[petsc-users] segfault in MatAssemblyEnd() when using large matrices on multi-core MAC OS-X
Matthew Knepley
knepley at gmail.com
Mon Jul 30 17:11:49 CDT 2012
On Mon, Jul 30, 2012 at 5:04 PM, Ronald M. Caplan <caplanr at predsci.com>wrote:
> Hi everyone,
> I seem to have solved the problem.
> I was storing my entire matrix on node 0 and then calling MatAssembly
> (begin and end) on all nodes (which should have worked...).
> Apparently I was using too much space for the buffering or the like,
> because when I change the code so each node sets its own matrix values,
> than the MatAssemblyEnd does not seg fault.
Hmm, it should give a nice error, not SEGV so I am still interested in the
stack trace.
> Why should this be the case? How many elements of a vector or matrix can
> a single node "set" before Assembly to distribute over all nodes?
If you are going to set a ton of elements, consider using
MAT_ASSEMBLY_FLUSH and calling Assembly a few times during the loop.
Matt
> - Ron C
> On Fri, Jul 27, 2012 at 2:14 PM, Ronald M. Caplan <caplanr at predsci.com>wrote:
>> Hi,
>> I do not know how to get the stack trace.
>> Attached is the code and makefile.
>> The value of npts is set to 25 which is where the code crashes with more
>> than one core running. If I set the npts to around 10, then the code
>> works with up to 12 processes (fast too!) but no more otherwise there is a
>> crash as well.
>> Thanks for your help!
>> - Ron C
>> On Fri, Jul 27, 2012 at 1:52 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Fri, Jul 27, 2012 at 3:35 PM, Ronald M. Caplan <caplanr at predsci.com>wrote:
>>>> 1) Checked it, had no leaks or any other problems that I could see.
>>>> 2) Ran it with debugging and without. The debugging is how I know it
>>>> was in MatAssemblyEnd().
>>> Its rare when valgrind does not catch something, but it happens. From
>>> here I would really like:
>>> 1) The stack trace from the fault
>>> 2) The code to run here
>>> This is one of the oldest and most used pieces of PETSc. Its difficult
>>> to believe that the bug is there
>>> rather than a result of earlier memory corruption.
>>> Thanks,
>>> Matt
>>>> 3) Here is the matrix part of the code:
>>>> !Create matrix:
>>>> call MatCreate(PETSC_COMM_WORLD,A,ierr)
>>>> call MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,N,N,ierr)
>>>> call MatSetType(A,MATMPIAIJ,ierr)
>>>> call MatSetFromOptions(A,ierr)
>>>> !print*,'3nrt: ',3*nr*nt
>>>> i = 16
>>>> IF(size .eq. 1) THEN
>>>> j = 0
>>>> ELSE
>>>> j = 8
>>>> END IF
>>>> call MatMPIAIJSetPreallocation(A,i,PETSC_NULL_INTEGER,
>>>> & j,PETSC_NULL_INTEGER,ierr)
>>>> !Do not call this if using preallocation!
>>>> !call MatSetUp(A,ierr)
>>>> call MatGetOwnershipRange(A,i,j,ierr)
>>>> print*,'Rank ',rank,' has range ',i,' and ',j
>>>> !Get MAS matrix in CSR format (random numbers for now):
>>>> IF (rank .eq. 0) THEN
>>>> call GET_RAND_MAS_MATRIX(CSR_A,CSR_AI,CSR_AJ,nr,nt,np,M)
>>>> print*,'Number of non-zero entries in matrix:',M
>>>> !Store matrix values one-by-one (inefficient: better way
>>>> ! more complicated - implement later)
>>>> DO i=1,N
>>>> !print*,'numofnonzerosinrowi:',CSR_AJ(i+1)-CSR_AJ(i)+1
>>>> DO j=CSR_AJ(i)+1,CSR_AJ(i+1)
>>>> call MatSetValue(A,i-1,CSR_AI(j),CSR_A(j),
>>>> & INSERT_VALUES,ierr)
>>>> END DO
>>>> END DO
>>>> print*,'Done setting matrix values...'
