[petsc-users] Number of nonzeros > 2^31-1
Thu Jul 19 13:35:22 CDT 2012
On Jul 19, 2012, at 4:28 AM, Nicolas TARDIEU wrote:
> Thanks for your answer, Matt.
> The problem is that I am using ML as a preconditioner and it does not support 64 bit indices (information reported in the PETSc configure phase).
> I am afraid I am stuck with this wrong nonzeros number.
   You cannot use ML for such large problems, if ML it is only built for 32 bit integers. It is that simple.
   Barry
> Nicolas
>  <Mail Attachment.gif>
> Nicolas TARDIEU
> Ing. Chercheur
> EDF - R&D Dpt AMA
> nicolas.tardieu at edf.fr
> Tél. : 01 47 65 39 05
>  <Mail Attachment.gif>  	Un geste simple pour l'environnement, n'imprimez ce message que si vous en avez l'utilité.
> knepley at gmail.com
> Envoyé par : petsc-users-bounces at mcs.anl.gov
> 17/07/2012 16:59
> Veuillez répondre à
> petsc-users at mcs.anl.gov
> A
> cc
> Objet
> Re: [petsc-users] Number of nonzeros > 2^31-1
> On Tue, Jul 17, 2012 at 6:20 AM, Nicolas TARDIEU <nicolas.tardieu at edf.fr> wrote:
> Dear PETSc users,
> I am solving an unstructured finite element-based problem with 500 millions unkwowns with PETSc.
> The number of nonzeros is greater than 2^31-1.
> Here is the KSPView I get :
>   Matrix Object:   700 MPI processes
>     type: mpiaij
>     rows=499125000, cols=499125000
>     total: nonzeros=-2147483648, allocated nonzeros=-2147483648
>     total number of mallocs used during MatSetValues calls =0
>       using I-node (on process 0) routines: found 242923 nodes, limit used is 5
> As you can see, The number of nonzeros is <0.
> I would like to check that this is due to the number of nonzeros being greater than 2^31-1.
> Here is a short description of the size of differents types :
> Compiled with full precision matrices (default)
> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8
> Is there a workaround? Should I worry about the result of my simulation?
> You could configure using --with-64-bit-indices.
>     Matt
> Thanks in advance,
> Nicolas
> Nicolas TARDIEU
> Ing. Chercheur
> EDF - R&D Dpt AMA
> Ce message et toutes les pièces jointes (ci-après le 'Message') sont établis à l'intention exclusive des destinataires et les informations qui y figurent sont strictement confidentielles. Toute utilisation de ce Message non conforme à sa destination, toute diffusion ou toute publication totale ou partielle, est interdite sauf autorisation expresse.
> Si vous n'êtes pas le destinataire de ce Message, il vous est interdit de le copier, de le faire suivre, de le divulguer ou d'en utiliser tout ou partie. Si vous avez reçu ce Message par erreur, merci de le supprimer de votre système, ainsi que toutes ses copies, et de n'en garder aucune trace sur quelque support que ce soit. Nous vous remercions également d'en avertir immédiatement l'expéditeur par retour du message.
> Il est impossible de garantir que les communications par messagerie électronique arrivent en temps utile, sont sécurisées ou dénuées de toute erreur ou virus.
> ____________________________________________________
> This message and any attachments (the 'Message') are intended solely for the addressees. The information contained in this Message is confidential. Any use of information contained in this Message not in accord with its purpose, any dissemination or disclosure, either whole or partial, is prohibited except formal approval.
> If you are not the addressee, you may not copy, forward, disclose or use any part of it. If you have received this message in error, please delete it and all copies from your system and notify the sender immediately by return message.
> E-mail communication cannot be guaranteed to be timely secure, error or virus-free.
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
