[petsc-users] Does this mean the matrix is ill-conditioned?
Bao Kai
paeanball at gmail.com
Wed Jul 11 12:40:51 CDT 2012
Hi, all,
The following is the output from the solution of a Poisson equation
from Darcy's law.
To compute the condition number of matrix, I did not use PC and use
GMRES KSP to do the test.
It seems like that the condition number keep increasing during the
iterative solution. Does this mean the matrix is ill-conditioned?
For this test, it did not achieve convergence with 10000 iterations.
When I use BJOCABI PC and BICGSTAB KSP, it generally takes about 600
times iteration to get the iteration convergent.
Any suggestion for improving the convergence rate will be much
appreciated. The solution of this equation has been the bottleneck of
my code, it takes more than 90% of the total time.
Thank you very much.
Best Regards,
Kai
the KSP type is gmres
the PC type is none
KSP rtol = 0.100000000000000008E-04 abstol = 0.100000000000000001E-49 dtol = 10000.0000000000000 maxit = 10000
SNES rtol = 0.100000000000000002E-07 abstol = 0.100000000000000001E-49 stol = 0.100000000000000002E-07 maxit = 50 maxf= 10000
0 SNES Function norm 4.573151996900e+02
0 KSP Residual norm 4.573151996900e+02
0 KSP Residual norm 4.573151996900e+02 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
1 KSP Residual norm 1.712147820093e+02
1 KSP Residual norm 1.712147820093e+02 % max 1.045538279822e-02 min 1.045538279822e-02 max/min 1.000000000000e+00
2 KSP Residual norm 9.264440714305e+01
2 KSP Residual norm 9.264440714305e+01 % max 1.341442246541e-02 min 6.047306755934e-03 max/min 2.218247396206e+00
3 KSP Residual norm 6.106792472402e+01
3 KSP Residual norm 6.106792472402e+01 % max 1.472031954019e-02 min 3.756157857579e-03 max/min 3.918983199944e+00
4 KSP Residual norm 4.554286112197e+01
4 KSP Residual norm 4.554286112197e+01 % max 1.540277850515e-02 min 2.460246491991e-03 max/min 6.260664756677e+00
5 KSP Residual norm 3.679681248393e+01
5 KSP Residual norm 3.679681248393e+01 % max 1.580188682187e-02 min 1.676768259980e-03 max/min 9.424013561694e+00
6 KSP Residual norm 3.133446439684e+01
6 KSP Residual norm 3.133446439684e+01 % max 1.605437366386e-02 min 1.181527981010e-03 max/min 1.358780657072e+01
7 KSP Residual norm 2.763377137035e+01
7 KSP Residual norm 2.763377137035e+01 % max 1.622367634674e-02 min 8.580313154728e-04 max/min 1.890802358163e+01
8 KSP Residual norm 2.495980544663e+01
8 KSP Residual norm 2.495980544663e+01 % max 1.634245666024e-02 min 6.407061489327e-04 max/min 2.550694524700e+01
9 KSP Residual norm 2.292746640884e+01
9 KSP Residual norm 2.292746640884e+01 % max 1.642887802339e-02 min 4.908297028371e-04 max/min 3.347164592614e+01
10 KSP Residual norm 2.132064948715e+01
10 KSP Residual norm 2.132064948715e+01 % max 1.649366342552e-02 min 3.848443768915e-04 max/min 4.285800810900e+01
11 KSP Residual norm 2.001544594893e+01
11 KSP Residual norm 2.001544594893e+01 % max 1.654353577107e-02 min 3.083036296755e-04 max/min 5.365987999713e+01
12 KSP Residual norm 1.915651242600e+01
12 KSP Residual norm 1.915651242600e+01 % max 1.658817320495e-02 min 2.615347136235e-04 max/min 6.342627705183e+01
13 KSP Residual norm 1.869099502629e+01
13 KSP Residual norm 1.869099502629e+01 % max 2.668576960746e-02 min 2.402286972676e-04 max/min 1.110848533543e+02
14 KSP Residual norm 1.786679692013e+01
14 KSP Residual norm 1.786679692013e+01 % max 4.531586353791e-02 min 2.028622993290e-04 max/min 2.233823814863e+02
15 KSP Residual norm 1.755222508589e+01
15 KSP Residual norm 1.755222508589e+01 % max 4.617547087190e-02 min 1.895794764179e-04 max/min 2.435678784665e+02
16 KSP Residual norm 1.689478391514e+01
16 KSP Residual norm 1.689478391514e+01 % max 4.690654750900e-02 min 1.642634706428e-04 max/min 2.855567785427e+02
17 KSP Residual norm 1.657593952970e+01
17 KSP Residual norm 1.657593952970e+01 % max 4.757805370202e-02 min 1.522684222525e-04 max/min 3.124617238309e+02
18 KSP Residual norm 1.607807633373e+01
18 KSP Residual norm 1.607807633373e+01 % max 4.787231856714e-02 min 1.357988993999e-04 max/min 3.525236123320e+02
19 KSP Residual norm 1.575670445571e+01
19 KSP Residual norm 1.575670445571e+01 % max 4.831549897599e-02 min 1.252078190052e-04 max/min 3.858824421660e+02
20 KSP Residual norm 1.537090399395e+01
20 KSP Residual norm 1.537090399395e+01 % max 4.848601459775e-02 min 1.140395291915e-04 max/min 4.251684915004e+02
21 KSP Residual norm 1.506947587307e+01
21 KSP Residual norm 1.506947587307e+01 % max 4.877611380564e-02 min 1.052883158172e-04 max/min 4.632623613270e+02
22 KSP Residual norm 1.474968532481e+01
22 KSP Residual norm 1.474968532481e+01 % max 4.889640063411e-02 min 9.704858932772e-05 max/min 5.038342233806e+02
23 KSP Residual norm 1.448591635498e+01
23 KSP Residual norm 1.448591635498e+01 % max 4.908959927887e-02 min 9.023308477824e-05 max/min 5.440310435969e+02
24 KSP Residual norm 1.419842980560e+01
