[petsc-users] Problem with KSPSetOperators
Manfred Gratt
manfred.gratt at uibk.ac.at
Thu Mar 1 03:19:39 CST 2012
Dear all,
I am solving with cholesky finite element problems where I have to solve
multiple times. To improve the performance I use KSPSetOperators and set
the option SAME_NONZERO_PATTERN because the matrix structure is always
the same in successive solves. This works great as long I use more than
one processor. When I use MUMPS, only one processor and a matrix made
with MATSEQSBAIJ the solving segfaults in the second solve. When I use
spooles or use LU with AIJ it also works, but I need MUMPS as
MatGetInertia only works with MUMPS with multiple processors.
The segfault:
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSC
ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to
find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: --------------------- Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR: INSTEAD the line number of the start of the function
[0]PETSC ERROR: is given.
[0]PETSC ERROR: [0] MatFactorNumeric_MUMPS line 642
src/mat/impls/aij/mpi/mumps/mumps.c
[0]PETSC ERROR: [0] MatCholeskyFactorNumeric line 3037
src/mat/interface/matrix.c
[0]PETSC ERROR: [0] PCSetUp_Cholesky line 92
src/ksp/pc/impls/factor/cholesky/cholesky.c
[0]PETSC ERROR: [0] PCSetUp line 797 src/ksp/pc/interface/precon.c
[0]PETSC ERROR: [0] KSPSetUp line 184 src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: [0] KSPSolve line 331 src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 6, Wed Jan 11
09:28:45 CST 2012
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./icona on a linux-gnu named sunray.dps.uibk.ac.at by
manfred Thu Mar 1 10:06:47 2012
[0]PETSC ERROR: Libraries linked from
/home/manfred/petsc-3.2-p6/linux-gnu-c/lib
[0]PETSC ERROR: Configure run at Thu Mar 1 09:11:08 2012
[0]PETSC ERROR: Configure options
--with-cc=/home/manfred/gcc-4.6.2/bin/gcc --download-mpich=1
--with-blas-lapack=1 --download-f-blas-lapack=1 PETSC_ARCH=linux-gnu-c
--with-clanguage=cxx --with-cxx=/home/manfred/gcc-4.6.2/bin/g++
--with-fc=/home/manfred/gcc-4.6.2/bin/gfortran --with-scalapack=1
--download-scalapack=1 --with-blacs=1 --download-blacs=1
--with-parmetis=1 --download-parmetis=1 --with-spooles=1
--download-spooles=1 --with-mumps=1 --download-mumps=1 --with-blopex=1
--download-blopex=1 --with-debugging=1
[0]PETSC ERROR:
[0]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
[cli_0]: aborting job:
with valgrind I get the error
==6853== Invalid read of size 8
==6853== at 0x11CDDAA: dmumps_148_ (dmumps_part1.F:1299)
==6853== by 0x111093C: dmumps_142_ (dmumps_part5.F:5094)
==6853== by 0x11C9754: dmumps_ (dmumps_part1.F:642)
==6853== by 0x10B4DDB: dmumps_f77_ (dmumps_part3.F:6651)
==6853== by 0x108E0FF: dmumps_c (mumps_c.c:422)
==6853== by 0xAE6EB3: MatFactorNumeric_MUMPS(_p_Mat*, _p_Mat*,
MatFactorInfo const*) (mumps.c:667)
==6853== by 0x9832D7: MatCholeskyFactorNumeric(_p_Mat*, _p_Mat*,
MatFactorInfo const*) (matrix.c:3050)
==6853== by 0xDFFE2D: PCSetUp_Cholesky(_p_PC*) (cholesky.c:157)
==6853== by 0xD7B390: PCSetUp(_p_PC*) (precon.c:819)
==6853== by 0xE47BD2: KSPSetUp(_p_KSP*) (itfunc.c:260)
==6853== by 0xE48C47: KSPSolve(_p_KSP*, _p_Vec*, _p_Vec*) (itfunc.c:379)
==6853== by 0x4914E0: Task::runCalc() (Task.cpp:1204)
Is this a bug or doing I am something wrong? Should I go to MUMPS with
this error? I have currently a workaround to simply not use
SAME_NONZERO_PATTERN if using only one processor but as a result it is
much slower in successive solves.
Thank you in advance
Manfred Gratt
