DM object created from an unstructured
>>>>> exodusII mesh, DMMeshCreateExodus, And the FEM assembly done on GPU ?
>>>> 1) I have pushed many more tests for it now. They can be run using the
>>>> Python build system
>>>> ./config/builder2.py check src/snes/examples/tutorials/ex52.c
>>>> in fact, you can build any set of files this way.
>>>> 2) The Exodus creation has to be converted to DMComplex from DMMesh.
>>>> That should not take me very long. Blaise maintains that
>>>> so maybe there will be help :) You will just replace
>>>> DMComplexCreateBoxMesh() with DMComplexCreateExodus(). If you request
>>>> it, I will bump it up the list.
>>>> DMMeshCreateExodusNG is much more flexible than DMMeshCreateExodus in
>>>> that it can read meshes with multiple element types and should have a much
>>>> lower memory footprint. The code should be fairly easy to read. you can
>>>> email me directly if you have specific questions. I had looked at creating
>>>> a DMComplex and it did not look too difficult, as long as interpolation is
>>>> not needed. I have plans to write DMComplexCreateExodus, but haven't had
>>>> time too so far. Updating the Vec viewers and readers may be a bit more
>>>> involved. In perfect world, one would write an EXODUS viewer following the
>>>> lines of the VTK and HDF5 ones.
>>> David and Blaise, I have converted this function, now
>>> DMComplexCreateExodus(). Its not tested, but I think
>>> Blaise has some stuff we can use to test it.
>>> Thanks,
>>> Matt
>>>> Blaise
>>>> Let me know if you can run the tests.
>>>> Thanks
>>>> Matt
>>>>> Thanks,
>>>>> David
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> Department of Mathematics and Center for Computation & Technology
>>>> Louisiana State University, Baton Rouge, LA 70803, USA
>>>> Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276
>>>> http://www.math.lsu.edu/~bourdin
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120328/23eabe35/attachment.htm>