24 KSP Residual norm 1.419842980560e+01 % max 4.918486927922e-02 min 8.355370801843e-05 max/min 5.886617176627e+02
25 KSP Residual norm 1.397964475782e+01
25 KSP Residual norm 1.397964475782e+01 % max 4.931609196955e-02 min 7.848055170355e-05 max/min 6.283861529903e+02
26 KSP Residual norm 1.370513733039e+01
26 KSP Residual norm 1.370513733039e+01 % max 4.939650692420e-02 min 7.267447159755e-05 max/min 6.796954396551e+02
27 KSP Residual norm 1.352528115483e+01
27 KSP Residual norm 1.352528115483e+01 % max 4.948929673950e-02 min 6.891284161113e-05 max/min 7.181433181752e+02
28 KSP Residual norm 1.326081311243e+01
28 KSP Residual norm 1.326081311243e+01 % max 4.955787236964e-02 min 6.379160955998e-05 max/min 7.768713269892e+02
29 KSP Residual norm 1.310778233412e+01
29 KSP Residual norm 1.310778233412e+01 % max 4.962674116591e-02 min 6.089219676274e-05 max/min 8.149934442220e+02
30 KSP Residual norm 1.285901828880e+01
30 KSP Residual norm 1.285901828880e+01 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
31 KSP Residual norm 1.277079005716e+01
31 KSP Residual norm 1.277079005716e+01 % max 2.722168497237e-03 min 2.722168497237e-03 max/min 1.000000000000e+00
32 KSP Residual norm 1.266683363017e+01
32 KSP Residual norm 1.266683363017e+01 % max 4.004279724366e-02 min 9.127378679357e-04 max/min 4.387108133710e+01
33 KSP Residual norm 1.258849237296e+01
33 KSP Residual norm 1.258849237296e+01 % max 4.594007675035e-02 min 5.298405793964e-04 max/min 8.670547054491e+01
34 KSP Residual norm 1.247351394381e+01
34 KSP Residual norm 1.247351394381e+01 % max 4.806735971621e-02 min 3.132044558135e-04 max/min 1.534695909462e+02
35 KSP Residual norm 1.239668430246e+01
35 KSP Residual norm 1.239668430246e+01 % max 4.883162533294e-02 min 2.407658620779e-04 max/min 2.028178949935e+02
36 KSP Residual norm 1.228012971411e+01
36 KSP Residual norm 1.228012971411e+01 % max 4.934524165164e-02 min 1.723589158474e-04 max/min 2.862935253975e+02
37 KSP Residual norm 1.219746497968e+01
37 KSP Residual norm 1.219746497968e+01 % max 4.956223238081e-02 min 1.430200760698e-04 max/min 3.465403860967e+02
38 KSP Residual norm 1.208654662874e+01
38 KSP Residual norm 1.208654662874e+01 % max 4.975857930187e-02 min 1.138415994604e-04 max/min 4.370860874912e+02
39 KSP Residual norm 1.199303910737e+01
39 KSP Residual norm 1.199303910737e+01 % max 4.984766569132e-02 min 9.727417164001e-05 max/min 5.124450288386e+02
40 KSP Residual norm 1.189050207640e+01
40 KSP Residual norm 1.189050207640e+01 % max 4.994122563351e-02 min 8.271140074009e-05 max/min 6.038009897866e+02
41 KSP Residual norm 1.178490083769e+01
41 KSP Residual norm 1.178490083769e+01 % max 4.998663577089e-02 min 7.181264179337e-05 max/min 6.960701420053e+02
42 KSP Residual norm 1.169000296495e+01
42 KSP Residual norm 1.169000296495e+01 % max 5.003678884890e-02 min 6.368173738923e-05 max/min 7.857321565062e+02
43 KSP Residual norm 1.157478182345e+01
43 KSP Residual norm 1.157478182345e+01 % max 5.006376436088e-02 min 5.605252567009e-05 max/min 8.931580470707e+02
44 KSP Residual norm 1.148607855674e+01
44 KSP Residual norm 1.148607855674e+01 % max 5.009158541095e-02 min 5.111049364404e-05 max/min 9.800645980807e+02
45 KSP Residual norm 1.136412186224e+01
45 KSP Residual norm 1.136412186224e+01 % max 5.011041280799e-02 min 4.555943744020e-05 max/min 1.099890947375e+03
46 KSP Residual norm 1.127749710266e+01
46 KSP Residual norm 1.127749710266e+01 % max 5.012568759917e-02 min 4.224471094501e-05 max/min 1.186555345696e+03
47 KSP Residual norm 1.115147008618e+01
47 KSP Residual norm 1.115147008618e+01 % max 5.014071249101e-02 min 3.811963577839e-05 max/min 1.315351300377e+03
48 KSP Residual norm 1.106039584262e+01
48 KSP Residual norm 1.106039584262e+01 % max 5.015013434089e-02 min 3.561350018397e-05 max/min 1.408177631567e+03
49 KSP Residual norm 1.094059620504e+01
49 KSP Residual norm 1.094059620504e+01 % max 5.016186045748e-02 min 3.270418879645e-05 max/min 1.533805371834e+03
50 KSP Residual norm 1.083508705289e+01
50 KSP Residual norm 1.083508705289e+01 % max 5.016995683788e-02 min 3.052792504522e-05 max/min 1.643411950323e+03
51 KSP Residual norm 1.073367913128e+01
51 KSP Residual norm 1.073367913128e+01 % max 5.017897801665e-02 min 2.865191798905e-05 max/min 1.751330505547e+03
52 KSP Residual norm 1.060603184736e+01
52 KSP Residual norm 1.060603184736e+01 % max 5.018800143551e-02 min 2.660968494931e-05 max/min 1.886080257287e+03
53 KSP Residual norm 1.051172191859e+01
53 KSP Residual norm 1.051172191859e+01 % max 5.019827210111e-02 min 2.526173649961e-05 max/min 1.987126740154e+03
54 KSP Residual norm 1.038153764145e+01
54 KSP Residual norm 1.038153764145e+01 % max 5.020825475867e-02 min 2.361305203455e-05 max/min 2.126292471012e+03
55 KSP Residual norm 1.028119058815e+01
55 KSP Residual norm 1.028119058815e+01 % max 5.022061690155e-02 min 2.248477688732e-05 max/min 2.233538591609e+03
56 KSP Residual norm 1.014232627496e+01
56 KSP Residual norm 1.014232627496e+01 % max 5.023806191189e-02 min 2.107980706501e-05 max/min 2.383231580676e+03
