[petsc-users] real and complex numbers
    Barry Smith
    bsmith at mcs.anl.gov
    Sun Mar 18 14:52:41 CDT 2012
  Just run your single code in complex numbers (where the nonlinear part may have zero imaginary part). You are introducing a complicated work flow (saving to files ...) (that is also not well supported in PETSc) just to save some work on the nonlinear part when generally most nonlinear solvers spend much more time in the linear solve than the nonlinear computations. Make your life easy, just use complex numbers; your time is much more valuable than the computers.
    Barry
On Mar 18, 2012, at 9:43 AM, Xavier Garnaud wrote:
> Dear PETSc team,
> I am performing nonlinear and linearized computations. Nonlinear computations are performed using real numbers (it would be approximately twice slower to use complex numbers instead). For linearized computations however, it is much more convenient to use complex numbers. These two types of computations are performed separately: first a run a nonlinear simulation, I save the result on the disk, and then I load it in a different code to perform linear operations.
> I would therefore like to be able to use VecView using a  version of PETSc compiled with real numbers and VecLoad using a version compiled for complex numbers. I would like to do this using binary or HDF5 format. I tried to create a real vector with twice the size of my non-linear result and fill every other element with a 0, but it does not work. Is there a way to do this using existing functions?
> Thank you very much,
> Sincerely,
> Xavier
