[petsc-users] segv in VecSum when using nested vec
Tue Mar 6 10:07:29 CST 2012
On Tue, Mar 6, 2012 at 09:52, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> >Could you get a stack trace with gdb? Also, I ran on petsc-dev.
> Breakpoint 1, vecsumsegv::vecsumsegv (this=0x7fffffffd310, m=3, n=4)
>    at vecsumsegv.cc:28
> 28        ierr = VecSum(x,&val);
> (gdb) next
This was fixed in petsc-dev.
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/3b9bc425b217
Why are you using VecNest? It causes more harm than good in all but some
very special circumstances.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120306/a62ccfec/attachment.htm>