57 KSP Residual norm 1.003842698073e+01
57 KSP Residual norm 1.003842698073e+01 % max 5.024688436678e-02 min 2.014709071403e-05 max/min 2.494001991652e+03
58 KSP Residual norm 9.919507136373e+00
58 KSP Residual norm 9.919507136373e+00 % max 5.025366627009e-02 min 1.916742405033e-05 max/min 2.621826810851e+03
59 KSP Residual norm 9.796376380994e+00
59 KSP Residual norm 9.796376380994e+00 % max 5.025842293049e-02 min 1.825927170108e-05 max/min 2.752487818423e+03
60 KSP Residual norm 9.691561821651e+00
60 KSP Residual norm 9.691561821651e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
61 KSP Residual norm 9.632099259731e+00
61 KSP Residual norm 9.632099259731e+00 % max 2.925500167504e-03 min 2.925500167504e-03 max/min 1.000000000000e+00
62 KSP Residual norm 9.575971599862e+00
62 KSP Residual norm 9.575971599862e+00 % max 3.982286419478e-02 min 8.791324690563e-04 max/min 4.529791083422e+01
63 KSP Residual norm 9.515302874531e+00
63 KSP Residual norm 9.515302874531e+00 % max 4.600312211673e-02 min 4.690569662221e-04 max/min 9.807576782676e+01
64 KSP Residual norm 9.464103525667e+00
64 KSP Residual norm 9.464103525667e+00 % max 4.822778551854e-02 min 3.131693908322e-04 max/min 1.539990399138e+02
65 KSP Residual norm 9.403560332422e+00
65 KSP Residual norm 9.403560332422e+00 % max 4.919703252361e-02 min 2.173988739905e-04 max/min 2.262984698153e+02
66 KSP Residual norm 9.357893043391e+00
66 KSP Residual norm 9.357893043391e+00 % max 4.964622614799e-02 min 1.710060298600e-04 max/min 2.903185705711e+02
67 KSP Residual norm 9.306960541922e+00
67 KSP Residual norm 9.306960541922e+00 % max 4.984787134450e-02 min 1.344096269947e-04 max/min 3.708653350140e+02
68 KSP Residual norm 9.269427150014e+00
68 KSP Residual norm 9.269427150014e+00 % max 4.995400794520e-02 min 1.140155165481e-04 max/min 4.381334177802e+02
69 KSP Residual norm 9.230165861600e+00
69 KSP Residual norm 9.230165861600e+00 % max 5.004176556833e-02 min 9.566114238487e-05 max/min 5.231148648320e+02
70 KSP Residual norm 9.198198029235e+00
70 KSP Residual norm 9.198198029235e+00 % max 5.009558946218e-02 min 8.331899653454e-05 max/min 6.012505136378e+02
71 KSP Residual norm 9.169251469517e+00
71 KSP Residual norm 9.169251469517e+00 % max 5.014519245640e-02 min 7.289198469218e-05 max/min 6.879383606876e+02
72 KSP Residual norm 9.135092793025e+00
72 KSP Residual norm 9.135092793025e+00 % max 5.018215774742e-02 min 6.271927321243e-05 max/min 8.001074498657e+02
73 KSP Residual norm 9.105362494120e+00
73 KSP Residual norm 9.105362494120e+00 % max 5.021388961400e-02 min 5.524064548644e-05 max/min 9.090025862628e+02
74 KSP Residual norm 9.061687673417e+00
74 KSP Residual norm 9.061687673417e+00 % max 5.023739863387e-02 min 4.687817079168e-05 max/min 1.071658680052e+03
75 KSP Residual norm 9.028679662969e+00
75 KSP Residual norm 9.028679662969e+00 % max 5.025730425083e-02 min 4.199221022330e-05 max/min 1.196824458241e+03
76 KSP Residual norm 8.992880406408e+00
76 KSP Residual norm 8.992880406408e+00 % max 5.027454686058e-02 min 3.752738297751e-05 max/min 1.339676334231e+03
77 KSP Residual norm 8.964528819102e+00
77 KSP Residual norm 8.964528819102e+00 % max 5.028699554781e-02 min 3.449201415211e-05 max/min 1.457931546881e+03
78 KSP Residual norm 8.932204845132e+00
78 KSP Residual norm 8.932204845132e+00 % max 5.030072885494e-02 min 3.134400332258e-05 max/min 1.604795926585e+03
79 KSP Residual norm 8.895761877274e+00
79 KSP Residual norm 8.895761877274e+00 % max 5.031028472527e-02 min 2.839269327487e-05 max/min 1.771944783054e+03
80 KSP Residual norm 8.865870934945e+00
80 KSP Residual norm 8.865870934945e+00 % max 5.031998882995e-02 min 2.627396025827e-05 max/min 1.915203811504e+03
81 KSP Residual norm 8.830580132880e+00
81 KSP Residual norm 8.830580132880e+00 % max 5.032777592309e-02 min 2.409536172351e-05 max/min 2.088691446122e+03
82 KSP Residual norm 8.798465225248e+00
82 KSP Residual norm 8.798465225248e+00 % max 5.033524303782e-02 min 2.236523603182e-05 max/min 2.250601914785e+03
83 KSP Residual norm 8.760080074944e+00
83 KSP Residual norm 8.760080074944e+00 % max 5.034177171096e-02 min 2.056519241405e-05 max/min 2.447911534082e+03
84 KSP Residual norm 8.727744076067e+00
84 KSP Residual norm 8.727744076067e+00 % max 5.034598614205e-02 min 1.925152975402e-05 max/min 2.615168081983e+03
85 KSP Residual norm 8.696038485352e+00
85 KSP Residual norm 8.696038485352e+00 % max 5.034985758289e-02 min 1.807525461962e-05 max/min 2.785568371925e+03
86 KSP Residual norm 8.658084916866e+00
86 KSP Residual norm 8.658084916866e+00 % max 5.035288484733e-02 min 1.683572987630e-05 max/min 2.990834684169e+03
87 KSP Residual norm 8.629832651339e+00
87 KSP Residual norm 8.629832651339e+00 % max 5.035570607484e-02 min 1.599518303526e-05 max/min 3.148179421507e+03
88 KSP Residual norm 8.590754754556e+00
88 KSP Residual norm 8.590754754556e+00 % max 5.035804458853e-02 min 1.494573854149e-05 max/min 3.369391512418e+03
