[petsc-users] Parallel Incomplete Choleski Factorization
Michele Rosso
mrosso at uci.edu
Fri Jul 13 15:44:17 CDT 2012
Thank you,
Michele
On 07/13/2012 12:14 PM, Hong Zhang wrote:
> Michele :
> I need to use the ICC factorization as preconditioner, but I
> noticed that no parallel version is supported.
> Is that correct?
> Correct.
> If so, is there a work around, like building the preconditioner
> "by hand" by using PETSc functions?
> You may try block jacobi with icc in the blocks '-ksp_type cg
> -pc_type bjacobi -sub_pc_type icc'
> Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120713/8f5b82f2/attachment.html>
