[petsc-users] [petsc-maint #107932] run a simple example ex19 in src/snes/examples/tutorials
Paul Mullowney paulm at txcorp.com
Tue Mar 13 10:18:35 CDT 2012
I don't think PCJACOBI is working on the GPU yet.
I have some local fixes to make it work efficiently (without extra
copies), but changes won't be pushed too soon because the design is not
sufficiently general.
-Paul
> 2012/3/13 Xiangze Zeng <zengshixiangze at 163.com
> <mailto:zengshixiangze at 163.com>>
>     I do set preallocation after setting the matrix type.
> Run with -info to make sure it is used (i.e. that the matrix type
> isn't changed later). Note that PCSOR does not run on the GPU, so it
> will do lots of copying (run with -log_summary to see). You should
> start by running PCJACOBI on the GPU.
>     Zeng
>     在 2012-03-13 22:14:12,"Jed Brown" <jedbrown at mcs.anl.gov
>     <mailto:jedbrown at mcs.anl.gov>> 写道:
>             At the beginning and end of  the codes for setting the
>             matrices values, I add "printf", and compute the time of
>             this period. It is much longer than that when I don't use
>             the GPU. I just guess the time is used for copping
>             data. My PCTYPE is sor. And 2000 iterations.  Do you have
>             any suggestion about this?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120313/4c40d705/attachment.htm>