89 KSP Residual norm 8.559150744004e+00
89 KSP Residual norm 8.559150744004e+00 % max 5.035997098383e-02 min 1.418721855779e-05 max/min 3.549671895073e+03
90 KSP Residual norm 8.521258228137e+00
90 KSP Residual norm 8.521258228137e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
91 KSP Residual norm 8.497526588411e+00
91 KSP Residual norm 8.497526588411e+00 % max 1.975264931070e-03 min 1.975264931070e-03 max/min 1.000000000000e+00
92 KSP Residual norm 8.469968314368e+00
92 KSP Residual norm 8.469968314368e+00 % max 4.067541947777e-02 min 5.649956814298e-04 max/min 7.199244315432e+01
93 KSP Residual norm 8.442388216535e+00
93 KSP Residual norm 8.442388216535e+00 % max 4.591641283212e-02 min 3.180748040850e-04 max/min 1.443572777297e+02
94 KSP Residual norm 8.419482060407e+00
94 KSP Residual norm 8.419482060407e+00 % max 4.796536774726e-02 min 2.164394688203e-04 max/min 2.216110028762e+02
95 KSP Residual norm 8.391448073437e+00
95 KSP Residual norm 8.391448073437e+00 % max 4.889377486049e-02 min 1.495946596321e-04 max/min 3.268417133388e+02
96 KSP Residual norm 8.368625827061e+00
96 KSP Residual norm 8.368625827061e+00 % max 4.933631094537e-02 min 1.176354530136e-04 max/min 4.194000165890e+02
97 KSP Residual norm 8.343888719911e+00
97 KSP Residual norm 8.343888719911e+00 % max 4.966580952625e-02 min 9.275757622672e-05 max/min 5.354366893422e+02
98 KSP Residual norm 8.318859375781e+00
98 KSP Residual norm 8.318859375781e+00 % max 4.985554288816e-02 min 7.584651557689e-05 max/min 6.573214670305e+02
99 KSP Residual norm 8.296818234372e+00
99 KSP Residual norm 8.296818234372e+00 % max 5.000465250274e-02 min 6.434331078101e-05 max/min 7.771538625503e+02
100 KSP Residual norm 8.273996484882e+00
100 KSP Residual norm 8.273996484882e+00 % max 5.008895279168e-02 min 5.506848158263e-05 max/min 9.095757019652e+02
101 KSP Residual norm 8.255724949899e+00
101 KSP Residual norm 8.255724949899e+00 % max 5.014593371023e-02 min 4.882008841863e-05 max/min 1.027157781449e+03
102 KSP Residual norm 8.232669957556e+00
102 KSP Residual norm 8.232669957556e+00 % max 5.018913332758e-02 min 4.226042050076e-05 max/min 1.187615568725e+03
103 KSP Residual norm 8.213296377141e+00
103 KSP Residual norm 8.213296377141e+00 % max 5.021868252235e-02 min 3.780616575153e-05 max/min 1.328319905605e+03
104 KSP Residual norm 8.193132226826e+00
104 KSP Residual norm 8.193132226826e+00 % max 5.024688075415e-02 min 3.377511995259e-05 max/min 1.487689187327e+03
105 KSP Residual norm 8.171643254763e+00
105 KSP Residual norm 8.171643254763e+00 % max 5.026728153150e-02 min 3.023415073303e-05 max/min 1.662599421937e+03
106 KSP Residual norm 8.151829662774e+00
106 KSP Residual norm 8.151829662774e+00 % max 5.028708500556e-02 min 2.744400922332e-05 max/min 1.832351993339e+03
107 KSP Residual norm 8.129025765420e+00
107 KSP Residual norm 8.129025765420e+00 % max 5.030339522581e-02 min 2.474875172459e-05 max/min 2.032562926228e+03
108 KSP Residual norm 8.111309802627e+00
108 KSP Residual norm 8.111309802627e+00 % max 5.031735287766e-02 min 2.293050726954e-05 max/min 2.194341027270e+03
109 KSP Residual norm 8.090366540985e+00
109 KSP Residual norm 8.090366540985e+00 % max 5.033121784005e-02 min 2.101137296849e-05 max/min 2.395427367623e+03
110 KSP Residual norm 8.073027662070e+00
110 KSP Residual norm 8.073027662070e+00 % max 5.034138335267e-02 min 1.960159080315e-05 max/min 2.568229479853e+03
111 KSP Residual norm 8.054434159270e+00
111 KSP Residual norm 8.054434159270e+00 % max 5.035015883239e-02 min 1.821682208537e-05 max/min 2.763937562570e+03
112 KSP Residual norm 8.032053340546e+00
112 KSP Residual norm 8.032053340546e+00 % max 5.035739060038e-02 min 1.676987839775e-05 max/min 3.002847689530e+03
113 KSP Residual norm 8.010926961336e+00
113 KSP Residual norm 8.010926961336e+00 % max 5.036401843600e-02 min 1.558244441831e-05 max/min 3.232099989191e+03
114 KSP Residual norm 7.984492067800e+00
114 KSP Residual norm 7.984492067800e+00 % max 5.036915025576e-02 min 1.432125376193e-05 max/min 3.517090828294e+03
115 KSP Residual norm 7.961675302740e+00
115 KSP Residual norm 7.961675302740e+00 % max 5.037370765890e-02 min 1.339130397868e-05 max/min 3.761673078224e+03
116 KSP Residual norm 7.932625028152e+00
116 KSP Residual norm 7.932625028152e+00 % max 5.037827218254e-02 min 1.237220076291e-05 max/min 4.071892555573e+03
117 KSP Residual norm 7.906813066610e+00
117 KSP Residual norm 7.906813066610e+00 % max 5.038125939613e-02 min 1.160011274858e-05 max/min 4.343169802576e+03
118 KSP Residual norm 7.879520099545e+00
118 KSP Residual norm 7.879520099545e+00 % max 5.038362664858e-02 min 1.088466124387e-05 max/min 4.628864924663e+03
119 KSP Residual norm 7.847935193267e+00
119 KSP Residual norm 7.847935193267e+00 % max 5.038553316037e-02 min 1.017160174043e-05 max/min 4.953549543737e+03
120 KSP Residual norm 7.820348365528e+00
