[petsc-users] Fwd: matrix dot product multiplication with petsc
Jed Brown
jedbrown at mcs.anl.gov
Mon Jul 23 21:47:48 CDT 2012
On Mon, Jul 23, 2012 at 9:18 PM, Nicholas Pezolano <npezolano at gmail.com>wrote:
> I am trying to draw random numbers from a complex multivariate mixture
> distribution needed for a monte carlo simulation. X:= mu + Lambda.* W +
> gamma.*sqrt(W) , where they are all NxN dense matrices of equal size where
> N ranges from 100,000 to 2,000,000.
Are these really matrices in the sense of linear operators? Are you also
doing operations like MatMult or KSPSolve with them? If not, then from
PETSc's perspective, these things are vectors and should be stored that
way. If you store them as MatDense, you could use MatGetArray.
I assume that you have 100 TB of memory or whatever is required to store
these enormous dense beasts?
> I need to do the dot product multiplication and addition for every part of
> this distribution. Would petsc be the right tool for this or should i just
> stick to C and mpi. I've already used many petsc functions that have made
> life much eaiser
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120723/1f7e8ca2/attachment.html>
