[petsc-users] Problem with KSPSetOperators
    Hong Zhang
    hzhang at mcs.anl.gov
    Thu Mar  1 12:32:42 CST 2012
Manfred :
I tested 'SAME_NONZERO_PATTERN' with sequential mumps using
petsc-dev/src/ksp/ksp/examples/tutorials/ex5.c:
petsc-dev/src/ksp/ksp/examples/tutorials>./ex5 -ksp_monitor -mat_type sbaij
-pc_type cholesky -pc_factor_mat_solver_package mumps
  0 KSP Residual norm 7.416198487096e+00
  1 KSP Residual norm 8.281965561733e-16
  1 KSP Residual norm 9.211962217404e-16
Can you switch to petsc-dev
(http://www.mcs.anl.gov/petsc/developers/index.html) to see if you still
get the same error?
Hong
> I am solving with cholesky finite element problems where I have to solve
> multiple times. To improve the performance I use KSPSetOperators and set
> the option SAME_NONZERO_PATTERN because the matrix structure is always the
> same in successive solves. This works great as long I use more than one
> processor. When I use MUMPS, only one processor and a matrix made with
> MATSEQSBAIJ the solving segfaults in the second solve. When I use spooles
> or use LU with AIJ it also works, but I need MUMPS as MatGetInertia only
> works with MUMPS with multiple processors.
> The segfault:
> [0]PETSC ERROR: ------------------------------**
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/**
> petsc-as/documentation/faq.**html#valgrind[0]PETSC<http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSC>ERROR: or try
> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
> corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: ---------------------  Stack Frames
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
> [0]PETSC ERROR:       is given.
> [0]PETSC ERROR: [0] MatFactorNumeric_MUMPS line 642
> src/mat/impls/aij/mpi/mumps/**mumps.c
> [0]PETSC ERROR: [0] MatCholeskyFactorNumeric line 3037
> src/mat/interface/matrix.c
> [0]PETSC ERROR: [0] PCSetUp_Cholesky line 92 src/ksp/pc/impls/factor/**
> cholesky/cholesky.c
> [0]PETSC ERROR: [0] PCSetUp line 797 src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: [0] KSPSetUp line 184 src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: [0] KSPSolve line 331 src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received!
> [0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 6, Wed Jan 11 09:28:45
> CST 2012
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR: ./icona on a linux-gnu named sunray.dps.uibk.ac.at by
> manfred Thu Mar  1 10:06:47 2012
> [0]PETSC ERROR: Libraries linked from /home/manfred/petsc-3.2-p6/**
> linux-gnu-c/lib
> [0]PETSC ERROR: Configure run at Thu Mar  1 09:11:08 2012
> [0]PETSC ERROR: Configure options --with-cc=/home/manfred/gcc-4.**6.2/bin/gcc
> --download-mpich=1 --with-blas-lapack=1 --download-f-blas-lapack=1
> PETSC_ARCH=linux-gnu-c --with-clanguage=cxx --with-cxx=/home/manfred/gcc-*
> *4.6.2/bin/g++ --with-fc=/home/manfred/gcc-4.**6.2/bin/gfortran
> --with-scalapack=1 --download-scalapack=1 --with-blacs=1 --download-blacs=1
> --with-parmetis=1 --download-parmetis=1 --with-spooles=1
> --download-spooles=1 --with-mumps=1 --download-mumps=1 --with-blopex=1
> --download-blopex=1 --with-debugging=1
> [0]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> [cli_0]: aborting job:
> with valgrind I get the error
> ==6853== Invalid read of size 8
> ==6853==    at 0x11CDDAA: dmumps_148_ (dmumps_part1.F:1299)
> ==6853==    by 0x111093C: dmumps_142_ (dmumps_part5.F:5094)
> ==6853==    by 0x11C9754: dmumps_ (dmumps_part1.F:642)
> ==6853==    by 0x10B4DDB: dmumps_f77_ (dmumps_part3.F:6651)
> ==6853==    by 0x108E0FF: dmumps_c (mumps_c.c:422)
> ==6853==    by 0xAE6EB3: MatFactorNumeric_MUMPS(_p_Mat***, _p_Mat*,
> MatFactorInfo const*) (mumps.c:667)
> ==6853==    by 0x9832D7: MatCholeskyFactorNumeric(_p_**Mat*, _p_Mat*,
> MatFactorInfo const*) (matrix.c:3050)
> ==6853==    by 0xDFFE2D: PCSetUp_Cholesky(_p_PC*) (cholesky.c:157)
> ==6853==    by 0xD7B390: PCSetUp(_p_PC*) (precon.c:819)
> ==6853==    by 0xE47BD2: KSPSetUp(_p_KSP*) (itfunc.c:260)
> ==6853==    by 0xE48C47: KSPSolve(_p_KSP*, _p_Vec*, _p_Vec*) (itfunc.c:379)
> ==6853==    by 0x4914E0: Task::runCalc() (Task.cpp:1204)
> Is this a bug or doing I am something wrong? Should I go to MUMPS with
> this error? I have currently a workaround to simply not use
> SAME_NONZERO_PATTERN if using only one processor but as a result it is much
> slower in successive solves.
> Thank you in advance
> Manfred Gratt
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120301/310cf8b2/attachment.htm>