120 KSP Residual norm 7.820348365528e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
121 KSP Residual norm 7.799046045074e+00
121 KSP Residual norm 7.799046045074e+00 % max 1.763573844259e-03 min 1.763573844259e-03 max/min 1.000000000000e+00
122 KSP Residual norm 7.772891000068e+00
122 KSP Residual norm 7.772891000068e+00 % max 4.012276949233e-02 min 5.621079331001e-04 max/min 7.137911979118e+01
123 KSP Residual norm 7.751356511735e+00
123 KSP Residual norm 7.751356511735e+00 % max 4.589984449729e-02 min 3.294352346375e-04 max/min 1.393288867470e+02
124 KSP Residual norm 7.729080405053e+00
124 KSP Residual norm 7.729080405053e+00 % max 4.809613107581e-02 min 2.125971954232e-04 max/min 2.262312585077e+02
125 KSP Residual norm 7.705970794736e+00
125 KSP Residual norm 7.705970794736e+00 % max 4.905136349091e-02 min 1.510670687320e-04 max/min 3.246992471796e+02
126 KSP Residual norm 7.686819565608e+00
126 KSP Residual norm 7.686819565608e+00 % max 4.952725262914e-02 min 1.178748152432e-04 max/min 4.201682312458e+02
127 KSP Residual norm 7.666701686115e+00
127 KSP Residual norm 7.666701686115e+00 % max 4.976093182491e-02 min 9.328491735132e-05 max/min 5.334295536491e+02
128 KSP Residual norm 7.649235097233e+00
128 KSP Residual norm 7.649235097233e+00 % max 4.989696153267e-02 min 7.766412200490e-05 max/min 6.424711983421e+02
129 KSP Residual norm 7.633235754643e+00
129 KSP Residual norm 7.633235754643e+00 % max 5.000231707025e-02 min 6.587368573978e-05 max/min 7.590636004151e+02
130 KSP Residual norm 7.619220007143e+00
130 KSP Residual norm 7.619220007143e+00 % max 5.007176928445e-02 min 5.716773243860e-05 max/min 8.758746787486e+02
131 KSP Residual norm 7.606446986325e+00
131 KSP Residual norm 7.606446986325e+00 % max 5.012837361729e-02 min 5.008891864933e-05 max/min 1.000787698537e+03
132 KSP Residual norm 7.592330732659e+00
132 KSP Residual norm 7.592330732659e+00 % max 5.017504638090e-02 min 4.343768101856e-05 max/min 1.155104167726e+03
133 KSP Residual norm 7.579037905111e+00
133 KSP Residual norm 7.579037905111e+00 % max 5.021088967367e-02 min 3.821442461058e-05 max/min 1.313925047553e+03
134 KSP Residual norm 7.562856215056e+00
134 KSP Residual norm 7.562856215056e+00 % max 5.023848561968e-02 min 3.313432200285e-05 max/min 1.516206838799e+03
135 KSP Residual norm 7.547358511004e+00
135 KSP Residual norm 7.547358511004e+00 % max 5.026078841519e-02 min 2.933327392962e-05 max/min 1.713439438631e+03
136 KSP Residual norm 7.532901434331e+00
136 KSP Residual norm 7.532901434331e+00 % max 5.028045023141e-02 min 2.637769496002e-05 max/min 1.906173011236e+03
137 KSP Residual norm 7.519753135895e+00
137 KSP Residual norm 7.519753135895e+00 % max 5.029524526417e-02 min 2.407220090845e-05 max/min 2.089349679967e+03
138 KSP Residual norm 7.507202333456e+00
138 KSP Residual norm 7.507202333456e+00 % max 5.031012734177e-02 min 2.208251190735e-05 max/min 2.278279190015e+03
139 KSP Residual norm 7.491643996798e+00
139 KSP Residual norm 7.491643996798e+00 % max 5.032241606998e-02 min 1.997321813357e-05 max/min 2.519494641947e+03
140 KSP Residual norm 7.479003314360e+00
140 KSP Residual norm 7.479003314360e+00 % max 5.033319407435e-02 min 1.849197931329e-05 max/min 2.721893271759e+03
141 KSP Residual norm 7.464516162579e+00
141 KSP Residual norm 7.464516162579e+00 % max 5.034358555367e-02 min 1.698606528749e-05 max/min 2.963816793447e+03
142 KSP Residual norm 7.449996382478e+00
142 KSP Residual norm 7.449996382478e+00 % max 5.035230265047e-02 min 1.568572671913e-05 max/min 3.210071394975e+03
143 KSP Residual norm 7.434571619570e+00
143 KSP Residual norm 7.434571619570e+00 % max 5.036072594499e-02 min 1.447781135267e-05 max/min 3.478476457405e+03
144 KSP Residual norm 7.419000751324e+00
144 KSP Residual norm 7.419000751324e+00 % max 5.036623286253e-02 min 1.343175093003e-05 max/min 3.749789072542e+03
145 KSP Residual norm 7.405831013304e+00
145 KSP Residual norm 7.405831013304e+00 % max 5.037115175889e-02 min 1.263636694125e-05 max/min 3.986205211759e+03
146 KSP Residual norm 7.389947313335e+00
146 KSP Residual norm 7.389947313335e+00 % max 5.037511137683e-02 min 1.178175543726e-05 max/min 4.275688087830e+03
147 KSP Residual norm 7.376589103834e+00
147 KSP Residual norm 7.376589103834e+00 % max 5.037884873619e-02 min 1.113697859480e-05 max/min 4.523565193858e+03
148 KSP Residual norm 7.361904465068e+00
148 KSP Residual norm 7.361904465068e+00 % max 5.038244929028e-02 min 1.048869803082e-05 max/min 4.803498884443e+03
149 KSP Residual norm 7.345707930341e+00
149 KSP Residual norm 7.345707930341e+00 % max 5.038557618488e-02 min 9.853233140868e-06 max/min 5.113608443496e+03
150 KSP Residual norm 7.332036969948e+00
150 KSP Residual norm 7.332036969948e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
151 KSP Residual norm 7.320455375230e+00
151 KSP Residual norm 7.320455375230e+00 % max 1.431385688657e-03 min 1.431385688657e-03 max/min 1.000000000000e+00
152 KSP Residual norm 7.306137835405e+00