>>>> END IF
>>>> !Assemble matrix A across all cores:
>>>> call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr)
>>>> print*,'between assembly'
>>>> call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr)
>>>> A couple things to note:
>>>> a) my CSR_AJ is what most peaople would call ai etc
>>>> b) my CSR array values are 0-index but the arrays are 1-indexed.
>>>> Here is the run with one processor (-n 1):
>>>> sumseq:PETSc sumseq$ valgrind mpiexec -n 1 ./petsctest -mat_view_info
>>>> ==26297== Memcheck, a memory error detector
>>>> ==26297== Copyright (C) 2002-2011, and GNU GPL'd, by Julian Seward et
>>>> al.
>>>> ==26297== Using Valgrind-3.7.0 and LibVEX; rerun with -h for copyright
>>>> info
>>>> ==26297== Command: mpiexec -n 1 ./petsctest -mat_view_info
>>>> ==26297==
>>>> UNKNOWN task message [id 3403, to mach_task_self(), reply 0x2803]
>>>> N: 46575
>>>> cores: 1
>>>> MPI TEST: My rank is: 0
>>>> Rank 0 has range 0 and 46575
>>>> Number of non-zero entries in matrix: 690339
>>>> between assembly
>>>> Matrix Object: 1 MPI processes
>>>> type: mpiaij
>>>> rows=46575, cols=46575
>>>> total: nonzeros=690339, allocated nonzeros=745200
>>>> total number of mallocs used during MatSetValues calls =0
>>>> not using I-node (on process 0) routines
>>>> PETSc y=Ax time: 367.9164 nsec/mp.
>>>> PETSc y=Ax flops: 0.2251188 GFLOPS.
>>>> ==26297==
>>>> ==26297== HEAP SUMMARY:
>>>> ==26297== in use at exit: 139,984 bytes in 65 blocks
>>>> ==26297== total heap usage: 938 allocs, 873 frees, 229,722 bytes
>>>> allocated
>>>> ==26297==
>>>> ==26297== LEAK SUMMARY:
>>>> ==26297== definitely lost: 0 bytes in 0 blocks
>>>> ==26297== indirectly lost: 0 bytes in 0 blocks
>>>> ==26297== possibly lost: 0 bytes in 0 blocks
>>>> ==26297== still reachable: 139,984 bytes in 65 blocks
>>>> ==26297== suppressed: 0 bytes in 0 blocks
>>>> ==26297== Rerun with --leak-check=full to see details of leaked memory
>>>> ==26297==
>>>> ==26297== For counts of detected and suppressed errors, rerun with: -v
>>>> ==26297== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 1 from 1)
>>>> Here is the run with 2 processors (-n 2)
>>>> sumseq:PETSc sumseq$ valgrind mpiexec -n 2 ./petsctest -mat_view_info
>>>> ==26301== Memcheck, a memory error detector
>>>> ==26301== Copyright (C) 2002-2011, and GNU GPL'd, by Julian Seward et
>>>> al.
>>>> ==26301== Using Valgrind-3.7.0 and LibVEX; rerun with -h for copyright
>>>> info
>>>> ==26301== Command: mpiexec -n 2 ./petsctest -mat_view_info
>>>> ==26301==
>>>> N: 46575
>>>> cores: 2
>>>> MPI TEST: My rank is: 1
>>>> Rank 0 has range 0 and 23288
>>>> Rank 1 has range 23288 and 46575
>>>> between assembly
>>>> between assembly
>>>> [1]PETSC ERROR:
>>>> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>>> probably memory access out of range
>>>> [1]PETSC ERROR: Try option -start_in_debugger or
>>>> -on_error_attach_debugger
>>>> [1]PETSC ERROR: or see
>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[1]PETSCERROR: or try
>>>> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
>>>> corruption errors
>>>> [1]PETSC ERROR: likely location of problem given in stack below
>>>> [1]PETSC ERROR: --------------------- Stack Frames
>>>> [1]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>> available,
>>>> [1]PETSC ERROR: INSTEAD the line number of the start of the
>>>> function
>>>> [1]PETSC ERROR: is given.
