[petsc-users] MATLAB Classes
Barry Smith
bsmith at mcs.anl.gov
Mon Mar 12 19:16:03 CDT 2012
Please send all the error output from MATLAB when it crashes to petsc-maint at mcs.anl.gov. In particular you may need to run MATLAB from a terminal with matlab -nodesktop to get the traceback as it crashes.
Barry
On Mar 12, 2012, at 5:27 PM, Jeremy Roberts wrote:
> Hi all,
> I'm trying access PETSc from MATLAB via the classes. I'm working on a 64 bit Ubuntu 11.04 system with MATLAB R2011b and PETSc 3.2-p6.
> I get PETSc built, but running e.g. "exKSP.m" leads to a segmentation fault at ksp.Solve(A,b,x). As a second test, I added MatMult to matlabheader.h, and that worked using A,x, and b of the exKSP example. My guess is that something goofy is happening with BLAS/LAPACK. I tried to run "valgrind matlab -nodesktop -nosplash < exKSP.m" without success (maybe there's another way to include valgrind?).
> I configured via:
> ./configure \
> PETSC_ARCH=gcc-matlab \
> --with-debugging \
> --with-cc=gcc-4.3 \
> --with-fc=gfortran-4.3 \
> --with-cxx=g++-4.3 \
> --with-shared-libraries \
> --with-matlab-engine \
> --with-matlab \
> --download-f2cblaslapack \
> --with-mpi=0 \
> --with-x=0 \
> --with-x11=0
> Any suggestions are greatly appreciated.
> Jeremy
