[petsc-users] Does this mean the matrix is ill-conditioned?
Matthew Knepley
knepley at gmail.com
Wed Jul 11 15:17:15 CDT 2012
On Wed, Jul 11, 2012 at 12:40 PM, Bao Kai <paeanball at gmail.com> wrote:
> Hi, all,
> The following is the output from the solution of a Poisson equation
> from Darcy's law.
> To compute the condition number of matrix, I did not use PC and use
> GMRES KSP to do the test.
> It seems like that the condition number keep increasing during the
> iterative solution. Does this mean the matrix is ill-conditioned?
Generally yes. Krylov methods take a long time to resolve the smallest
eigenvalues, so this approximation is not great.
> For this test, it did not achieve convergence with 10000 iterations.
> When I use BJOCABI PC and BICGSTAB KSP, it generally takes about 600
> times iteration to get the iteration convergent.
> Any suggestion for improving the convergence rate will be much
> appreciated. The solution of this equation has been the bottleneck of
> my code, it takes more than 90% of the total time.
Try ML or GAMG.
Matt
> Thank you very much.
> Best Regards,
> Kai
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120711/be6c890b/attachment.html>
