[petsc-users] Preconditioners memory use
Jarunan Panyasantisuk jarunan at ascomp.ch
Tue Mar 27 09:32:49 CDT 2012
Dear Petsc List,
In case you have an experience about precondtiioners performance tests:
Does the preconditioner Block Jacobi generally consume memory more than
HYPRE/BoomerAMG? I use GMRES as a solver and -log_summary to print out
the performance result. The results of my test case shows that BJACOBI
uses more memory than AMG. I thought it is other way round. If you have
similar results, please share your experience.
Thank you
Jarunan
