[petsc-users] Number of nonzeros > 2^31-1
Nicolas TARDIEU nicolas.tardieu at edf.fr
Thu Jul 19 04:28:05 CDT 2012
Thanks for your answer, Matt.
The problem is that I am using ML as a preconditioner and it does not
support 64 bit indices (information reported in the PETSc configure
phase).
I am afraid I am stuck with this wrong nonzeros number.
Nicolas
Nicolas TARDIEU
Ing. Chercheur
EDF - R&D Dpt AMA
Tél. : 01 47 65 39 05
Un geste simple pour l'environnement, n'imprimez ce message que si vous en
avez l'utilité.
knepley at gmail.com
Envoyé par : petsc-users-bounces at mcs.anl.gov
17/07/2012 16:59
Veuillez répondre à
petsc-users at mcs.anl.gov
A
cc
Objet
Re: [petsc-users] Number of nonzeros > 2^31-1
On Tue, Jul 17, 2012 at 6:20 AM, Nicolas TARDIEU <nicolas.tardieu at edf.fr>
wrote:
Dear PETSc users,
I am solving an unstructured finite element-based problem with 500
millions unkwowns with PETSc.
The number of nonzeros is greater than 2^31-1.
Here is the KSPView I get :
  Matrix Object:   700 MPI processes
    type: mpiaij
    rows=499125000, cols=499125000
    total: nonzeros=-2147483648, allocated nonzeros=-2147483648
    total number of mallocs used during MatSetValues calls =0
      using I-node (on process 0) routines: found 242923 nodes, limit used
is 5
As you can see, The number of nonzeros is <0.
I would like to check that this is due to the number of nonzeros being
Here is a short description of the size of differents types :
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
sizeof(PetscScalar) 8
Is there a workaround? Should I worry about the result of my simulation?
You could configure using --with-64-bit-indices.
    Matt
Thanks in advance,
Nicolas
Nicolas TARDIEU
Ing. Chercheur
EDF - R&D Dpt AMA
avez l'utilité.
Ce message et toutes les pièces jointes (ci-après le 'Message') sont
établis à l'intention exclusive des destinataires et les informations qui
y figurent sont strictement confidentielles. Toute utilisation de ce
Message non conforme à sa destination, toute diffusion ou toute
publication totale ou partielle, est interdite sauf autorisation expresse.
Si vous n'êtes pas le destinataire de ce Message, il vous est interdit de
le copier, de le faire suivre, de le divulguer ou d'en utiliser tout ou
partie. Si vous avez reçu ce Message par erreur, merci de le supprimer de
votre système, ainsi que toutes ses copies, et de n'en garder aucune trace
sur quelque support que ce soit. Nous vous remercions également d'en
avertir immédiatement l'expéditeur par retour du message.
Il est impossible de garantir que les communications par messagerie
électronique arrivent en temps utile, sont sécurisées ou dénuées de toute
erreur ou virus.
____________________________________________________
This message and any attachments (the 'Message') are intended solely for
the addressees. The information contained in this Message is confidential.
Any use of information contained in this Message not in accord with its
purpose, any dissemination or disclosure, either whole or partial, is
prohibited except formal approval.
If you are not the addressee, you may not copy, forward, disclose or use
any part of it. If you have received this message in error, please delete
it and all copies from your system and notify the sender immediately by
return message.
E-mail communication cannot be guaranteed to be timely secure, error or
virus-free.
experiments lead.
-- Norbert Wiener
Ce message et toutes les pièces jointes (ci-après le 'Message') sont établis à l'intention exclusive des destinataires et les informations qui y figurent sont strictement confidentielles. Toute utilisation de ce Message non conforme à sa destination, toute diffusion ou toute publication totale ou partielle, est interdite sauf autorisation expresse.
Si vous n'êtes pas le destinataire de ce Message, il vous est interdit de le copier, de le faire suivre, de le divulguer ou d'en utiliser tout ou partie. Si vous avez reçu ce Message par erreur, merci de le supprimer de votre système, ainsi que toutes ses copies, et de n'en garder aucune trace sur quelque support que ce soit. Nous vous remercions également d'en avertir immédiatement l'expéditeur par retour du message.
Il est impossible de garantir que les communications par messagerie électronique arrivent en temps utile, sont sécurisées ou dénuées de toute erreur ou virus.
This message and any attachments (the 'Message') are intended solely for the addressees. The information contained in this Message is confidential. Any use of information contained in this Message not in accord with its purpose, any dissemination or disclosure, either whole or partial, is prohibited except formal approval.
If you are not the addressee, you may not copy, forward, disclose or use any part of it. If you have received this message in error, please delete it and all copies from your system and notify the sender immediately by return message.
E-mail communication cannot be guaranteed to be timely secure, error or virus-free.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120719/042923d7/attachment.html>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120719/042923d7/attachment.gif>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120719/042923d7/attachment-0001.gif>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120719/042923d7/attachment-0002.gif>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120719/042923d7/attachment-0003.gif>
