[petsc-users] Parallel Incomplete Choleski Factorization
Hong Zhang
hzhang at mcs.anl.gov
Fri Jul 13 14:14:22 CDT 2012
Michele :
> I need to use the ICC factorization as preconditioner, but I noticed that
> no parallel version is supported.
> Is that correct?
Correct.
> If so, is there a work around, like building the preconditioner "by hand"
> by using PETSc functions?
You may try block jacobi with icc in the blocks '-ksp_type cg -pc_type
bjacobi -sub_pc_type icc'
Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120713/1aae5c32/attachment.html>
