[petsc-users] Saving graphical matrix structure to a file
    Habbal, Feras (353G-Affiliate)
    Feras.A.Habbal at jpl.nasa.gov
    Thu Mar 22 16:01:13 CDT 2012
Thank you very much for your response! I will definitely make use of this
feature.
On 3/22/12 1:58 PM, "Barry Smith" <bsmith at mcs.anl.gov> wrote:
>   Feras,
>      You are in luck, we do have a mechanism that automatically save
>PETSc X images as Gif files.  I delayed responding so I could clean up
>the code for you to use.
>   1) It is only in petsc-dev
>http://www.mcs.anl.gov/petsc/developers/index.html
>    2) you must first install afterimage (easy) which installs in
>/usr/local
>     3) ./configure PETSc with the additional option --with-afterimage
>    4) when running your program just use the extra command line option
>-draw_save  or use the function PetscDrawSetSave() on the draw object you
>create before using it
>    5) If you want to generate a movie of all the images once the problem
>is complete also install ffmpeg  and also use the run time option
>-draw_save_movie
>     6) When generating your images make sure they are all open and
>fulling displayed on the screen, afterimage will not function if the
>window is not fully visible.
>     7) Report all problems to petsc-maint at mcs.anl.gov
>     8) Have fun
>     9) Like all PETSc graphics this is a useful tool for debugging and
>algorithmic development etc, it is not intended to produce publication
>quality graphics
>    Barry
>On Mar 21, 2012, at 6:02 PM, Habbal, Feras (353G-Affiliate) wrote:
>> Ok, no problem. Thank you for your assistance!
>> From: Matthew Knepley <knepley at gmail.com>
>> Reply-To: PETSc users list <petsc-users at mcs.anl.gov>
>> Date: Wed, 21 Mar 2012 15:43:07 -0700
>> Subject: Re: [petsc-users] Saving graphical matrix structure to a file
>> On Wed, Mar 21, 2012 at 5:31 PM, Habbal, Feras (353G-Affiliate)
>><Feras.A.Habbal at jpl.nasa.gov> wrote:
>>> I tried using the commands from the previous post:
>>> xwd | xpr -device ps > foo.ps
>> That worked fine for me when I made movies this way. I'm not sure what
>>else to recommend.
>>    Matt
>>> But the output was bizarre: reversed and had some artifacts.
>>> I can certainly use the mac screen capture tools, but I am needing an
>>>automated capability to capture the structure of several matrices
>>>(~1000) during a run.
>>> Feras
>>> Date: Wed, 21 Mar 2012 15:14:39 -0700
>>> On Wed, Mar 21, 2012 at 5:11 PM, Habbal, Feras (353G-Affiliate)
>>>> Hello,
>>>> I am trying to save the matrix structure visualization from
>>>>(-mat_view_draw) to a file (jpeg, ps, or anything else).
>>>> I saw the post: "help in capturing matrix patterns to files,"
>>> The easiest thing to do is use screen capture for that window.
>>>     Matt
>>>> but adding the options did not work for me:
>>>>  mat_view_draw draw_type ps
>>>> I have been trying to do this with the example file:
>>>>ksp/examples/tutorials/ex1.c
>>>> I included "petscdraw.h"
>>>> $ mpiexec ex1 -mat_view_draw -draw_type ps
>>>> [0]PETSC ERROR: --------------------- Error Message
>>>> [0]PETSC ERROR: Unknown type. Check for miss-spelling or missing
>>>>external package needed for type
>>>>seehttp://www.mcs.anl.gov/petsc/petsc-as/documentation/installation.htm
>>>>l#external!
>>>> [0]PETSC ERROR: Unknown PetscDraw type given: ps!
>>>> [0]PETSC ERROR:
>>>> [0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 3, Fri Sep 30
>>>>10:28:33 CDT 2011
>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>> [0]PETSC ERROR:
>>>> [0]PETSC ERROR: ex1 on a macosx-gn named habbalf.jpl.nasa.gov by
>>>>habbalf Wed Mar 21 14:56:30 2012
>>>> [0]PETSC ERROR: Libraries linked from
>>>>/Users/habbalf/issm/trunk-jpl/externalpackages/petsc/install/lib
>>>> [0]PETSC ERROR: Configure run at Tue Mar  6 11:39:23 2012
>>>> [0]PETSC ERROR: Configure options
>>>>--prefix=/Users/habbalf/issm/trunk-jpl/externalpackages/petsc/install
>>>>--PETSC_DIR=/Users/habbalf/issm/trunk-jpl/externalpackages/petsc/src
>>>>--PETSC_ARCH=macosx-gnu
>>>>--with-mpi-dir=/Users/habbalf/issm/trunk-jpl/externalpackages/mpich2/in
>>>>stall --with-debugging=1 --download-c2html=1 --with-shared-libraries=0
>>>>--download-mumps=yes --download-scalapack=yes --download-blacs=yes
>>>>--download-blas=yes --download-plapack=yes --download-parmetis=yes
>>>>--download-f-blas-lapack=yes
>>>> [0]PETSC ERROR:
>>>> [0]PETSC ERROR: PetscDrawSetType() line 147 in
>>>>src/sys/draw/interface/drawreg.c
>>>> [0]PETSC ERROR: PetscDrawSetFromOptions() line 278 in
>>>> [0]PETSC ERROR: PetscViewerDrawGetDraw() line 109 in
>>>>src/sys/viewer/impls/draw/drawv.c
>>>> [0]PETSC ERROR: MatView_SeqAIJ_Draw() line 752 in
>>>>src/mat/impls/aij/seq/aij.c
>>>> [0]PETSC ERROR: MatView_SeqAIJ() line 781 in
>>>> [0]PETSC ERROR: MatView() line 757 in src/mat/interface/matrix.c
>>>> [0]PETSC ERROR: MatView_Private() line 4881 in
>>>> [0]PETSC ERROR: MatAssemblyEnd() line 4965 in
>>>> [0]PETSC ERROR: main() line 89 in src/ksp/ksp/examples/tutorials/ex1.c
>>>> application called MPI_Abort(MPI_COMM_WORLD, 86) - process 0
>>>> Thank you for your assistance,
>>>> Feras
>>> What most experimenters take for granted before they begin their
>>>experiments is infinitely more interesting than any results to which
>>>their experiments lead.
>>> -- Norbert Wiener
>> -- Norbert Wiener
