[petsc-users] real and complex numbers
Jed Brown
jedbrown at mcs.anl.gov
Sun Mar 18 14:57:42 CDT 2012
On Sun, Mar 18, 2012 at 14:52, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Just run your single code in complex numbers (where the nonlinear part
> may have zero imaginary part). You are introducing a complicated work flow
> (saving to files ...) (that is also not well supported in PETSc) just to
> save some work on the nonlinear part when generally most nonlinear solvers
> spend much more time in the linear solve than the nonlinear computations.
> Make your life easy, just use complex numbers; your time is much more
> valuable than the computers.
Also, if the nonlinear function is very expensive, you can read the state
from the Vec into PetscReal locally (e.g. one stencil at a time) and
compute with reals.
Writing to files creates a _serious_ bottleneck that will likely take
orders of magnitude longer than everything else your code does if you scale
it to large problems/computers.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120318/ffbfc303/attachment.htm>