>>>> [1]PETSC ERROR: [1] MatStashScatterGetMesg_Private line 609
>>>> /usr/local/petsc-3.3-p2/src/mat/utils/matstash.c
>>>> [1]PETSC ERROR: [1] MatAssemblyEnd_MPIAIJ line 646
>>>> /usr/local/petsc-3.3-p2/src/mat/impls/aij/mpi/mpiaij.c
>>>> [1]PETSC ERROR: [1] MatAssemblyEnd line 4857
>>>> /usr/local/petsc-3.3-p2/src/mat/interface/matrix.c
>>>> [1]PETSC ERROR: --------------------- Error Message
>>>> [1]PETSC ERROR: Signal received!
>>>> [1]PETSC ERROR:
>>>> [1]PETSC ERROR: Petsc Release Version 3.3.0, Patch 2, Fri Jul 13
>>>> 15:42:00 CDT 2012
>>>> [1]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>> [1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>> [1]PETSC ERROR: See docs/index.html for manual pages.
>>>> [1]PETSC ERROR:
>>>> [1]PETSC ERROR: ./petsctest on a arch-darw named sumseq.predsci.com by
>>>> sumseq Fri Jul 27 13:34:36 2012
>>>> [1]PETSC ERROR: Libraries linked from
>>>> /usr/local/petsc-3.3-p2/arch-darwin-c-debug/lib
>>>> [1]PETSC ERROR: Configure run at Fri Jul 27 13:28:26 2012
>>>> [1]PETSC ERROR: Configure options --with-debugging=1
>>>> [1]PETSC ERROR:
>>>> [1]PETSC ERROR: User provided function() line 0 in unknown directory
>>>> unknown file
>>>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 1
>>>> [cli_1]: aborting job:
>>>> ==26301==
>>>> ==26301== HEAP SUMMARY:
>>>> ==26301== in use at exit: 139,984 bytes in 65 blocks
>>>> ==26301== total heap usage: 1,001 allocs, 936 frees, 234,886 bytes
>>>> allocated
>>>> ==26301==
>>>> ==26301== LEAK SUMMARY:
>>>> ==26301== definitely lost: 0 bytes in 0 blocks
>>>> ==26301== indirectly lost: 0 bytes in 0 blocks
>>>> ==26301== possibly lost: 0 bytes in 0 blocks
>>>> ==26301== still reachable: 139,984 bytes in 65 blocks
>>>> ==26301== suppressed: 0 bytes in 0 blocks
>>>> ==26301== Rerun with --leak-check=full to see details of leaked memory
>>>> ==26301==
>>>> ==26301== For counts of detected and suppressed errors, rerun with: -v
>>>> ==26301== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 1 from 1)
>>>> - Ron
>>>> On Fri, Jul 27, 2012 at 1:19 PM, Jed Brown <jedbrown at mcs.anl.gov>wrote:
>>>>> 1. Check for memory leaks using Valgrind.
>>>>> 2. Be sure to run --with-debugging=1 (the default) when trying to find
>>>>> the error.
>>>>> 3. Send the full error message and the relevant bit of code.
>>>>> On Fri, Jul 27, 2012 at 3:17 PM, Ronald M. Caplan <caplanr at predsci.com
>>>>> > wrote:
>>>>>> Hello,
>>>>>> I am running a simple test code which takes a sparse AIJ matrix in
>>>>>> PETSc and multiplies it by a vector.
>>>>>> The matrix is defined as an AIJ MPI matrix.
>>>>>> When I run the program on a single core, it runs fine.
>>>>>> When I run it using MPI with multiple threads (I am on a 4-core,
>>>>>> 8-thread MAC) I can get the code to run correctly for matrices under a
>>>>>> certain size (2880 X 2880), but when the matrix is set to be larger, the
>>>>>> code crashes with a segfault and the error says it was in the
>>>>>> MatAssemblyEnd(). Sometimes it works with -n 2, but typically it always
>>>>>> crashes when using multi-core.
>>>>>> Any ideas on what it could be?
>>>>>> Thanks,
>>>>>> Ron Caplan
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120730/aaf7f9d3/attachment.html>