152 KSP Residual norm 7.306137835405e+00 % max 4.067576743363e-02 min 4.241260979801e-04 max/min 9.590489155784e+01
153 KSP Residual norm 7.293375577879e+00
153 KSP Residual norm 7.293375577879e+00 % max 4.590977116489e-02 min 2.456009487710e-04 max/min 1.869283135697e+02
154 KSP Residual norm 7.281375640680e+00
154 KSP Residual norm 7.281375640680e+00 % max 4.794606694861e-02 min 1.624135035336e-04 max/min 2.952098557415e+02
155 KSP Residual norm 7.267585152756e+00
155 KSP Residual norm 7.267585152756e+00 % max 4.883815226720e-02 min 1.132870807821e-04 max/min 4.311008098192e+02
156 KSP Residual norm 7.256005246851e+00
156 KSP Residual norm 7.256005246851e+00 % max 4.928821371002e-02 min 8.875215964924e-05 max/min 5.553466406318e+02
157 KSP Residual norm 7.243046942130e+00
157 KSP Residual norm 7.243046942130e+00 % max 4.962899267192e-02 min 6.961410772597e-05 max/min 7.129157335073e+02
158 KSP Residual norm 7.229811309947e+00
158 KSP Residual norm 7.229811309947e+00 % max 4.983438073161e-02 min 5.673001872789e-05 max/min 8.784481628791e+02
159 KSP Residual norm 7.217877941614e+00
159 KSP Residual norm 7.217877941614e+00 % max 4.999187039515e-02 min 4.800542601518e-05 max/min 1.041379580286e+03
160 KSP Residual norm 7.205919454792e+00
160 KSP Residual norm 7.205919454792e+00 % max 5.008301131493e-02 min 4.122670881103e-05 max/min 1.214819537123e+03
161 KSP Residual norm 7.195409385573e+00
161 KSP Residual norm 7.195409385573e+00 % max 5.014616631182e-02 min 3.631703183888e-05 max/min 1.380789226782e+03
162 KSP Residual norm 7.183547674636e+00
162 KSP Residual norm 7.183547674636e+00 % max 5.019278208096e-02 min 3.173784761671e-05 max/min 1.581480341299e+03
163 KSP Residual norm 7.172979874079e+00
163 KSP Residual norm 7.172979874079e+00 % max 5.022591765326e-02 min 2.839070882841e-05 max/min 1.769096994260e+03
164 KSP Residual norm 7.162534910500e+00
164 KSP Residual norm 7.162534910500e+00 % max 5.025519893286e-02 min 2.551128075164e-05 max/min 1.969920656752e+03
165 KSP Residual norm 7.150786114562e+00
165 KSP Residual norm 7.150786114562e+00 % max 5.027704919547e-02 min 2.281464044572e-05 max/min 2.203718674204e+03
166 KSP Residual norm 7.139085411880e+00
166 KSP Residual norm 7.139085411880e+00 % max 5.029716479060e-02 min 2.058123314807e-05 max/min 2.443836306054e+03
167 KSP Residual norm 7.127348133205e+00
167 KSP Residual norm 7.127348133205e+00 % max 5.031340434771e-02 min 1.870110965983e-05 max/min 2.690396733825e+03
168 KSP Residual norm 7.117236740050e+00
168 KSP Residual norm 7.117236740050e+00 % max 5.032704745463e-02 min 1.728792595435e-05 max/min 2.911109614162e+03
169 KSP Residual norm 7.106581467538e+00
169 KSP Residual norm 7.106581467538e+00 % max 5.033992742731e-02 min 1.595303186658e-05 max/min 3.155508485680e+03
170 KSP Residual norm 7.096702708897e+00
170 KSP Residual norm 7.096702708897e+00 % max 5.034994373036e-02 min 1.484567897591e-05 max/min 3.391555469579e+03
171 KSP Residual norm 7.086565366195e+00
171 KSP Residual norm 7.086565366195e+00 % max 5.035812213690e-02 min 1.381612484622e-05 max/min 3.644880362433e+03
172 KSP Residual norm 7.075012585924e+00
172 KSP Residual norm 7.075012585924e+00 % max 5.036502228469e-02 min 1.278340351316e-05 max/min 3.939875811073e+03
173 KSP Residual norm 7.062833495345e+00
173 KSP Residual norm 7.062833495345e+00 % max 5.037137634876e-02 min 1.183829447275e-05 max/min 4.254952135607e+03
174 KSP Residual norm 7.048879356834e+00
174 KSP Residual norm 7.048879356834e+00 % max 5.037656483477e-02 min 1.091961875670e-05 max/min 4.613399602791e+03
175 KSP Residual norm 7.035902594057e+00
175 KSP Residual norm 7.035902594057e+00 % max 5.038141686987e-02 min 1.018839733079e-05 max/min 4.944979591404e+03
176 KSP Residual norm 7.021136476465e+00
176 KSP Residual norm 7.021136476465e+00 % max 5.038611549016e-02 min 9.468564830312e-06 max/min 5.321409991180e+03
177 KSP Residual norm 7.006593845151e+00
177 KSP Residual norm 7.006593845151e+00 % max 5.038959144611e-02 min 8.859635889121e-06 max/min 5.687546539919e+03
178 KSP Residual norm 6.993062833601e+00
178 KSP Residual norm 6.993062833601e+00 % max 5.039236160252e-02 min 8.359618446769e-06 max/min 6.028069573199e+03
179 KSP Residual norm 6.975879436834e+00
179 KSP Residual norm 6.975879436834e+00 % max 5.039481328183e-02 min 7.806301511296e-06 max/min 6.455658061491e+03
180 KSP Residual norm 6.961936159036e+00
180 KSP Residual norm 6.961936159036e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
181 KSP Residual norm 6.949571104766e+00
181 KSP Residual norm 6.949571104766e+00 % max 1.399351227981e-03 min 1.399351227981e-03 max/min 1.000000000000e+00
182 KSP Residual norm 6.934430276323e+00
182 KSP Residual norm 6.934430276323e+00 % max 4.006268471447e-02 min 4.553537108235e-04 max/min 8.798146092192e+01
183 KSP Residual norm 6.922501402175e+00
183 KSP Residual norm 6.922501402175e+00 % max 4.594179754423e-02 min 2.676752077283e-04 max/min 1.716326212432e+02
