[petsc-users] GAMG issue
John Mousel john.mousel at gmail.com
Wed Mar 14 11:54:02 CDT 2012
Mark,
I have a non-symmetric matrix. I am running with the following options.
-pc_type gamg -pc_gamg_sym_graph -ksp_monitor_true_residual
and with the inclusion of -pc_gamg_sym_graph, I get a new malloc error:
0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Argument out of range!
[0]PETSC ERROR: New nonzero at (5150,9319) caused a malloc!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Development HG revision:
587b25035091aaa309c87c90ac64c13408ecf34e  HG Date: Wed Mar 14 09:22:54 2012
-0500
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ../JohnRepo/VFOLD_exe on a linux-deb named
wv.iihr.uiowa.eduby jmousel Wed Mar 14 11:51:35 2012
[0]PETSC ERROR: Libraries linked from
/home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/linux-debug/lib
[0]PETSC ERROR: Configure run at Wed Mar 14 09:46:39 2012
[0]PETSC ERROR: Configure options --download-blacs=1 --download-hypre=1
--download-metis=1 --download-ml=1 --download-mpich=1 --download-parmetis=1
--download-scalapack=1 --with-blas-lapack-dir=/opt/intel11/mkl/lib/em64t
--with-cc=gcc --with-cmake=/usr/local/bin/cmake --with-cxx=g++
--with-fc=ifort PETSC_ARCH=linux-debug
[0]PETSC ERROR:
[0]PETSC ERROR: MatSetValues_MPIAIJ() line 506 in
/home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/src/mat/impls/aij/mpi/mpiaij.c
[0]PETSC ERROR: MatSetValues() line 1141 in
/home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/src/mat/interface/matrix.c
[0]PETSC ERROR: scaleFilterGraph() line 155 in
/home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/src/ksp/pc/impls/gamg/tools.c
[0]PETSC ERROR: PCGAMGgraph_AGG() line 865 in
/home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/src/ksp/pc/impls/gamg/agg.c
[0]PETSC ERROR: PCSetUp_GAMG() line 516 in
/home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/src/ksp/pc/impls/gamg/gamg.c
[0]PETSC ERROR: PCSetUp() line 832 in
/home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: KSPSetUp() line 261 in
/home/jmousel/NumericalLibraries/petsc-hg/petsc-dev/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: KSPSolve() line 385 in
John
On Wed, Mar 14, 2012 at 11:27 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
> On Mar 14, 2012, at 11:56 AM, John Mousel wrote:
> Mark,
> The matrix is asymmetric. Does this require the setting of an option?
> Yes:  -pc_gamg_sym_graph
> Mark
> I pulled petsc-dev this morning, so I should have (at least close to) the
> latest code.
> John
> On Wed, Mar 14, 2012 at 10:54 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
>> On Mar 14, 2012, at 11:08 AM, John Mousel wrote:
>> I'm getting the following error when using GAMG.
>> petsc-dev/src/ksp/pc/impls/gamg/agg.c:508: smoothAggs: Assertion
>> `sgid==-1' failed.
>> Is it possible that your matrix is structurally asymmetric?
>> This code is evolving fast and so you will need to move to the dev
>> version if you are not already using it. (I think I fixed a bug that hit
>> this assert).
>> When I try to alter the type of aggregation at the command line using
>> -pc_gamg_type pa, I'm getting
>> [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
>> [1]PETSC ERROR: Unknown type. Check for miss-spelling or missing external
>> package needed for type:
>> see http://www.mcs.anl.gov/petsc/documentation/installation.html#external
>> [1]PETSC ERROR: Unknown GAMG type pa given!
>> Has there been a change in the aggregation options? I just pulled
>> petsc-dev this morning.
>> Yes, this option is gone now.  You can use -pc_gamg_type agg for now.
>> Mark
>> John
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120314/26635f09/attachment.htm>
