[petsc-users] segv in VecSum when using nested vec
Matthew Knepley
knepley at gmail.com
Tue Mar 6 07:51:56 CST 2012
On Tue, Mar 6, 2012 at 2:13 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> In a larger code I'm getting a segmentation fault when setting a null space
> with KSPSetNullSpace. After some trying I can reproduce the problem with
> the small code below. It happens when calling VecSum on a nested vec.
Runs for me:
Vector Object:
type=nest, rows=2
VecNest structure:
(0) : type=mpi, rows=24
Vector Object: 1 MPI processes
type: mpi
Process [0]
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
(1) : type=mpi, rows=12
type: mpi
Process [0]
0
0
0
0
0
0
0
0
0
0
0
0
and it was valgrind clean. Are you running on multiple processes?
Matt
> /* test program to find VecSum segmentation fault */
> #include <petscksp.h>
> class vecsumsegv {
> public:
> PetscErrorCode ierr;
> PetscInt nx, ny;
> Vec x, subx[2];
> IS isg[2];
> vecsumsegv(PetscInt m, PetscInt n);
> private:
> PetscErrorCode setupVectors();
> PetscErrorCode setupIndexSets();
> PetscErrorCode setupVecBlock0();
> PetscErrorCode setupVecBlock1();
> vecsumsegv::vecsumsegv(PetscInt m, PetscInt n) {
> nx=m;
> ny=n;
> ierr = setupVectors();
> ierr = setupIndexSets();
> ierr = VecCreateNest(PETSC_COMM_WORLD,2,isg,subx,&x); // nested vec
> ierr = VecView(x,(PetscViewer)PETSC_VIEWER_DEFAULT);
> // this causes the segv:
> PetscScalar val;
> ierr = VecSum(x,&val);
> PetscErrorCode vecsumsegv::setupVectors() {
> // the two vectors
> ierr = setupVecBlock0(); CHKERRQ(ierr);
> ierr = setupVecBlock1(); CHKERRQ(ierr);
> return 0;
> PetscErrorCode vecsumsegv::setupVecBlock0() {
> // 2N vector corresponding to block 0
> ierr = VecCreate(PETSC_COMM_WORLD,&subx[0]); CHKERRQ(ierr);
> ierr = VecSetSizes(subx[0],PETSC_DECIDE,2*nx*ny); CHKERRQ(ierr);
> ierr = VecSetType(subx[0],VECMPI); CHKERRQ(ierr);
> return 0;
> PetscErrorCode vecsumsegv::setupVecBlock1() {
> // N vector corresponding to block 1
> ierr = VecCreate(PETSC_COMM_WORLD,&subx[1]); CHKERRQ(ierr);
> ierr = VecSetSizes(subx[1],PETSC_DECIDE,nx*ny); CHKERRQ(ierr);
> ierr = VecSetType(subx[1],VECMPI); CHKERRQ(ierr);
> return 0;
> PetscErrorCode vecsumsegv::setupIndexSets() {
> PetscInt rank,m0,m1;
> ierr = MPI_Comm_rank(PETSC_COMM_WORLD,&rank); CHKERRQ(ierr);
> ierr = VecGetLocalSize(subx[0],&m0); CHKERRQ(ierr);
> ierr = VecGetLocalSize(subx[1],&m1); CHKERRQ(ierr);
> // first index set
> PetscInt *idx0=new PetscInt[m0];
> for (int i=0; i<m0; i++) { idx0[i]=i+rank*(m0+m1); }
> ierr =
> ISCreateGeneral(PETSC_COMM_WORLD,m0,idx0,PETSC_COPY_VALUES,&isg[0]);
> CHKERRQ(ierr);
> delete[] idx0;
> // ISView(isg[0],PETSC_VIEWER_STDOUT_WORLD);
> // second index set
> PetscInt *idx1=new PetscInt[m1];
> for (int i=0; i<m1; i++) { idx1[i]=i+(rank+1)*m0+rank*m1; }
> ierr =
> ISCreateGeneral(PETSC_COMM_WORLD,m1,idx1,PETSC_COPY_VALUES,&isg[1]);
> CHKERRQ(ierr);
> delete[] idx1;
> // ISView(isg[1],PETSC_VIEWER_STDOUT_WORLD);
> return 0;
> int main(int argc, char **argv) {
> PetscReal val;
> ierr = PetscInitialize(&argc, &argv, PETSC_NULL, PETSC_NULL);
> CHKERRQ(ierr);
> vecsumsegv tryme(3,4);
> ierr = PetscFinalize(); CHKERRQ(ierr);
> return 0;
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSCERROR: or try
> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
> corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: --------------------- Stack Frames
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [0]PETSC ERROR: INSTEAD the line number of the start of the function
> [0]PETSC ERROR: is given.
> [0]PETSC ERROR: [0] VecSum line 1301
> /home/CKlaij/ReFRESCO/Libraries/build/petsc-3.2-p5/src/vec/vec/utils/vinv.c
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29 13:45:54
> CDT 2011
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ./vecsumsegv on a linux_64b named lin0133 by cklaij Tue
> Mar 6 08:55:25 2012
> [0]PETSC ERROR: Libraries linked from
> /home/CKlaij/ReFRESCO/Libraries/build/petsc-3.2-p5/linux_64bit_debug/lib
> [0]PETSC ERROR: Configure run at Thu Mar 1 10:59:35 2012
> [0]PETSC ERROR: Configure options
> --with-mpi-dir=/opt/refresco/64bit_intelv11.1_openmpi/openmpi-1.4.5
> --with-clanguage=c++ --with-x=1 --with-debugging=1
> --with-hypre-include=/opt/refresco/64bit_intelv11.1_openmpi/hypre-2.7.0b/include
> --with-hypre-lib=/opt/refresco/64bit_intelv11.1_openmpi/hypre-2.7.0b/lib/libHYPRE.a
> --with-ml-include=/opt/refresco/64bit_intelv11.1_openmpi/ml-6.2/include
> --with-ml-lib=/opt/refresco/64bit_intelv11.1_openmpi/ml-6.2/lib/libml.a
> --with-blas-lapack-dir=/opt/intel/mkl
> [0]PETSC ERROR:
> [0]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> with errorcode 59.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> mpiexec has exited due to process rank 0 with PID 565 on
> node lin0133 exiting without calling "finalize". This may
> have caused other processes in the application to be
> terminated by signals sent by mpiexec (as reported here).
> dr. ir. Christiaan Klaij
> CFD Researcher
> Research & Development
> E mailto:C.Klaij at marin.nl
> T +31 317 49 33 44
> MARIN
> 2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
> T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120306/ea6d7f25/attachment-0001.htm>
