[petsc-users] segv in VecSum when using nested vec
Klaij, Christiaan
C.Klaij at marin.nl
Tue Mar 6 09:52:43 CST 2012
>> >> In a larger code I'm getting a segmentation fault when setting a null
>> space
>> >> with KSPSetNullSpace. After some trying I can reproduce the problem with
>> >> the small code below. It happens when calling VecSum on a nested vec.
>> >Runs for me:
>> >and it was valgrind clean. Are you running on multiple processes?
>> > Matt
>> Strange, I get the same error both with single and multiple processes...
>Could you get a stack trace with gdb? Also, I ran on petsc-dev.
Breakpoint 1, vecsumsegv::vecsumsegv (this=0x7fffffffd310, m=3, n=4)
at vecsumsegv.cc:28
28 ierr = VecSum(x,&val);
(gdb) next
Program received signal SIGSEGV, Segmentation fault.
0x00000000004fda7c in VecSum (v=0xbad750, sum=0x7fffffffd2c8)
at /home/CKlaij/ReFRESCO/Libraries/build/petsc-3.2-p5/src/vec/vec/utils/vinv.c:1307
1307 lsum += x[i];
(gdb) backtrace
#0 0x00000000004fda7c in VecSum (v=0xbad750, sum=0x7fffffffd2c8)
#1 0x000000000041f93e in vecsumsegv::vecsumsegv (this=0x7fffffffd310, m=3,
n=4) at vecsumsegv.cc:28
#2 0x00000000004202fd in main (argc=1, argv=0x7fffffffd468)
at vecsumsegv.cc:78
(gdb) bt full
ierr = 0
i = 0
n = 36
x = 0x2
lsum = 0
val = 0
at vecsumsegv.cc:78
ierr = 0
val = 6.3659873728958169e-314
tryme = {ierr = 0, nx = 3, ny = 4, x = 0xbad750, subx = {0xb954e0,
0xb9b640}, isg = {0xba4ac0, 0xba9140}}
dr. ir. Christiaan Klaij
CFD Researcher
Research & Development
E mailto:C.Klaij at marin.nl
T +31 317 49 33 44
MARIN
2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
