[petsc-users] system upgrade
Francis Poulin
fpoulin at uwaterloo.ca
Tue Mar 13 18:47:57 CDT 2012
Hello,
Sorry for not thinking of this myself. Thanks for pointing out that it was Xcode and also telling me about the command line tools. That saved me from sending another email.
It seems to be installing very nicely right now.
Cheers, Francis
On 2012-03-13, at 6:00 PM, Sean Farley wrote:
> I was using petsc on my Mac OS x 10.6 perfectly fine and then decided (perhaps foolishly) to upgrade to lion, 10.7. When I type the same configure line as before,
> ./configure --with-cc=/usr/local/bin/gcc --with-fc=/usr/local/bin/gfortran --with-clanguage=cxx --download-f-blas-lapack=1 --download-mpich=1
> Any ideas what I need to do to configure it like I had before (that doesn't involve going back to 10.6)?
> Depending on how you upgraded (or perhaps did a clean install), you'll need to install Xcode 4.3.1 and make sure that you check (it's not checked by default) to install command line tools. This is done from the 'Downloads' section of Xcode's preferences.
> P.S. I tried before with both log files but the first was too big so i'm only including the one that failed. I presume that's the more interesting one anyhow.
> You could send to petsc-maint instead (and / or try zipping)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120313/565a1afa/attachment.htm>
