[petsc-users] ex52_integrateElement.cu
Matthew Knepley
knepley at gmail.com
Wed Mar 28 11:55:46 CDT 2012
On Wed, Mar 28, 2012 at 11:45 AM, David Fuentes <fuentesdt at gmail.com> wrote:
> The example seems to be running on cpu with '-batch' but i'm getting
> errors in line 323 with the '-gpu' option
> [0]PETSC ERROR: IntegrateElementBatchGPU() line 323 in
> src/snes/examples/tutorials/ex52_integrateElement.cu
> should this possibly be PetscScalar ?
No.
> - ierr = cudaMalloc((void**) &d_coefficients, Ne*N_bt *
> sizeof(float));CHKERRQ(ierr);
> + ierr = cudaMalloc((void**) &d_coefficients, Ne*N_bt *
> sizeof(PetscScalar));CHKERRQ(ierr);
> SCRGP2$ python $PETSC_DIR/bin/pythonscripts/PetscGenerateFEMQuadrature.py
> 2 1 1 1 laplacian ex52.h
> ['/opt/apps/PETSC/petsc-dev/bin/pythonscripts/PetscGenerateFEMQuadrature.py',
> '2', '1', '1', '1', 'laplacian', 'ex52.h']
> 2 1 1 1 laplacian
> [{(-1.0, -1.0): [(1.0, ())]}, {(1.0, -1.0): [(1.0, ())]}, {(-1.0, 1.0):
> [(1.0, ())]}]
> {0: {0: [0], 1: [1], 2: [2]}, 1: {0: [], 1: [], 2: []}, 2: {0: []}}
> Perm: [0, 1, 2]
> Creating /home/fuentes/snestutorial/ex52.h
> Creating /home/fuentes/snestutorial/ex52_gpu.h
> [(1.0, ())]}]
> Perm: [0, 1, 2]
> Creating /home/fuentes/snestutorial/ex52_gpu_inline.h
> SCRGP2$ make ex52
> /usr/bin/mpicxx -o ex52.o -c -O0 -g -fPIC
> -I/opt/apps/PETSC/petsc-dev/include
> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/include
> -I/opt/apps/cuda/4.1/cuda/include -I/opt/apps/PETSC/petsc-dev/include/sieve
> -I/opt/MATLAB/R2011a/extern/include -I/usr/include
> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/cbind/include
> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/forbind/include
> -I/usr/include/mpich2 -D__INSDIR__=src/snes/examples/tutorials/ ex52.c
> nvcc -O0 -g -arch=sm_20 -c --compiler-options="-O0 -g -fPIC
> -I/usr/include/mpich2 -D__INSDIR__=src/snes/examples/tutorials/"
> ex52_gpu_inline.h(7): warning: variable "points_0" was declared but never
> referenced
> ex52_gpu_inline.h(21): warning: variable "Basis_0" was declared but never
> referenced
> referenced
> ex52_gpu_inline.h(13): warning: variable "weights_0" was declared but
> never referenced
> referenced
> ex52_gpu_inline.h(28): warning: variable "BasisDerivatives_0" was declared
> but never referenced
> referenced
> referenced
> referenced
> never referenced
> referenced
> /usr/bin/mpicxx -O0 -g -o ex52 ex52.o ex52_integrateElement.o
> -Wl,-rpath,/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/lib
> -L/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/lib -lpetsc
> -ltriangle -lX11 -lpthread -lsuperlu_dist_3.0 -lcmumps -ldmumps -lsmumps
> -lzmumps -lmumps_common -lpord -lparmetis -lmetis -lscalapack -lblacs
> -Wl,-rpath,/opt/apps/cuda/4.1/cuda/lib64 -L/opt/apps/cuda/4.1/cuda/lib64
> -lcufft -lcublas -lcudart -lcusparse
> -Wl,-rpath,/opt/MATLAB/R2011a/sys/os/glnxa64:/opt/MATLAB/R2011a/bin/glnxa64:/opt/MATLAB/R2011a/extern/lib/glnxa64
> -L/opt/MATLAB/R2011a/bin/glnxa64 -L/opt/MATLAB/R2011a/extern/lib/glnxa64
> -leng -lmex -lmx -lmat -lut -licudata -licui18n -licuuc
> -Wl,-rpath,/opt/epd-7.1-2-rh5-x86_64/lib -L/opt/epd-7.1-2-rh5-x86_64/lib
> -lmkl_rt -lmkl_intel_thread -lmkl_core -liomp5 -lexoIIv2for -lexodus
> -lnetcdf_c++ -lnetcdf -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.4.3
> -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -ldl -lmpich -lopa -lpthread -lrt
> -lgcc_s -lmpichf90 -lgfortran -lm -lm -lmpichcxx -lstdc++ -lmpichcxx
