[petsc-users] GAMG issue
    Mark F. Adams
    mark.adams at columbia.edu
    Wed Mar 14 11:27:44 CDT 2012
On Mar 14, 2012, at 11:56 AM, John Mousel wrote:
> Mark,
> The matrix is asymmetric. Does this require the setting of an option?
Yes:  -pc_gamg_sym_graph
> I pulled petsc-dev this morning, so I should have (at least close to) the latest code.
> John
> On Wed, Mar 14, 2012 at 10:54 AM, Mark F. Adams <mark.adams at columbia.edu> wrote:
> On Mar 14, 2012, at 11:08 AM, John Mousel wrote:
>> I'm getting the following error when using GAMG.
>> petsc-dev/src/ksp/pc/impls/gamg/agg.c:508: smoothAggs: Assertion `sgid==-1' failed.
> Is it possible that your matrix is structurally asymmetric?
> This code is evolving fast and so you will need to move to the dev version if you are not already using it. (I think I fixed a bug that hit this assert).
>> When I try to alter the type of aggregation at the command line using -pc_gamg_type pa, I'm getting
>> [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message ------------------------------------
>> [1]PETSC ERROR: Unknown type. Check for miss-spelling or missing external package needed for type:
>> see http://www.mcs.anl.gov/petsc/documentation/installation.html#external!
>> [1]PETSC ERROR: Unknown GAMG type pa given!
>> Has there been a change in the aggregation options? I just pulled petsc-dev this morning.
> Yes, this option is gone now.  You can use -pc_gamg_type agg for now.
> Mark
>> John
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120314/a8563415/attachment.htm>