184 KSP Residual norm 6.909332295912e+00
184 KSP Residual norm 6.909332295912e+00 % max 4.812582036535e-02 min 1.696467143449e-04 max/min 2.836825962188e+02
185 KSP Residual norm 6.896287042548e+00
185 KSP Residual norm 6.896287042548e+00 % max 4.906043413850e-02 min 1.212860900976e-04 max/min 4.045017371655e+02
186 KSP Residual norm 6.884916847633e+00
186 KSP Residual norm 6.884916847633e+00 % max 4.953832593062e-02 min 9.391587179028e-05 max/min 5.274755479163e+02
187 KSP Residual norm 6.873060200420e+00
187 KSP Residual norm 6.873060200420e+00 % max 4.977259153265e-02 min 7.430022632071e-05 max/min 6.698847903613e+02
188 KSP Residual norm 6.862680021627e+00
188 KSP Residual norm 6.862680021627e+00 % max 4.991455828748e-02 min 6.176130304247e-05 max/min 8.081849933308e+02
189 KSP Residual norm 6.852837583168e+00
189 KSP Residual norm 6.852837583168e+00 % max 5.002041053011e-02 min 5.220301128960e-05 max/min 9.581901368221e+02
190 KSP Residual norm 6.844339558399e+00
190 KSP Residual norm 6.844339558399e+00 % max 5.009153534565e-02 min 4.533445353381e-05 max/min 1.104933035275e+03
191 KSP Residual norm 6.836163224382e+00
191 KSP Residual norm 6.836163224382e+00 % max 5.014995414872e-02 min 3.956405914800e-05 max/min 1.267563420657e+03
192 KSP Residual norm 6.827649277866e+00
192 KSP Residual norm 6.827649277866e+00 % max 5.019724473232e-02 min 3.449994474144e-05 max/min 1.454994931398e+03
193 KSP Residual norm 6.819390263748e+00
193 KSP Residual norm 6.819390263748e+00 % max 5.023378666870e-02 min 3.037668631425e-05 max/min 1.653695408019e+03
194 KSP Residual norm 6.809627039335e+00
194 KSP Residual norm 6.809627039335e+00 % max 5.026073446154e-02 min 2.647033683855e-05 max/min 1.898756890329e+03
195 KSP Residual norm 6.800053875740e+00
195 KSP Residual norm 6.800053875740e+00 % max 5.028268345327e-02 min 2.345083920236e-05 max/min 2.144174160224e+03
196 KSP Residual norm 6.790862273360e+00
196 KSP Residual norm 6.790862273360e+00 % max 5.030114878577e-02 min 2.105839057759e-05 max/min 2.388651145986e+03
197 KSP Residual norm 6.782848047202e+00
197 KSP Residual norm 6.782848047202e+00 % max 5.031488527030e-02 min 1.926879621578e-05 max/min 2.611210617770e+03
198 KSP Residual norm 6.774820940722e+00
198 KSP Residual norm 6.774820940722e+00 % max 5.032806655943e-02 min 1.765506124918e-05 max/min 2.850631093775e+03
199 KSP Residual norm 6.765560705278e+00
199 KSP Residual norm 6.765560705278e+00 % max 5.033850883800e-02 min 1.605613422737e-05 max/min 3.135157449805e+03
200 KSP Residual norm 6.757382042481e+00
200 KSP Residual norm 6.757382042481e+00 % max 5.034786300596e-02 min 1.483058273224e-05 max/min 3.394867478574e+03
201 KSP Residual norm 6.748407018126e+00
201 KSP Residual norm 6.748407018126e+00 % max 5.035636455149e-02 min 1.364758464500e-05 max/min 3.689763856488e+03
202 KSP Residual norm 6.739546132243e+00
202 KSP Residual norm 6.739546132243e+00 % max 5.036368235375e-02 min 1.263270753527e-05 max/min 3.986768649010e+03
203 KSP Residual norm 6.729883903870e+00
203 KSP Residual norm 6.729883903870e+00 % max 5.037053456809e-02 min 1.166511323803e-05 max/min 4.318049344251e+03
204 KSP Residual norm 6.720537000820e+00
204 KSP Residual norm 6.720537000820e+00 % max 5.037532511363e-02 min 1.085623180438e-05 max/min 4.640221950061e+03
205 KSP Residual norm 6.712215379652e+00
205 KSP Residual norm 6.712215379652e+00 % max 5.037958968674e-02 min 1.020706245172e-05 max/min 4.935757954362e+03
206 KSP Residual norm 6.702764302125e+00
206 KSP Residual norm 6.702764302125e+00 % max 5.038301694015e-02 min 9.547806980790e-06 max/min 5.276920348465e+03
207 KSP Residual norm 6.694503439664e+00
207 KSP Residual norm 6.694503439664e+00 % max 5.038645990787e-02 min 9.027288881950e-06 max/min 5.581571673043e+03
208 KSP Residual norm 6.685836845914e+00
208 KSP Residual norm 6.685836845914e+00 % max 5.038983496539e-02 min 8.525086467240e-06 max/min 5.910771129305e+03
209 KSP Residual norm 6.676056081078e+00
209 KSP Residual norm 6.676056081078e+00 % max 5.039292090854e-02 min 8.016959589319e-06 max/min 6.285789562377e+03
210 KSP Residual norm 6.667972824779e+00
210 KSP Residual norm 6.667972824779e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
211 KSP Residual norm 6.660524120788e+00
211 KSP Residual norm 6.660524120788e+00 % max 1.201057584256e-03 min 1.201057584256e-03 max/min 1.000000000000e+00
212 KSP Residual norm 6.651638150805e+00
212 KSP Residual norm 6.651638150805e+00 % max 4.055003712073e-02 min 3.602702261671e-04 max/min 1.125545054115e+02
213 KSP Residual norm 6.643691520486e+00
213 KSP Residual norm 6.643691520486e+00 % max 4.592802802980e-02 min 2.065701906456e-04 max/min 2.223361845494e+02
214 KSP Residual norm 6.636037873988e+00
214 KSP Residual norm 6.636037873988e+00 % max 4.796407969370e-02 min 1.353722017463e-04 max/min 3.543126216090e+02
215 KSP Residual norm 6.627442754885e+00