> -lstdc++ -ldl -lmpich -lopa -lpthread -lrt -lgcc_s -ldl
> /bin/rm -f ex52.o ex52_integrateElement.o
> SCRGP2$ ./ex52 -dim 2 -compute_function -show_residual -batch
> Residual:
> Vector Object: 1 MPI processes
> type: seq
> -0.25
> -0.5
> 0.25
> -0.5
> -1
> 0.5
> 0.25
> 0.5
> 0.75
> SCRGP2$ ./ex52 -dim 2 -compute_function -show_residual -batch -gpu
> [0]PETSC ERROR: FormFunctionLocalBatch() line 679 in
> src/snes/examples/tutorials/ex52.c
> [0]PETSC ERROR: SNESDMComplexComputeFunction() line 431 in
> src/snes/utils/damgsnes.c
> [0]PETSC ERROR: main() line 1021 in src/snes/examples/tutorials/ex52.c
> application called MPI_Abort(MPI_COMM_WORLD, 35) - process 0
This is failing on cudaMalloc(), which means your card is not available for
running. Are you trying to run on your laptop?
If so, applications like Preview can lock up the GPU. I know of no way to
test this in CUDA while running. I just close
apps until it runs.
Matt
> On Tue, Mar 27, 2012 at 8:37 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Tue, Mar 27, 2012 at 2:10 PM, Blaise Bourdin <bourdin at lsu.edu> wrote:
>>> On Mar 27, 2012, at 1:23 PM, Matthew Knepley wrote:
>>> On Tue, Mar 27, 2012 at 12:58 PM, David Fuentes <fuentesdt at gmail.com>wrote:
>>>> Hi,
>>>> I had a question about the status of example 52.
>>>> http://petsc.cs.iit.edu/petsc/petsc-dev/file/a8e2f2c19319/src/snes/examples/tutorials/ex52.c
>>>> http://petsc.cs.iit.edu/petsc/petsc-dev/file/a8e2f2c19319/src/snes/examples/tutorials/ex52_integrateElement.cu
>>>> Can this example be used with a DM object created from an unstructured
>>>> exodusII mesh, DMMeshCreateExodus, And the FEM assembly done on GPU ?
>>> 1) I have pushed many more tests for it now. They can be run using the
>>> Python build system
>>> ./config/builder2.py check src/snes/examples/tutorials/ex52.c
>>> in fact, you can build any set of files this way.
>>> 2) The Exodus creation has to be converted to DMComplex from DMMesh.
>>> That should not take me very long. Blaise maintains that
>>> so maybe there will be help :) You will just replace
>>> DMComplexCreateBoxMesh() with DMComplexCreateExodus(). If you request
>>> it, I will bump it up the list.
>>> DMMeshCreateExodusNG is much more flexible than DMMeshCreateExodus in
>>> that it can read meshes with multiple element types and should have a much
>>> lower memory footprint. The code should be fairly easy to read. you can
>>> email me directly if you have specific questions. I had looked at creating
>>> a DMComplex and it did not look too difficult, as long as interpolation is
>>> not needed. I have plans to write DMComplexCreateExodus, but haven't had
>>> time too so far. Updating the Vec viewers and readers may be a bit more
>>> involved. In perfect world, one would write an EXODUS viewer following the
>>> lines of the VTK and HDF5 ones.
>> David and Blaise, I have converted this function, now
>> DMComplexCreateExodus(). Its not tested, but I think
>> Blaise has some stuff we can use to test it.
>> Thanks,
>> Matt
>>> Blaise
>>> Let me know if you can run the tests.
>>> Thanks
>>> Matt
>>>> Thanks,
>>>> David
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> Department of Mathematics and Center for Computation & Technology
>>> Louisiana State University, Baton Rouge, LA 70803, USA
>>> Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276
>>> http://www.math.lsu.edu/~bourdin
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120328/7e65531a/attachment-0001.htm>
