[petsc-users] segv in VecSum when using nested vec
    Klaij, Christiaan
    C.Klaij at marin.nl
    Tue Mar  6 02:13:00 CST 2012
In a larger code I'm getting a segmentation fault when setting a null space
with KSPSetNullSpace. After some trying I can reproduce the problem with
the small code below. It happens when calling VecSum on a nested vec.
/*  test program to find VecSum segmentation fault */
#include <petscksp.h>
class vecsumsegv {
public:
  PetscErrorCode ierr;
  PetscInt       nx, ny;
  Vec            x, subx[2];
  IS             isg[2];
  vecsumsegv(PetscInt m, PetscInt n);
private:
  PetscErrorCode setupVectors();
  PetscErrorCode setupIndexSets();
  PetscErrorCode setupVecBlock0();
  PetscErrorCode setupVecBlock1();
vecsumsegv::vecsumsegv(PetscInt m, PetscInt n) {
  nx=m;
  ny=n;
  ierr = setupVectors();
  ierr = setupIndexSets();
  ierr = VecCreateNest(PETSC_COMM_WORLD,2,isg,subx,&x); // nested vec
  ierr = VecView(x,(PetscViewer)PETSC_VIEWER_DEFAULT);
  // this causes the segv:
  PetscScalar val;
  ierr = VecSum(x,&val);
PetscErrorCode vecsumsegv::setupVectors() {
  // the two vectors
  ierr = setupVecBlock0(); CHKERRQ(ierr);
  ierr = setupVecBlock1(); CHKERRQ(ierr);
  return 0;
PetscErrorCode vecsumsegv::setupVecBlock0() {
  // 2N vector corresponding to block 0
  ierr = VecCreate(PETSC_COMM_WORLD,&subx[0]); CHKERRQ(ierr);
  ierr = VecSetSizes(subx[0],PETSC_DECIDE,2*nx*ny); CHKERRQ(ierr);
  ierr = VecSetType(subx[0],VECMPI); CHKERRQ(ierr);
  return 0;
PetscErrorCode vecsumsegv::setupVecBlock1() {
  // N vector corresponding to block 1
  ierr = VecCreate(PETSC_COMM_WORLD,&subx[1]); CHKERRQ(ierr);
  ierr = VecSetSizes(subx[1],PETSC_DECIDE,nx*ny); CHKERRQ(ierr);
  ierr = VecSetType(subx[1],VECMPI); CHKERRQ(ierr);
  return 0;
PetscErrorCode vecsumsegv::setupIndexSets() {
  PetscInt rank,m0,m1;
  ierr = MPI_Comm_rank(PETSC_COMM_WORLD,&rank); CHKERRQ(ierr);
  ierr = VecGetLocalSize(subx[0],&m0); CHKERRQ(ierr);
  ierr = VecGetLocalSize(subx[1],&m1); CHKERRQ(ierr);
  // first index set
  PetscInt *idx0=new PetscInt[m0];
  for (int i=0; i<m0; i++) { idx0[i]=i+rank*(m0+m1); }
  ierr = ISCreateGeneral(PETSC_COMM_WORLD,m0,idx0,PETSC_COPY_VALUES,&isg[0]); CHKERRQ(ierr);
  delete[] idx0;
  //  ISView(isg[0],PETSC_VIEWER_STDOUT_WORLD);
  // second index set
  PetscInt *idx1=new PetscInt[m1];
  for (int i=0; i<m1; i++) { idx1[i]=i+(rank+1)*m0+rank*m1; }
  ierr = ISCreateGeneral(PETSC_COMM_WORLD,m1,idx1,PETSC_COPY_VALUES,&isg[1]); CHKERRQ(ierr);
  delete[] idx1;
  //  ISView(isg[1],PETSC_VIEWER_STDOUT_WORLD);
  return 0;
int main(int argc, char **argv) {
  PetscReal      val;
  ierr = PetscInitialize(&argc, &argv, PETSC_NULL, PETSC_NULL); CHKERRQ(ierr);
  vecsumsegv tryme(3,4);
  ierr = PetscFinalize(); CHKERRQ(ierr);
  return 0;
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] VecSum line 1301 /home/CKlaij/ReFRESCO/Libraries/build/petsc-3.2-p5/src/vec/vec/utils/vinv.c
[0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29 13:45:54 CDT 2011
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR: ./vecsumsegv on a linux_64b named lin0133 by cklaij Tue Mar  6 08:55:25 2012
[0]PETSC ERROR: Libraries linked from /home/CKlaij/ReFRESCO/Libraries/build/petsc-3.2-p5/linux_64bit_debug/lib
[0]PETSC ERROR: Configure run at Thu Mar  1 10:59:35 2012
[0]PETSC ERROR: Configure options --with-mpi-dir=/opt/refresco/64bit_intelv11.1_openmpi/openmpi-1.4.5 --with-clanguage=c++ --with-x=1 --with-debugging=1 --with-hypre-include=/opt/refresco/64bit_intelv11.1_openmpi/hypre-2.7.0b/include --with-hypre-lib=/opt/refresco/64bit_intelv11.1_openmpi/hypre-2.7.0b/lib/libHYPRE.a --with-ml-include=/opt/refresco/64bit_intelv11.1_openmpi/ml-6.2/include --with-ml-lib=/opt/refresco/64bit_intelv11.1_openmpi/ml-6.2/lib/libml.a --with-blas-lapack-dir=/opt/intel/mkl
[0]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 59.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
mpiexec has exited due to process rank 0 with PID 565 on
node lin0133 exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpiexec (as reported here).
dr. ir. Christiaan Klaij
CFD Researcher
Research & Development
E mailto:C.Klaij at marin.nl
T +31 317 49 33 44
MARIN
2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