215 KSP Residual norm 6.627442754885e+00 % max 4.884567320882e-02 min 9.462015702202e-05 max/min 5.162290440657e+02
216 KSP Residual norm 6.619887241098e+00
216 KSP Residual norm 6.619887241098e+00 % max 4.929835256881e-02 min 7.355460128521e-05 max/min 6.702279899208e+02
217 KSP Residual norm 6.611644672814e+00
217 KSP Residual norm 6.611644672814e+00 % max 4.963767318297e-02 min 5.782377865251e-05 max/min 8.584301188836e+02
218 KSP Residual norm 6.603094047823e+00
218 KSP Residual norm 6.603094047823e+00 % max 4.984846204805e-02 min 4.703322416890e-05 max/min 1.059856365982e+03
219 KSP Residual norm 6.595182173561e+00
219 KSP Residual norm 6.595182173561e+00 % max 5.000432218602e-02 min 3.967324824945e-05 max/min 1.260404035274e+03
220 KSP Residual norm 6.587284563620e+00
220 KSP Residual norm 6.587284563620e+00 % max 5.009670521772e-02 min 3.404241840693e-05 max/min 1.471596542257e+03
221 KSP Residual norm 6.580128584866e+00
221 KSP Residual norm 6.580128584866e+00 % max 5.016072928392e-02 min 2.990024164317e-05 max/min 1.677602806109e+03
222 KSP Residual norm 6.572296403412e+00
222 KSP Residual norm 6.572296403412e+00 % max 5.020731588915e-02 min 2.618933910196e-05 max/min 1.917089839254e+03
223 KSP Residual norm 6.565352707582e+00
223 KSP Residual norm 6.565352707582e+00 % max 5.024073372415e-02 min 2.347465778804e-05 max/min 2.140211549740e+03
224 KSP Residual norm 6.558386275258e+00
224 KSP Residual norm 6.558386275258e+00 % max 5.026951967451e-02 min 2.110562876230e-05 max/min 2.381806305828e+03
225 KSP Residual norm 6.550598040629e+00
225 KSP Residual norm 6.550598040629e+00 % max 5.029079158979e-02 min 1.889984268976e-05 max/min 2.660910591443e+03
226 KSP Residual norm 6.542697017960e+00
226 KSP Residual norm 6.542697017960e+00 % max 5.031008807660e-02 min 1.704236672389e-05 max/min 2.952059939309e+03
227 KSP Residual norm 6.534759376592e+00
227 KSP Residual norm 6.534759376592e+00 % max 5.032533122873e-02 min 1.548375893644e-05 max/min 3.250201158215e+03
228 KSP Residual norm 6.528021311803e+00
228 KSP Residual norm 6.528021311803e+00 % max 5.033781802385e-02 min 1.433114590636e-05 max/min 3.512476835612e+03
229 KSP Residual norm 6.520984017979e+00
229 KSP Residual norm 6.520984017979e+00 % max 5.034943606557e-02 min 1.324786234169e-05 max/min 3.800570595237e+03
230 KSP Residual norm 6.514193170401e+00
230 KSP Residual norm 6.514193170401e+00 % max 5.035841820200e-02 min 1.231461482687e-05 max/min 4.089321420929e+03
231 KSP Residual norm 6.507454678993e+00
231 KSP Residual norm 6.507454678993e+00 % max 5.036564337502e-02 min 1.147801720702e-05 max/min 4.388009049524e+03
232 KSP Residual norm 6.499715568912e+00
232 KSP Residual norm 6.499715568912e+00 % max 5.037174915650e-02 min 1.062931272644e-05 max/min 4.738946952913e+03
233 KSP Residual norm 6.491658928677e+00
233 KSP Residual norm 6.491658928677e+00 % max 5.037725892752e-02 min 9.861215700509e-06 max/min 5.108625595211e+03
234 KSP Residual norm 6.482539749822e+00
234 KSP Residual norm 6.482539749822e+00 % max 5.038200712523e-02 min 9.117400679384e-06 max/min 5.525917846207e+03
235 KSP Residual norm 6.473739436873e+00
235 KSP Residual norm 6.473739436873e+00 % max 5.038639249864e-02 min 8.502157227416e-06 max/min 5.926306836125e+03
236 KSP Residual norm 6.464207246788e+00
236 KSP Residual norm 6.464207246788e+00 % max 5.039071411587e-02 min 7.923453501421e-06 max/min 6.359690772064e+03
237 KSP Residual norm 6.454563042524e+00
237 KSP Residual norm 6.454563042524e+00 % max 5.039401381208e-02 min 7.417590394319e-06 max/min 6.793852333863e+03
238 KSP Residual norm 6.445814111401e+00
238 KSP Residual norm 6.445814111401e+00 % max 5.039670848391e-02 min 7.010929124691e-06 max/min 7.188306654880e+03
239 KSP Residual norm 6.434818602557e+00
239 KSP Residual norm 6.434818602557e+00 % max 5.039914643905e-02 min 6.561797780115e-06 max/min 7.680691805496e+03
240 KSP Residual norm 6.425629227876e+00
240 KSP Residual norm 6.425629227876e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
241 KSP Residual norm 6.417127248758e+00
241 KSP Residual norm 6.417127248758e+00 % max 1.210656778015e-03 min 1.210656778015e-03 max/min 1.000000000000e+00
242 KSP Residual norm 6.407084526202e+00
242 KSP Residual norm 6.407084526202e+00 % max 3.993892554248e-02 min 3.965391930652e-04 max/min 1.007187340897e+02
243 KSP Residual norm 6.399023676786e+00
243 KSP Residual norm 6.399023676786e+00 % max 4.595771539869e-02 min 2.302090353201e-04 max/min 1.996347160519e+02
244 KSP Residual norm 6.390100972460e+00
244 KSP Residual norm 6.390100972460e+00 % max 4.813642522449e-02 min 1.454042346773e-04 max/min 3.310524300158e+02
245 KSP Residual norm 6.381371311556e+00
245 KSP Residual norm 6.381371311556e+00 % max 4.906816728063e-02 min 1.040324840991e-04 max/min 4.716619785209e+02
246 KSP Residual norm 6.373426446725e+00
246 KSP Residual norm 6.373426446725e+00 % max 4.954785702498e-02 min 7.995229606721e-05 max/min 6.197177499859e+02
247 KSP Residual norm 6.365388681789e+00
